Front axle won't come out!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsouth, Jul 6, 2014.
  1. Jul 6, 2014 at 9:01 PM
    dsouth
    dsouth [OP] New Member
    STL
    06 Access Cab 4X4
    5100's, homemade Satoshi grill, CAI, Catback System, Derped stuff
    Ok guys, I've read all I can about the needle bearing and the removal of the cv axle, boot replacement, and anything to do with the front end. I've now had 3 failed attempts at removing the axle. I've tried the cable and sledgehammer( broke the 200lb cable twice) tried slide hammer with 1 clip and a hose clamp( didn't move) bought a CV puller for the slide hammer, didn't work either.
    Has anyone come across this? Any ideas why it won't release?
    Thanks in advance.
  2. Jul 6, 2014 at 10:22 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I use a metal punch to pop it loose and then the pry bar to get it out the rest of the way.
    Be careful not to damage the metal seals on the CV axle as you pry it out.
  3. Jul 6, 2014 at 10:26 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    pry bar took like 5 minutes for both sides
  4. Jul 7, 2014 at 6:02 PM
    dsouth
    STL
    06 Access Cab 4X4
    I stopped by a shop today, that has a few Tacoma guys, and he mentioned the punch through the diff from the passenger side. I guess I'll be trying that next....
  5. Jul 7, 2014 at 6:37 PM
    tacoma4
    tacoma4 Well-Known Member
    How can you punch it through the diff without removing the other axle first? Cable trick did it for me, but sounds like yours is pretty stuck.
    Also, I'm in St Louis too, what shop has Tacoma guys? Haven't been too happy with the places I've been so far for alignments.
  6. Jul 7, 2014 at 6:45 PM
    Large
    Large Red
  7. Jul 7, 2014 at 6:51 PM
    bzzr2
    bzzr2 Well-Known Member
    so much help, awesome post! haha shat, now i'm posting useless crap too.
    bigmw likes this.
  8. Jul 7, 2014 at 9:46 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    FWIW, there is supposed to be a sweet spot when you are using a pry bar. Pry, rotate the axel 1/6 turn, and repeat till you find the sweet spot. I didn't know this, pryed like mad without turning, and couldn't budge it. The slide hammer with hose clamp worked for me. Good luck.
    Crazydave4x4 likes this.
  9. Jul 8, 2014 at 8:52 PM
    dsouth
    STL
    06 Access Cab 4X4
  10. Jul 9, 2014 at 2:15 AM
    gearcruncher
    Canadain bumper technician
    It helps if the axle is as straight as possible both for removal as well as installation . If there is any side loading on the axle while trying to remove it , its not going to come out . Needs to be straight and relaxed in order for the retention ring to collapse properly .
    You may have a retention ring groove that is worn down or the retention ring is having issues trying to collapse .
    bigmw likes this.
  11. Jul 9, 2014 at 4:03 AM
    Large
    Large Red
    Thanks I try. Just reiterating the pry bar, worked like a charm for me.
