Front Bumper Removal...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by obz, Dec 13, 2016.
  1. Dec 13, 2016 at 8:43 PM
    obz
    obz [OP] Well-Known Member
    Utah
    2017 Silver Sky TRD Sport 4x4
    I searched a ton on this and was never able to find a definitive answer. For all of you that have removed your front bumper, I could use your help. I need to remove the front bumper cover to get my headlights out. How do I actually remove the cover? Is it pretty straight forward? Any pics or anything to help?
  2. Dec 14, 2016 at 3:26 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    I haven't removed mine but I believe you start by removing grill and the fender flares have to be
    unclipped about a third of their length from the front .
    GaryLaurenLogan likes this.
  3. Dec 14, 2016 at 5:23 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Hmmm you could look up install instructions for aftermarket bumpers. Most require you to remove all that stuff so I'm sure their directions have it. I'll see if I can find something. I try searching for the ARB summit bar instructions and SSO instructions.
  4. Dec 14, 2016 at 5:39 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Ah shit I just realized you are third gen...I don't think any of this will be helpful.
    I have removed my headlights many times, you don't need to remove the front bumper. There are THREE bolts for your headlights though, the third bolt is hidden inside the fender that connects the light and the fenders together. The best way to access this is to go in your fender well and pop out 2-3 of the black liner supports from the front. By removing these supports in the liner, it will give you enough room to move the liner a little bit to the side to gain access to the bolts on the bottom portion of your bumper sides. From there I would unbolt the bottom two bolts that connect the side portion of the bumper to the truck. After you do this, you can slowly pop out the sides of the bumper enough to get access to that pesky third bolt. After I installed new headlights I simply left these bolts off, but do what you want. Anyway the beginning process is to remove the grill with the bolts in the engine bay and getting all the push pins. After that you should be able to wiggle the bottom portion of the grill out as it is connected by six big clips. Also you will have to remove the pieces underneath your headlights before taking the headlights out. Feel free to hit me with any questions, I have my lights to where I can remove them in like 2 min now.
    Coot
    Glaese and JoeCOVA like this.
  5. Dec 14, 2016 at 6:24 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
  6. Dec 14, 2016 at 7:01 AM
    obz
    Utah
  7. Dec 14, 2016 at 7:02 AM
    Marbleyard
    Virginia
    2019 4Runner Pro
  8. Dec 18, 2016 at 6:54 PM
    obz
    Utah
    A couple things that I want to point out for the person that may be doing the same thing I did tonight... First, once you've pulled the bumper you'll notice a few things. The first is why you have to remove the bumper to get your headlight out. The bolt is below:
    Next, once you remove that bolt, you'll notice that the headlight is in a channel that can't be pulled out (this is on the inside of the light - closest to the engine)... took me a minute to figure out why I couldn't get the stupid light out...
    On the other side of the channel, you'll find a plastic rivet that needs to be removed then you can pull the plastic panel out of the way so you can slide the headlight housing off the channel.
    Once done, you can pull the headlight out - repeat on the other side and you end up with this...
    Hope this helps someone else!
  9. Dec 18, 2016 at 6:58 PM
    obz
    Utah
    Oh, also, I busted 2 tabs pulling the fender flares away from the bumper. Be SUPER careful with that crap. If you can, reach under the wheel well and try to push them from the inside. Did not come off smoothly for sure. Gorilla glue to the rescue!
  10. Jun 8, 2021 at 4:06 PM
    Kronan49
    Kronan49 Well-Known Member
    Ronan
    2020 Tacoma Trd Pro 6M
    What holds the front bumper in place? Like the mounting points? My front bumper saved down an inch and wondering what holds it together so I can figure out what I have to fix
  11. Jun 13, 2023 at 7:56 AM
    NjTaco23
    NjTaco23 Active Member
    Did you ever figure this out?
