Front bed header rail install.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eurowner, Apr 20, 2022.
  1. Apr 20, 2022 at 6:17 PM
    eurowner
    eurowner [OP] Duke Sky
    Scoty
  2. Apr 20, 2022 at 6:28 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
  3. Apr 20, 2022 at 6:30 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’m trying to remove the front rail out of my 6 foot bed. I destroyed one screw head. I guess it’s on there forever.
  4. Apr 20, 2022 at 6:34 PM
    CrispyTacoLover
    The factory guys are idiots. They definitely put the screws in too tight.
  5. Apr 20, 2022 at 6:40 PM
    eurowner
    Scoty
  6. Apr 20, 2022 at 6:51 PM
    eurowner
    Scoty
    Trivial to lift my shell or not?
  7. Apr 20, 2022 at 6:52 PM
    CrispyTacoLover
    I wouldn’t know if that is required. The rail install without the shell is easy.
  8. Apr 20, 2022 at 6:55 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Show us a picture of the cab end of your truck bed. If the end is covered then yes, you have to lift it.
    If you can see the T30 screws, then no. All you do is remove the screws, place rail, replace screws. End caps to the rail would be nice but not included, not worth getting imo. Enjoy having more utility.
    eurowner[OP] likes this.
  9. Apr 20, 2022 at 6:59 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Actually it is the cheap fasteners Toyota uses. Take for instance most everyone that has put a Meso Gasshole on the inside of the gas door has swore the factory put the screw that holds the gas door clasp on in to tight. Actually it is the fact the threads are rusted in the female threads or the female threads are close to rusting and are corroded. I found this out when I went to take my Gasshole off and replace it with a gas cap cradle. I had to use a small pair of Vise-grips to get the screw out. the threads on the screw where it mated with the female threads was rusted. I replaced the screw with a stainless steel screw which I should never have to take out.
  10. Apr 20, 2022 at 7:12 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    If you can remove all 5 existing bolts without a problem, you'll do fine without lifting the cap.
    I have one for my '21 TRD waiting to be installed when work and the honey-do list stops getting in the way. I bought 316 stainless bolts & washers for mine. The washers are spacers for behind the rail because I anticipate tight clearance when using the OEM moveable tie-off brackets.
  11. Apr 20, 2022 at 7:21 PM
    Merling
    James
    NH
    Shouldnt you have the same clearance as with the other rails with the oem fasteners? Its a 2 minute install
  12. Apr 20, 2022 at 7:39 PM
    eurowner
    Scoty
    Excellent pertinent information! I do see the OEM hardware.
    Merling[QUOTED] likes this.
  13. Apr 20, 2022 at 7:40 PM
    eurowner
    Scoty
    :facepalm:
  14. Apr 20, 2022 at 7:41 PM
    eurowner
    Scoty
    :bowdown::cheers:
  15. Apr 20, 2022 at 7:48 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    The torx screws are cheap and strip easily, so don't bang on them with that mega impact gun. While you have them out, hit the threads with some anti-seize.
  16. Apr 20, 2022 at 8:16 PM
    CT Yankee
    CT
    Agree that it's a 2-5 minute install if all goes well.
    I compared the side rail clearance (for the tie off brackets) from the bedside cap to the front. The front cap appeared to be closer to the rail. Won't know for sure until I get it installed.
  17. Apr 20, 2022 at 8:20 PM
    CrispyTacoLover
    Lol
  18. Apr 20, 2022 at 8:44 PM
    Tacomike18
    J
    Also these bolts are m6x1.0 10mm heads I believe.
  19. Apr 21, 2022 at 7:03 AM
    Merling
    James
    NH
    You can put a front molle but I went with the rail too. I would say go for it. Takes two minutes. I loosen the nuts by hand then use my electric ratchet once I break em free. What are you gonna use it for? Mine holds my recovery boards which has been like almost zero space used up that way
  20. Apr 21, 2022 at 7:16 AM
    eurowner
    Scoty
    I have ATH front bed corner brackets and a few accessories brackets to hold two rotorpax jugs and looking into traction boards to mount there (may not have enough room).
