Front diff 4wd actuator replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SJC3081, Nov 2, 2018.
  1. Nov 2, 2018 at 12:55 PM
    SJC3081
    SJC3081 [OP] Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    I a previous thread I put my Tacoma in 4wd with the rear tires spinning and the fronts stationary. I fxcked up the 4wd. So I replaced the front actuator and now I have 4wd , but light blinks no 4lo and must shut off truck to disengage the 4wd. So I had the dealer do a diagnostic. The dealer states the new actuator is at a constant 6volts and they think I didn’t time it correctly on install. Is there some special trick on front actuator install ? Also they said front actuator will need to be relearned after install. Any ideas?
  2. Nov 2, 2018 at 5:42 PM
    Taco'09
    Taco'09 Well-Known Member
    Did you mess with the other actuator on the transfer case?
    Are you comfortable using a VOM meter that you could do some diagnostics yourself? If so post back and I will get you something.
    I also have a brand new ADD actuator and if you think i would help I could pull its cover and see where its is clocked.
    SJC3081[OP] likes this.
  3. Nov 2, 2018 at 6:36 PM
    SJC3081
    Wappinger NY
    2011 DCLB 4x4
    Taco 09 thx I’ll await. I didn’t remove the rear actuator only the gear drive. I hear the rear transfer case disengage when shifting 4wd to 2wd.
  4. Nov 2, 2018 at 6:53 PM
    Taco'09
    Here are the diagnostics. You only need a VOM meter and they are really very easy to use if the instructions for the meter are read. Even the free ones at Harbor Freight are pretty good. If you have a buddy that uses them and is more comfortable that always helps.
    Tips: go to the Tacoma tab at the top and click on that. Also pay special note to the very bottom of each page as the arrows show what is happening with that shifting step and where.
    QT312H 4WD COMPILATION FINAL-1.pdf
    SR-71A likes this.
  5. Nov 6, 2018 at 2:17 PM
    SJC3081
    Wappinger NY
    2011 DCLB 4x4
    I reinstalled my front actuator this time placing the fork properly in the groove. Problem solved all 4wd functions are corrected. Super duper thanks to all that helped.
  6. Nov 16, 2018 at 7:44 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
  7. Nov 17, 2018 at 4:30 AM
    SJC3081
    Wappinger NY
    2011 DCLB 4x4
    It’s a great deal.
  8. Nov 17, 2018 at 11:11 AM
    babylon5
    David
    Saw one place on Amazon.ca that wanted $900 for the ADD actuator.:annoyed:
    For anyone that has purchase/replace the ADD is the AISIN one the OEM toyota one? I recall AISIN makes the the 750 transmission so i gather its quite possible they are the manufacturer of the actuator as well??
  9. Nov 19, 2018 at 5:57 AM
    96carboard
    96carboard Well-Known Member
    Toyota OWNS Aisin.
