Front brake pads & rotors- Toyota OEM part numbers??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by .Q., Apr 25, 2023.
  1. Apr 25, 2023 at 9:11 AM
    .Q.
    .Q. [OP] Well-Known Member
    Stowe, VT
    2013 Tacoma DCLB TRD Sport 4x4
    Hi all,
    Does anyone know the Toyota part numbers for the OEM front brake pads and OEM brake rotors??
    This would be for a 2013 TRD sport DCLB 4x4 with an automatic transmission.
    Thanks!!
  2. Apr 25, 2023 at 9:28 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    winkel and SR-71A like this.
  3. Apr 25, 2023 at 9:29 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    winkel and TnShooter like this.
  4. Apr 25, 2023 at 10:27 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Wish you were a little closer, I have a set of Power Stop rotors and power stop break pads. Brand new in box FS
  5. Apr 25, 2023 at 3:24 PM
    .Q.
    Stowe, VT
    This is perfect info. Very helpful to confirm the part numbers that I already had researched were correct. Thanks guys!!
    TnShooter likes this.
  6. Apr 25, 2023 at 7:37 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Can i ask why you wouldnt look aftermarket when similar quality would def be cheaper and an upgrade probably would also?
  7. Apr 26, 2023 at 7:22 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    I know, 150.00 NIB set of rotors and pads from Power Stop. For 05-15. I think
  8. Apr 26, 2023 at 1:55 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have no shuddering/shaking when you brake, you can re-use the oem rotors. If the shake a little, you can resurface them. I put 60K on my resurfaced oem rotors. Although I think Toyota was using Akebono in my year Tacoma.
  9. Apr 29, 2023 at 8:51 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    I'm turning 60K on my '19 OR and plan to check/replace the front pads this summer. I always replaced pads/rotors in tandem on my Acura RSX (which was hard on brakes). is this generally not necessary on a Tacoma that is currently braking evenly? Would prefer to reuse rotors if thats the norm.
  10. Apr 30, 2023 at 10:13 AM
    Chuy
    Lakeside, CA
    Silver Taco
    @JWestie I can’t speak for everyone else. I generally keep the rotors through two brake pad rotations unless they shudder or they are damaged. I would agree with you to swap out the rotors if you brake hard or if you tow or carry heavy loads.
  11. May 3, 2023 at 8:11 PM
    DailyTacoMD
    Jeremiah
    Last month i paid $175 on RockAuto for Powerstop slotted/crossdrilled rotors with Powerstop ceramic pads. Added another $40 for braided stainless lines. Super happy with it as a budget upgrade.
