Front brake pads are down to 3mm. Best value for light duty daily driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TimberlandSR5, Oct 21, 2015.
  1. Oct 21, 2015 at 6:41 PM
    TimberlandSR5
    TimberlandSR5 [OP] Member
    Southern PA
    SR5 2.7 4wd
    Hey guys, I've done a lot of reading here, and it seems many people are going with performance kits. I do a lot of highway driving and do not drive aggressively at all. Just looking to get something quality that will last a long time. I don't necessarily need performance and do not want to pay extra for it. Should I just go to advanced/auto zone? Should I buy new rotors (75k, first set of new pads)? Do "OEM" recommendations include OEM replacement (advanced house brand for example)? Thanks in advanced!
  2. Oct 21, 2015 at 8:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    OEM Pads.
    Lester Lugnut likes this.
  3. Oct 21, 2015 at 8:10 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    OEM pads.
  4. Oct 21, 2015 at 8:13 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pads and slap some rotors on that Bitch.
  5. Oct 22, 2015 at 3:13 AM
    TimberlandSR5
    Southern PA
    SR5 2.7 4wd
    Where to buy OEM pads? And do you guys mean Toyota brand, or just OEM replacement? What rotors, and are they needed? My breaking now is perfectly smooth. Thanks!
  6. Oct 22, 2015 at 4:00 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    OEM means get them from a toyota dealer parts department
  7. Oct 22, 2015 at 4:03 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    Rotors are pretty much rotors no matter what brand you choose. I just about always use OE Toyota pads on my trucks because pads vary greatly in how you're going to stop and how the pedal is going to feel. Last time I was broke and bought advanced auto rotors with a 30% off coupon and some Bosch quietcast pads. I actually like the pedal feel and bite of the Bosch pads better than OE. But they do get hot quicker when the truck is loaded so I don't think I would want to tow with them.
  8. Oct 22, 2015 at 4:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Toyota pads sound right for you.
    We can't tell if you need rotors or not. Mileage isn't the key as much as what the rotor looks like.
    However, with that mileage on original equipment, I suspect your rotors are in fine shape; they typically last 2 sets of pads.
    Just be sure you bed the new pads properly, as well as clean and lubricate all the exposed moving parts while you are in there.
    You should also clean, lubricate and adjust the rear drums.
    You don't tell us the year of your vehicle, but its likely it's time to change your brake fluid as well. While it's up on stands and you have everything apart is a great time to do it.
  9. Oct 22, 2015 at 4:55 AM
    TimberlandSR5
    Southern PA
    SR5 2.7 4wd
    Thanks for the help. I left out that it is a 2010. I do a lot of travel for work which means lots of long highway travel with minimal braking. I also tend to follow pretty far back and slow down with the motor when possible. Very non-aggressive driving style.
    What does bed the new pads refer to?
  10. Oct 22, 2015 at 5:21 AM
    Clearwater Bill
    Billy
    Largo Florida
  11. Oct 22, 2015 at 5:37 AM
    TimberlandSR5
    Southern PA
    SR5 2.7 4wd
    Sounds easy enough. Thanks
  12. Oct 22, 2015 at 8:07 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OEM.
    hit up @gunny1005 he works for camelback toyota (out in arizona) and can get you probably the best deal on OEM parts.
  13. Oct 22, 2015 at 8:35 AM
    TimberlandSR5
    Southern PA
    SR5 2.7 4wd
    Thanks, do I have time to wait? Dealer measured 3mm on one side and 4mm on the other, which is the "address immediately" range. Do I have a couple weeks of ~1k miles/month to wait for something to ship?
  14. Oct 22, 2015 at 9:07 AM
    nd4spdbh
    SoCal
    yeah you are fine.... fyi camelback toyota gets stuff out quick, should be less than a week for some pads.
  15. Oct 22, 2015 at 9:14 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    If you're replacing with OEM pads at the dealer, just have them price match camelback's.
  16. Oct 22, 2015 at 9:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hopefully you are doing the work yourself? Taking pads to a dealer to install will just get you a list of other stuff they want you to do.
    And yes, the way you drive the measurements are fine for 1k, likely more.
  17. Oct 22, 2015 at 10:31 AM
    TimberlandSR5
    Southern PA
    SR5 2.7 4wd
    I appreciate all the help guys. I will be doing it myself with the help of a very mechanically inclined friend. Dealer wanted 300 (oem, fronts only, with rotor resurface) and they're usually very reasonable.
  18. Oct 22, 2015 at 10:35 AM
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    If you can get your local Toyota dealer to price match great, if not let me know and I can see what I can do for you. A good local dealer should price match. Also dont forget to turn your rotors, they may squeel afterwards if you dont.
    Revelations likes this.
  19. Oct 22, 2015 at 10:37 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    I vote sparks toyota
    they are great at ordering partz on the intertoobs
  20. Oct 22, 2015 at 11:59 AM
    Revelations
    2014 MGM DCSB
    Yep, always turn rotors when changing pads.
