Front Diff and Transfer Case Oil Change Howto
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Mar 24, 2011.
  1. Feb 26, 2012 at 12:05 PM
    #121
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Try tapping it with a hammer - not hammering it just tapping it. Sometimes the vibration helps get the blaster into the threads.
  2. Feb 26, 2012 at 12:11 PM
    #122
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    if it strips out it can be romoved ver quick with a 3/8" - 3/4" e-z out....
    used for plumbing......and other stuff.....
  3. Feb 29, 2012 at 1:49 PM
    #123
    desertrock
    desertrock Well-Known Member
    Keoni
    El Paso, TX / Fountain, CO
    Tacoma TRD Off Road
    ToyTec Adjustable Coils W/Bilstein 5100's, Lower front Dif Kit, Rigid Industries Dually s, Throttle body spacer, ARB Front Bumper (some mods), ALL Pro Rear Bumper, Rear Expedition Leaf Springs, Rock Sliders, upgraded Tie Rods, Budbuilt fuel tank skid plates, KN Cold Air intake, Warn HID Lights-4", Banks CatBack Exhaust, Total Chaos UCA, AllPro Transfer Case Skidplate, 886 Rear backlight mod, rock lights, TRD Hawaii Off Road decal (sockmonkey), Garage built Tire Carrier.
    Got a question here. Have a 2006 TRD Off-Road Access cab and looking to change the front diff oil. Do I need LSD additive for the front diff or does the Tacomas have an open front diff. 2006 year model
  4. Feb 29, 2012 at 2:08 PM
    #124
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    LSD is in the rear only
  5. Feb 29, 2012 at 2:23 PM
    #125
    brutalguyracing
    F.U> GUYZ
    broken mods
    someone say lsd
  6. Mar 4, 2012 at 3:06 PM
    #126
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    Just changed the front diff and TC @37k miles. Front diff was funktastic. TS was just a little dark.
  7. Mar 11, 2012 at 1:37 PM
    #127
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    Great write-up.
    Definitely buy a six point 24 mm socket and 10mm hex driver and a nice breaker bar for this. Definitely take the advice everyone has given for soaking the bolts and giving them a tap before trying to break the bolts. Definitely use either a torque wrench or caution not to over- tighten bolts.
    I used Castrol full synthetic 75w-90.
    Don't forget to lube the drive shafts while you are down there.
    Thanks a bunch!
  8. Mar 18, 2012 at 9:08 PM
    #128
    Tacomanato
    Tacomanato Member
    Rey
    San Diego
    06 Tacoma 4x4
    6" Fabtech lift, 31" Kumho Tires, DTRL Mod, BHL Mod, PlastiDip Hood Scoop, USA SPEC PA15-TOY
    Great tutorial! Finished front, rear and transfer today. Used royal purple on front and transfer and conventional mobil 1 with the lsd additive on the rear. Also had a grease gun ready and greased the drive shaft.
    What an improvement! This truck's purring like a tiger at 109k miles!
    Next on the list transmission flush and radiator flush.
    Stryker420 and Veryhelpfulforum like this.
  9. Mar 22, 2012 at 5:52 PM
    #129
    tigertoy
    tigertoy Active Member
    Gary
    Birmingham, Alabama
    2012 TRD/4x4
    18" clad Toyota Wheels/Low Profile Tool Box/Nerf Steps
  10. Mar 23, 2012 at 6:02 AM
    #130
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
  11. Mar 31, 2012 at 12:22 PM
    #131
    crooks420
    crooks420 Well-Known Member
    Jesse
    San Gabriel
    05 AC Prerunner SR5, 12 DC LB 4x4, 70 FJ40
    Can anyone provide the specs on how much gear oil is called for when changinging out the oil in:
    Front differential....
    5 speed manual transmission...
    Transfer case....
    rear differntial....
    I know a few people listed the numbers, but maybe put it here in one post...???
    Thanks.
    Jesse
    2005 Prerunner SR5 Access Cab 2.7 5 speed manual
    2012 Dbl Cab LB SR5 4X4 V6 5 speed auto
    1970 FJ40 Inline 6 3 speed manual w/PTO Winch
  12. Apr 14, 2012 at 10:56 AM
    #132
    crooks420
    Jesse
    San Gabriel
    Ok, so I found this info from my 2005 pre-runner manual:
    4 cylinder Pre-Runner:
    Manual transmission- 2.6 L 75W-90 GL4 or 5
    Rear differential- 2.8 L 90W GL-5
    4 cylinder 4X4:
    Manual transmission- 2.2 L 75W-90 GL4 or 5
    Transfer case- 1.0 L 75W-90 GL4 or 5
    Front Differential- 1.5 L 75W-90 GL5
    Rear Differential- 2.8 L 90W GL5
    4 Cylinder 2X2 (non 4X4, non pre-runner):
    Rear Differential- 3.31L 75W-90 GL4 or 5
    I will look in my 2012 V6 4X4 manual soon, and post those numbers.
    Jesse
    NCAmother likes this.
  13. Apr 17, 2012 at 10:47 AM
    #133
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    this is prbbly a dumb question but if you dont have a 4wd, is there any need to do the front diff and tcase oil changes?
  14. Apr 17, 2012 at 10:48 AM
    #134
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Nope. The front diff and transfer case are part of the 4wd system, you don't have to worry about it.
  15. Apr 17, 2012 at 10:51 AM
    #135
    Muscles
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    haha sweet, ya i was starting to see that only the 4wd people were doing these lol thanks , i prbbly would have figured it out when i got under my truck haah but doesnt hurt to ask
  16. May 3, 2012 at 12:20 PM
    #136
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    where the heck do i get the right size hand pump? i've been to lowes, walmart, autozone (and got the wrong one). someone help a guy out please.
  17. May 3, 2012 at 12:21 PM
    #137
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    The wrong size? How did you get the wrong size? I got the pictured pump at autozone.
  18. May 3, 2012 at 12:23 PM
    #138
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    only size they had was for gallon bottles not the quarts and was too fat to fit down the bottle neck.
  19. May 3, 2012 at 12:24 PM
    #139
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Ah, well, like I said, I got the one I had at autozone. Autozone, advance auto parts, order on Amazon.com?
  20. May 3, 2012 at 12:25 PM
    #140
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    yea i'm gonna go searching Amazon now since the auto stores here failed me. no clue why they wouldnt have the right size. i've had the oil for 3 weeks now just can't find the right pump. thanks for the help.
