Front diff drain plug seized up and striped, any advise?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Satchmo!, Mar 25, 2023.
  1. Mar 25, 2023 at 9:03 PM
    Satchmo!
    Satchmo! [OP] Well-Known Member
    2019 Tacoma TRD Off-Road
    Was doing some maintenance on the truck today. Decided to do the front & rear diff fluids. The dealership did the front, TC, & rear fluids @ 45k miles. Haven't touched the fluids since and I am at 75k miles currently. Rear went fine, front not so much. Got the front fill plug loose, then the drain plug is stuck on there. Sprayed it some some PB blaster and waited an hour, tried it again and really striped it. Decided that was enough for the night, sprayed some PB blaster to sit overnight and was able to hammer the Allen socket in. Guessing I have 1 more shot at this before the plug is done. I don't have access to heating it with a torch. If all else fails was going to try the chisel method if it was 100% striped. Any advise outside of taking it to the dealer/shop?
    CLVol1255 likes this.
  2. Mar 25, 2023 at 9:06 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Make sure you’re using the proper size allen key and not letting it slip out at an angle while trying to loosen the plug. The correct size should not be able to strip the plug.
    Stevie17, shakerhood and Chew like this.
  3. Mar 25, 2023 at 9:07 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Buy a cheap 10mm hex socket and have a shop weld it onto the plug. Will come out easily. Obviously will need a new drain plug but you will get it off.
  4. Mar 25, 2023 at 9:10 PM
    Satchmo!
    Used a 10mm hex. Made sure it was all the way in also. Had the same problem with my wife's Rav4 a few months back, but that plug was in bad shape. I want to avoid drilling it. I have a new drain plug, went to the dealer before they closed today (was shocked at the $15 price tag on it).
  5. Mar 25, 2023 at 9:11 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Happened on my first gen, stripped it. Same hex style plug I imagine. I notched it with a Dremel and was able to then fit a chisel in the slot and hammer it loose easily. Worth a shot
    Patch Barracks and Stevie17 like this.
  6. Mar 25, 2023 at 9:11 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Easy to weld a nut
    Blockhead and Superdave1.0 like this.
  7. Mar 25, 2023 at 9:12 PM
    MGMDesertTaco
    Switch to the Lexus plug when you get it out. Maybe hit it with a torch?
  8. Mar 25, 2023 at 9:38 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Thanks for the Lexus part numbers
    MGMDesertTaco and Lt. Dangle like this.
  9. Mar 25, 2023 at 9:49 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    A chisel to the side of the plug will work just fine. . . . .trust me.
    Stevie17 and 22Coma6MT like this.
  10. Mar 26, 2023 at 4:04 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    A little heat can help a lot, you can get a basic Bernz-O-Matic plumbers propane torch kit at Lowes's/Home Depot or even The Mart for less than $30.
    BillyE, hiPSI, MKC1911 and 5 others like this.
  11. Mar 26, 2023 at 4:13 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    This is exactly the torch I bought to loosen some difficult hardware while doing suspension work. Works great. Access anywhere.
    It may be a little late at this point but one key to the hex diff plug is thoroughly cleaning out the recess before getting started, so the 10mm will fit all the way inside. Often the stripping happens when the 10mm isn’t fully seated into the plug recess.
  12. Mar 26, 2023 at 6:50 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    just use a fluid pump and extract the fluid through the fill hole. and put some anti-seize on the fill plug.
  13. Mar 26, 2023 at 6:53 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Probably best bet is to weld a bolt to the plug, and then try removing the bolt.
    Patch Barracks and Blockhead like this.
  14. Mar 26, 2023 at 4:33 PM
    Satchmo!
    Got it out, 49ft/lbs my ass. Used the chisel method, plug decided to listen and come out. Noticed the fluid was extremely dirty compared to the rear, it was pretty black and the rear looked clean/newish (they were both "changed" at the same time @ 45k by the dealer). Is that normal for the front to be dirtier than the rear? I use 4wd in the winter/camping/backroads/off roading. This is my daily driver, so most of the time I have it in 2wd. Any thoughts? Thinking of doing the transfer case also since the front fluid was so dirty, hope the dealer didn't pull any BS and wrote it up saying all 3 were changed but only did the rear at the time...
  15. Mar 26, 2023 at 7:04 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga STRONG Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Gets me to thinking about using this. I once used it to remove standing water 13’ down into a steel pole. I couldn’t believe it did it and done it well with a battery powered drill. 13’!!!!
    I’m not sure if it’s strong enough to flow the viscosity of gear oil, but we gonna find out.
    TexasG likes this.
  16. Mar 26, 2023 at 8:17 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    well now we need to know where you got it
  17. Mar 26, 2023 at 8:36 PM
    Superdave1.0
    SoCal
    Congrats!
    Have replaced diff fluids on dozens of Tacomas. The front diff is always dirtier than the T case and rear diff. Not sure why, but it's normal.
    joba27n likes this.
  18. Mar 27, 2023 at 6:47 AM
    zoo truck
    None
    Fluid was always dirtier looking in the front differential than the rear on all my different year toyota pickups.
    shakerhood likes this.
  19. Oct 16, 2023 at 6:20 AM
    yoopersteeze
    yoopersteeze Fake it til you make it
    WI
    2017 Magnetic Gray Metallic Tacoma TRD OR MT
    I am about to embark on this crusade. Wish me luck.
  20. Oct 16, 2023 at 7:04 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    I am looking for a deal on the toyota front diff fluid - im ready otherwise.
    Ill be early on all 3...
    faawrenchbndr likes this.
