Front Bumper with Hitch
Discussion in 'Armor' started by gudujarlson, Jan 8, 2022.
  1. Jan 8, 2022 at 10:01 AM
    gudujarlson
    gudujarlson [OP] Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I'm playing with bumper and winch ideas. I like the idea of having portable winch than I can move from front to back and leave in the garage when not in use. I would also like to have a full front bumper.
    I know winch bumpers can be bought and I know front hitches can be bought, but I do not see any front bumpers with hitches or hitch-bumper combinations that would allow the hitch to be mounted in place of the winch.
    Has anyone done something like this or have thought about it?
  2. Jan 13, 2022 at 7:53 AM
    technocardic
    technocardic New Member
    2019 TRD OR DCSB 6MT
    Retrax One XR tonneau cover, Yakima HD Outpost rack, Apex all-pro rock sliders, OME 2" lift, Mastercraft Courser CXT 255/85/R16 hybrid AT/MT tires, Alpine iLX-107 head unit, Alpine KTP-445A Power Pack speaker amp, Alpine MRV-M500 sub amp, JL Audio Stealthbox with 10" 10TW3-D4 subwoofer, Focal Integration ISS 165 speakers
    I like this idea too. Best of both worlds. Following...
  3. Jan 14, 2022 at 7:54 PM
    RauthBjorn
    RauthBjorn Well-Known Member
    Also following, because I've been looking for one for months.
    At this point I'm looking at buying a DIY kit and modifying it to fit a front hitch that I can weld into the frame attachment points of the bumper. I don't need a winch often enough to justify permanently carrying up front, and a hitch mount allows you to install it in the rear if needed.
    Alternately, if I could get CAD files for a bumper, I could modify and cut it myself on our plasma cutter table at work.
  4. Feb 4, 2022 at 7:37 AM
    heard4it
    heard4it Well-Known Member
    2006 Toyota Tacoma TRD Sport access cab
    Following
  5. Feb 4, 2022 at 7:40 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I wanted a front hitch that wasn’t low, had to make one. Already have a winch on a receiver :D
    gussie, Bivouac, mtip and 1 other person like this.
  6. Feb 4, 2022 at 8:04 AM
    technocardic
    I’d love to see a commercially available front bumper that had an integrated winch cradle that could be removed and swapped to the back when necessary. Seems like a feature that could set one of these fab companies’ bumpers apart from the dozens of similar products. Ideally it would also be crash/airbag compatible.
    5nahalf likes this.
  7. Feb 4, 2022 at 9:19 AM
    RauthBjorn
    At this point I plan on getting a DIY weld kit, likely from Northwest Innovations, and modifying it by cutting a hole in the front beneath the winch plate and welding a 2" hitch into the structure of the bumper.
    I also plan on emailing them and see if they cab add a hole to the plate, should be easy enough since they are cutting the plates out on laser cutting table or similar.
  8. Feb 4, 2022 at 10:56 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    I really liked the look of the SSO bumper, but also wanted a front receiver. Got the bumper thru a group buy here on TW. Found a local welder that did a great job of merging the receiver to it. He added some gusseting too.
    The receiver sits below the winch mounting plate.
  9. Feb 4, 2022 at 11:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I have built a few over the years Not all that hard .
    Everyone has a different idea How they want the design Might be why no Aftermarket are built.
    Build it yourself you get just what you want.
    mtip and six5crèéd like this.
  10. Mar 19, 2022 at 4:27 AM
    Mister Blue
    Mister Blue Member
    Toby
    St Paul MN
    2020 Blue Tacoma TRD Off Road DCSB
  11. Mar 19, 2022 at 5:40 AM
    Bivouac
  12. Jan 8, 2025 at 6:00 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    I bought a raw steel aftermarket bumper and had a fabricator cut out a slot where the winch would been and welded on a 2” receiver. Then he got it powder coated. $600 added to the bumper cost but I also saved on the powder coat. Did this 5 years ago never looked back. Now I’m looking to shed some weight and do it again, bumper needs to be 50 lbs lighter, which won’t be hard as it’s 225 lbs on the front of my truck.
