Front Corner Lights not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by WeaponR, Sep 7, 2009.
  1. Sep 7, 2009 at 5:53 PM
    WeaponR
    WeaponR [OP] Member
    Okay, this might be a dumb question - but what do the front corner lights do?
    The reason I'm asking is because I picked up a Tacoma (2001 Prerunner) recently and the front corner lights do absolutely nothing.
    The signal lights are in the bumper, while the corners stay off all the time. I opened them up today and noticed they had a bulb, so they obviously have to light up sometime...right?
    What fuse is related to the corners? I found the headlight fuse and signals, but not the corner lights...any ideas?
  2. Sep 7, 2009 at 5:56 PM
    mwild
    mwild I CANT SPELL SO DONT BITCH
    Vernon, NJ
    03 2500 Dodge Ram
    Cat-Back, weather techs, ipod and sisuis Old 04 Taco: 5100s At all 4 corners set at 2.5", Toyotec AAL, Gibson cat-back, Deck plate mod, 20% Tint on fronts, 10" Kicker Comp sub, Sirius radio, Bud Built Skid, Pro Comp 8069 Wheels
    they are just mrker lights
  3. Sep 7, 2009 at 6:16 PM
    WeaponR
    WeaponR [OP] Member
    Are they supposed to turn on? Do they do anything at all? Mine are just decorations right now, i'm wondering what fuse is responsible for getting them to light up.
  4. Apr 12, 2012 at 7:58 PM
    ninja_taco
    ninja_taco Well-Known Member
    Nick
    Louisiana
    '10 Prerunner
    Vanillarama Pinetree Scent
    bump. having same issue on a 99 4runner. all the fuses are good and changed the bulbs
  5. Apr 12, 2012 at 8:57 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    The sidemarkers are linked to the TAIL fuse, in the engine compartment. Make sure its a 10A
    Get a Volt Mete, to see if any juice is going to the bulbs?
  6. Apr 13, 2012 at 6:49 AM
    ninja_taco
    Nick
    Louisiana
    '10 Prerunner
    will do. mucho grassy ass. its gone until tonight though
  7. Apr 13, 2012 at 8:23 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    OP - as stated, the lights are marker/corner/park lights. They are not supposed to flash with the turn signal as they are not a turn signal. Your turn signals are in the bumper as you said. The lights are only supposed to come on with you have your headlamp switch turned on. They are designed to let other drivers know the size and positioning of your vehicle at night.
    Check to see if they come on with the headlamp switch. If they don't then will be a matter of doing the problem solving to find out why they are not working at all.
    Fp12 likes this.
