Front bumper loose
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maiwong, May 22, 2018.
  1. May 22, 2018 at 10:19 AM
    maiwong
    maiwong [OP] Member
    Maria
    2018 Inferno Tacoma TRD Sport
    Hi there,
    I went to Utah this past weekend, and while we were off road I came up on a sand dune a little too fast.
    We noticed that the front bumper is not "clipped" in anymore. We tried pushing it back in, but we're thinking that the clips broke. There are no dents in the bumper.
    Anyone know if this is something we can fix at home? Can the clips be bought and replaced?
    Thanks in advance!
  2. May 22, 2018 at 12:31 PM
    phsycle
    phsycle Well-Known Member
    CA
    You should be able to buy the clips at Toyota. Maybe even a local auto parts store. Just take one out and bring it with you.
  3. May 22, 2018 at 3:07 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    Is it the whole bumper? or just the front cover? In the OR, the front cover is black, I think in Sports yours are color matched. If its just the front cover, that's a bitch to get back in. you prob messed up your clips, which are molded into the whole cover (not replaceable). I speak from experience.
  4. May 22, 2018 at 3:13 PM
    maiwong
    maiwong [OP] Member
    Maria
    I think it's the front cover.
    Where the license plate holder is attached to.
    I can take a picture later today and post it.
  5. May 22, 2018 at 3:26 PM
    vuTron
    SF Bay Area
    yeah if its the front cover, those tabs are molded into the cover itself (not separate piece). Once they are damaged, you're kinda SOL. I too ripped mine off in the dirt. I ended up gluing the piece back into place, knowing that eventually i'll prob get a new bumber. The front cover itself is about $120 to replace from Toyota. good luck.
  6. May 22, 2018 at 3:29 PM
    ajsabra
    ajsabra Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    time for a lo profile/stealth bumper replacement. unless you want to pay $100+ for a replacement plastic piece.
  7. May 22, 2018 at 3:36 PM
    maiwong
    maiwong [OP] Member
    Maria
    Any suggestions on a good stealth bumper?
  8. May 22, 2018 at 5:04 PM
    maiwong
    maiwong [OP] Member
    Maria
    Here's a picture of where the front cover is loose.
  9. May 22, 2018 at 6:52 PM
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    I think if the tabs are not broken it should push/snap back in. My memory is that most tabs are molded and just snap in. There are two tabs at each lower edge that are U-shaped and have separate blue clips that secure them. That bumper piece can be removed to inspect pretty easily and, if still intact, can just be put back on. Those two blue clips are the challenge. I used this video for reference when I replaced mine.
    https://youtu.be/w4zmvqFh4dk
  10. May 22, 2018 at 7:03 PM
    maiwong
    maiwong [OP] Member
    Maria
    We did try to push and see if we could snap it back into place, but it was a no go.
    Thanks for the video link! Maybe I will take the grill off and see if the clips are broken.
  11. May 22, 2018 at 8:12 PM
    Hogan1966
    Hogan1966 Well-Known Member
    Kevin
    Loveland, OH
    2021 DCSB TRD OR - Army Green
    Blackout package - planned: black bed logos, black wheel vinyls, front seat window tint, tires.
    Mine was like that from the factory. They tried to replace the front cover, but the issue is with the actual bumper cover itself The receiver for the tab is broken and the whole bumper cover needs to be replaced
  12. May 22, 2018 at 9:00 PM
    rsimi72
    PNW
    Yikes! That lower valance isn’t the tightest fitting piece ever made but it should snap in tighter than the OP’s. Hopefully it’s the valance clips rather than the bumper that needs replacing.
  13. May 22, 2018 at 10:57 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    The middle portion of those tabs can get bent so they don't go back in.
  14. Apr 25, 2019 at 7:26 PM
    Mile0tacoma
    Mile0tacoma Well-Known Member
    Hank
    Mile zero Alaska Highway
    2019 & 2018 Tacoma
    Mine has level kit, 34" tires, wife's truck is all stock
    I own 2 2018 trucks and they have not been off road, they haven't hit anything, yet both bumpers are doing the same thing. Tells me this is a flaw from factory...anyone take it to the dealership for warranty yet? What was the outcome?
  15. Apr 25, 2019 at 7:34 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    It's completely "normal". Just cheap Toyota plastic and everyone's does it if you search
    Edit yours looks particularly bad, mine doesnt separate from the license plate bracket. Everyone's just separate from the two outside clips
  16. Apr 27, 2019 at 10:44 PM
    Mile0tacoma
    Hank
    2019 & 2018 Tacoma
    Talked to dealership today and they said I must have hit something.another words they ain't fixin. I told them I never hit anything with either truck and no marks at all show that.
  17. Apr 28, 2019 at 3:52 AM
    Resqu2
    Resqu2 Well-Known Member
    Rick
    SW VA
    2018 Tacoma TRD Off-road
    AVS Aeroskin bug shield, TufSkinz tailgate letters, tinted windows, Undercover Ultraflex bed cover.
    SSO Slimline was my choice, love it!
    Mile0tacoma, IEsurfer and Tocamo like this.
  18. Apr 28, 2019 at 3:56 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Off Roading in a Sport??? :D:D
    Just teasing Maria, but what about the Valance underneath. Did it not get pushed up or damaged?
