Front coil springs suggestions needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TopShapeCabrio, Mar 27, 2018.
  1. Mar 27, 2018 at 5:12 AM
    TopShapeCabrio
    TopShapeCabrio [OP] Active Member
    Ontario
    07 4x4 TRD Yamaha Edition
    Raider Lo-Rider Elite Tonneau Cover, Weathertech Floor Mats, LED 4x4 Switch, Blu Logic Bluetooth, Toyota Roof Rack
    Hello, I've done some research but haven't found exactly what I'm looking for...
    I have a 2007 Double Cab TRD Yamaha Edition, 6.5 Box, 4x4, 4.0L, Auto, 116000KM (72000Miles).
    Toyota replaced the rear leafs as per the recall and I installed Bilstein 5100 Rear Shocks.
    The ride is SOOOO MUCH better now but I want to replace the front suspension.
    I will use Bilstein 5100 front strut.
    Looking to keep stock height...
    What coil springs should I use? Replace the strut bearing? Any other suggestion???
    Thanks a bunch...
  2. Mar 27, 2018 at 5:13 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    883 coils with the 5100s set to zero if you want stock height
    Yamaha edition?
    Let's so some pics
    doorsidedown, REDdawn6 and jpereira2 like this.
  3. Mar 27, 2018 at 5:59 AM
    TopShapeCabrio
    Ontario
    dd0cf545-aeef-48cd-943d-79d0d9766a65_239f00cf26493b1497895c3c154acd5a0cac36f3.jpg d22b4fb0-e3bf-4dc8-a1a9-ab89e2fe9af5_d05b52eea7aff54d9e7d93cc3bc69bc11af2b014.jpg 89216783-a071-4ff0-bfb5-ced76ffbb122_b3733310d5ee1c9f81c4afcba516671dc76dcd09.jpg
    Thanks for the info on the suspension!!!!
    Here's a couple of pics...
    Yamaha Edition has the Running Boards, TRD CatBack , Black Carbon Fiber Dash Stick Ons around the radio and vents (a little cheesy/cheap but I prefer it over the all gray dash), Stickers on the bed (might be more, can't remember). They did remove some options when you got the Yamaha SE........no diff lock, no HD alternator, no towing package, no bilstein
    lo2hi, timbobzimbob and ChadsPride like this.
  4. Mar 27, 2018 at 6:03 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Lol Yamaha Edition. That's just some custom stickers someone put on.. Toyota doesn't have a Yamaha edition.
    Thats just an TRD sport
    Edit: Uhm OK Canada :canada: ... Must of gotten some money from Yamaha lol
    ChadsPride and KMFDM_V like this.
  5. Mar 27, 2018 at 6:05 AM
    KMFDM_V
    KMFDM_V Well-Known Member
    Ken
    Sacramento, CA
    09 Timberland Mica 2.7L 5MT 4x2 Access
    I may have tweaked a few things...
    Looks clean! A lot of people told me that 5100s are better for when you do lift. 'Upgrading' to a set of coilovers from a 3rd gen will keep you in stock height range but likely lift the front enough to level you out. Finding low mileage 3rd gen suspension parts is easy since so many people upgrade their stock parts early.
    ChadsPride likes this.
  6. Mar 27, 2018 at 6:31 AM
    ChadsPride
    Cool! My dad just picked up an '07 in radiant red
    Pearson, lo2hi, doorsidedown and 2 others like this.
  7. Mar 27, 2018 at 6:32 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Sounds similar to the Ford Chevy edition
    Tacocam24, Fatmonk8 and ChadsPride like this.
  8. Mar 27, 2018 at 6:45 AM
    TopShapeCabrio
    Ontario
    I'm reading that 883 with 5100 will yield about 1" to 1.25" Lift....is this the setup you did on your truck?
    ChadsPride[QUOTED] likes this.
  9. Mar 27, 2018 at 6:47 AM
    ChadsPride
    Initially, but it will most likely settle back into a stockish ride height.
    Negative. My truck has a 5" front & 3" rear lift....for now
    Phoosa likes this.
  10. Mar 27, 2018 at 6:48 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    If you want stock height just reuse your stock coils.
  11. Mar 27, 2018 at 6:51 AM
    TopShapeCabrio
    Ontario
    Cool that seems reasonable if I end up with less than 1" of lift...
  12. Mar 27, 2018 at 7:15 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    Nice truck! I always like seeing these "editions". My question would be, why are replacing the front suspension? Do you feel it's worn out?
    Most people only replace the coils when they want to lift it. If you've put brand new 5100s up front, I would say just leave it.
  13. Mar 27, 2018 at 7:22 AM
    dragonle87
    dragonle87 Well-Known Member
    Atlanta, GA
    '13 DCLB TRD Sport
    Is there any difference with 883 coils and factory coils?
    I still have stock Bilsteins shocks. And what is the difference factory Bilsteins that come with the truck and Bilstein 5100s?
  14. Mar 27, 2018 at 7:24 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    The YAMAHA EDITION was a real thing in Canada.
    REDdawn6 and ChadsPride like this.
  15. Mar 27, 2018 at 7:30 AM
    Chase8059
    Chase
    ESVA
    Is this the Yahama edition as in audio? Or Yamaha edition as in BRAHP? There is a big difference lol
  16. Mar 27, 2018 at 8:08 AM
    TopShapeCabrio
    Ontario
    I'm replacing the front cause it does feel worn out and rule of thumb is to change all the way around at the same time. It has low miles but 11-12 years old.
    When I go over speed bumps (at low speed), the front suspension bottoms out (or very close to). Also, I have a small rattle in the front when hitting pot holes, I will look for the source of the problem but I suspect the noise is coming from the passenger shock.
    I haven't replace the front shocks yet. I want to do it once.
  17. Mar 27, 2018 at 8:16 AM
    Chase8059
    Chase
    ESVA
    Understood, I misread your OP. You have 5100s in the rear but not up front (yet).
    I would consider replacing the bumpstops over the factory coils especially if you want to keep the factory ride height. Those bumpstops could be dry rotted and if you bottom out the suspension it won't be as harsh.
    Also, if you preload the 5100s up front you achieve a leveled look at the .85in mark. This will also stiffen up the front a bit and limit nose diving under hard braking and body lean when cornering. I ran my 5100s at 1.75 and liked the handling alot better over stock.
  18. Mar 27, 2018 at 8:45 AM
    TopShapeCabrio
    Ontario
    By "bumpstop", do you mean the strut bearing over the coil (#18) or the bumper (#17)?
    https://parts.scarboroughtoyota.ca/...5963688/SUSPENSION-COMPONENTS/8512295.html#18
    Are you recommending using OEM for these "bumpstop"
    The .85in mark is the second from the bottom?
    Thanks for your help and clarification...
  19. Mar 27, 2018 at 8:53 AM
    Chase8059
    Chase
    ESVA
    The bumpstop is item 17 in the diagram in your link. I know alot of guys on here do upgrade them to Superbumps from Wheelers, or to Timbren so you might want to search around. I haven't replaced mine yet, but will probably go with Super bumps as alot of members have good things to say. I'm sure somebody will come along and chime in about the aftermarket bumpstops.
    Yes, the bottom mark would be 0, or no lift. Working up, 2nd is .85, 3rd is 1.75, and 4th is 2.5.
    Pearson and ChadsPride like this.
  20. Mar 27, 2018 at 8:55 AM
    TopShapeCabrio
    Ontario
    :cheers: for the good and quick info!!!!!
    Chase8059[QUOTED] and ChadsPride like this.
