Front brake pads, should I use lube?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timothom, Jun 11, 2019.
  1. Jun 11, 2019 at 8:53 AM
    timothom
    timothom [OP] Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Got about 50k miles on my 2014 Tacoma, front brakes are starting to make a bit of sound letting me know they need new pads.
    My question is, I have some brake lube left over from a previous job. Would it hurt to use it on my Tacoma? I ordered the OEM Toyota pads for it, I don't think they come with lube.
  2. Jun 11, 2019 at 8:59 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I never use lube, but if you live in a rust state ide highly recommend lubing up the caliper pins with anti seize. Future you will be thankful for that.
  3. Jun 11, 2019 at 9:06 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    I always use lubricants.
    Bleep100 likes this.
  4. Jun 11, 2019 at 9:12 AM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    You should lubricate the caliper pins for sure.
  5. Jun 11, 2019 at 9:29 AM
    timothom
    Are the caliper pins the long bolts that go across and lock the brake pads into place?
    You guys aren't talking about the pistons, right?
  6. Jun 11, 2019 at 9:33 AM
    tntacomaguy
    tntacomaguy Well-Known Member
  7. Jun 11, 2019 at 9:35 AM
    timothom
    Cool. Hopefully can knock this out this weekend.
    I was thinking of sanding the roters with some emary cloth as well... Just to rough them up a bit. I have no vibration at all when braking now.
  8. Jun 11, 2019 at 11:46 AM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    I'd highly recommend m77 molykote, it's a grease that eventually dries out leaving a dry lubrication surface. Honda sells a smaller cheaper tube that can be had at most dealers if you don't want to buy it online. I used it to quiet up my squeaking brakes recently and it's long lasting
    12TRDTacoma likes this.
  9. Jun 11, 2019 at 12:59 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    I used some steel wool on my disc brake rotors.
  10. Jun 11, 2019 at 3:35 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    50k on your brakes and they need replacing? Dayum. Bought this 06 new and when i replaced the pads at 100k miles they still had life.
  11. Jun 11, 2019 at 4:13 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    50K is early for pad wear in my experience, be it a Toyota car or Toyota truck. Then again, you may do a lot of stop-n-go driving. I would pull the wheels and pads and see how much pad is left and make note of their condition.
    Some people says you can observe this looking thru the back side of the wheel, turning it in and out to see both inner/outer pad. . I won't argue that; I just prefer taking it all apart and seeing what I have, all laid out in front of me.
  12. Jun 11, 2019 at 4:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    As others suggest, you may not need pads. And if you do, you should be considering 'why'. If nothing else, just to understand what's going on.
    You may only need cleanup and lubrication.
    Having pads on hand is fine, but you might want to source them from a place easy to process a return if you don't need them.
  13. Jun 11, 2019 at 7:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That isn't the correct image for a 4X4 or Prerunner which uses a fixed caliper.
    That is for a 5 lug base Tacoma with a floating caliper..
  14. Jun 11, 2019 at 8:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you still have life on the pads, and they are clacking around as would expected to be at 50K miles on an otherwise OEM setup, I would remove the pins, line them and then install a secondary pressure retaining spring at the top of the pads. That should keep them from ever being a noisy issue ever again.
    One of these kits will cover both sides for you.
    https://www.amazon.com/Raybestos-H15506A-Professional-Caliper-Hardware/dp/B000R4A3BA
  15. Jun 11, 2019 at 8:01 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I lube the sliding pins, the pistons, the back of the pads and both sides of the anti squeal shims.
  16. Jun 11, 2019 at 8:02 PM
    tntacomaguy
    Didn’t say that it was for a particular vehicle ... just googled where to grease a caliper and used the first picture that shows general areas to put grease
  17. Jun 11, 2019 at 8:04 PM
    Sharpish
    Brian
    Oh and I put a second spring in each caliper recently when I did my brakes, no more clanking.
  18. Jun 11, 2019 at 8:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is what an ideal setup would look like for all fixed piston caliper setups from Toyota from the factory. They don't do this because cheap that's why. Notice the addition of the secondary spring up top.
    Sailor_Nick and CTtoNoVa like this.
  19. Jun 11, 2019 at 8:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Just pointing out that most of those areas do not exist on a fixed caliper brake system.
    KTM753 likes this.
  20. Jun 11, 2019 at 8:17 PM
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    Very Nice...
    Sharpish and 12TRDTacoma[QUOTED] like this.
