Front diff locked up while driving in 4hi
Discussion in '3rd Gen. Tacomas (2016-2023)' started by trail.taco, Dec 17, 2022.
  1. Dec 17, 2022 at 9:07 PM
    trail.taco
    trail.taco [OP] Well-Known Member
    2019 Tacoma Trd Offroad
    Beadlocks, 35s, Mid Travel
    I was driving in 4hi today going about 30mph through some pretty icy and snow covered roads in mammoth when my front tires locked up and sent my truck skidding until it finally stopped. I did regear to 5.29s this year and believe maybe something failed in the diff causing the wheels to lock up. I gave it some light gas and the truck would not move so I put it in 2wd and was able to get off the road. The truck seems to drive fine in 2wd. I noticed when I got the truck home that there was gear oil splattered all over under the truck. It almost looks like the transfer case may have been damaged when this happened as well. Ill check along the top of the t-case for cracks in the morning. Taking the truck to the gear shop next week to get inspected. Just wanted to get some thoughts.
    7EA1AAF9-066A-4F5E-A9A9-9387E0F5C505.jpg C687AD8F-65DF-4072-8569-DAD7166953B8.jpg
    BigWhiteTRD likes this.
  2. Dec 17, 2022 at 10:45 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Same as other thread. You probably had front gear failure and the lock up took out the tcase in the process.
    Installing gears in the front clamshell diff requires attention to detail. When something is done incorrectly, failure is imminent.
    Jerry311SD, Wulf, Mully and 7 others like this.
  3. Dec 18, 2022 at 5:36 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Did you check the front diff housing? That’s probably where the oil came from. I doubt the t-case broke. I had something like this happen on dry payment at 70mph and my t-case was fine. Completely exploded the front diff though.
    trail.taco[OP] and hiPSI like this.
  4. Dec 18, 2022 at 6:39 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Tough brake OP, I feel for you. Hopefully the shop will make it right, sounds like something was not done properly.
    trail.taco[OP] likes this.
  5. Dec 18, 2022 at 6:59 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    The housing on a Toyota clamshell front diff is made of really thin pot metal. If you over-torque the mounting bolts putting it back in the chassis, it can warp the housing, mess up the total preload and the differential will overheat, or worse, seize up. I found this out the hard way when I did gears and Harrop e-lockers on my Tacoma. I ended up having to do my front diff twice.
    I had meticulously set them up but then when I put the front diff back in, I zapped the mounting hardware on with a 3/8" impact and thought nothing of it. Second time around I did the mounting bolts with hand tools and a torque wrench, following all OEM torque specs and checking the preload several times with a beam-style torque wrench to make sure it stayed in spec. If you had a shop do your gears for you, this is probably the step they overlooked.
  6. Dec 18, 2022 at 7:02 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  7. Dec 18, 2022 at 7:40 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  8. Dec 18, 2022 at 7:45 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol great eh?
  9. Dec 18, 2022 at 8:06 AM
    trail.taco
    Ill drop my skid today and check today but it does appear to be coming from the transfer case
  10. Dec 18, 2022 at 8:10 AM
    trail.taco
    Yeah I had a pretty well known shop do it
  11. Dec 18, 2022 at 9:37 AM
    trail.taco
    Narrowed it down to the ring and pinion im pretty sure. Jacked up the front put it in 4hi and put the transmission in neutral. I am able to spin one wheel and the opposite side spins the other direction (spider gears are okay). Switched the truck to 2wd kept the trans in neutral and tried to spin the front driveshaft and im unable to turn it. It should be able to turn freely and rotate at least one of the front tires. Ring and pinion failed somehow and when the front end locked up, the transfer case still wanted to spin the driveshaft. Because of this im pretty sure the transfer case cracked. Not draining any fluids or pulling anything off until the gear shop looks at the truck next week. Hopefully they make things right since transfer cases are not cheap
  12. Dec 18, 2022 at 9:50 AM
    ShimStack
    Ben
    NC
    You pretty much got it. This was also the indication when you were able to drive fine in 2wd (spiders good). Yes, when you tried to spin the front driveshaft by hand in 2wd neutral it should spin freely, but it likely won't rotate a tire when you do that (RF disconnected, more drag on LF than the disconnected RF shaft so the disconnected RF shaft is what will likely be driven to rotate when you do this).
    You're also right on about the shock load going into the transfer case which could likely damage it. This is a very severe case that introduces a lot of stress to driveline components.
    You either ate the R&P or completely seized a bearing. When you tried to spin the front driveshaft was it solidly locked up or did it have some backlash before it felt bound up? It is possible the driveshaft can be locked up by tcase failure, but given your gear work and historical failures that's unlikely the root failure.
  13. Dec 18, 2022 at 10:01 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    wow that sounds catastrophic, hopefully the shop has enough insurance, resources, and moral compass to make it right. If not, hopefully you paid using a major credit card, so maybe you can recoup some monies that way.
  14. Dec 18, 2022 at 10:19 AM
    trail.taco
    Looks like the transfer case end of the driveshaft has some backlash but the diff side is completely seized. Pulled the skid off the transfer case and it looks like hopefully only the seal at the flange started leaking and there are no actual cracks03D8E87A-FA9E-487C-A3CD-9ABE369D0B19.jpg
  15. Dec 18, 2022 at 10:23 AM
    trail.taco
    Yeah I dont want to name drop but I went to a very well known gear shop. Ive never heard anything bad about them and they supposedly offer 1 year warranty on parts and labor
    Chew[QUOTED] likes this.
  16. Dec 18, 2022 at 10:24 AM
    trail.taco
    Yeah I believe the damage stopped there. Call me an idiot but I drove 300+ miles to get home in 2wd and everything seemed normal
  17. Dec 18, 2022 at 10:32 AM
    trail.taco
    I will! Shops getting me in on Tuesday or Wednesday to inspect
  18. Dec 18, 2022 at 10:47 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Yeah definitely give em a chance to make it right before you publicly out them.
    GL
    AmateurTaco1313 likes this.
  19. Dec 18, 2022 at 11:09 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    probably dumb question; if the gear shop re geared both diffs and front diff checks out as OK and they not touch the transfer case and it is a transfer case would it still be on them?
  20. Dec 18, 2022 at 11:13 AM
    ShimStack
    Ben
    NC
    No
