Fridge... what one?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scott17818, Feb 26, 2021.
  1. Feb 28, 2021 at 8:45 AM
    PilotMM
    PilotMM Well-Known Member
    Las Vegas
    '17 TRDOR DCSB
    RLD Canopy, Icon Stage 4 plus RXT leaf
  2. Feb 28, 2021 at 9:17 AM
    Scott17818
    Scott17818 [OP] Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    The larger one is similar to what I am looking for don't need a freezer all the time, but it is a nice option.. little pricey though, and I assume the fridge temp isn't settable like the true dual zones are.... its freezer & the fridge gets what cold air leaks through the divider.... until you remove the divider.... the power consumption looks great though... .75a up to 3.5 max...
  3. Feb 28, 2021 at 11:45 AM
    PilotMM
    Las Vegas
    '17 TRDOR DCSB
    I think you are right about the fridge freezer operation. But yeah, .75-3amps. My plan is to power it from a LiFePo4 battery so if I can get 1.5 amp average that’s 53 hour run time without charge :eek:
    -M
  4. Feb 28, 2021 at 1:16 PM
    PuckerbuttPliny
    PuckerbuttPliny Well-Known Member
    California
    2018 TRDOR 4X4 DCLB
    275/70r17 KO2 E Load 4R TRD Pro Rims
    Love my Dometic CFX3 75Dz. Like others have said, if you’re running the small side as a freezer, and the larger as a fridge, I’ve seen as high at 2.75 amps/hour. I run mine off a goalzero 1500, so the power drain is fine. However, are you always going to have a freezer running? I ask because I didn’t think about the fact that a fridge doesn’t need room for ice (yeah I know, really fudged that up). So if you’re going for a 1:1 size comparison on the fridge vs cooler, you’ll probably find yourself with significantly more room in the fridge than you need, and a higher power draw.
  5. Feb 28, 2021 at 1:20 PM
    Shellshock
    Iowa
    Yup for sure. A 60l cooler is really 30l of usable space. Unless you are traveling with a huge group or months at a time, people can use a smaller fridge.
    the other thing is if you have a single zone fridge, it’s typically colder in the bottom so I’ll put frozen stuff in the bottom and stuff I don’t want frozen at the top.
  6. Feb 28, 2021 at 1:28 PM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I’m in the same planning boat as you. And I’m also planning to spend some quality time in the north Maine woods this summer. Haven’t been back since moving out of there in ‘08. Can’t wait!
  7. Mar 24, 2021 at 8:42 AM
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    Check out the Alpicool app. It's compatible with the Massimo fridge.
  8. Mar 24, 2021 at 10:14 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    As far as I know the Massimo doesn't have any wifi or bluetooth...
  9. Mar 24, 2021 at 2:09 PM
    mikeaesq
    TRD Off-road 4x4
  10. Nov 14, 2021 at 12:32 AM
    Blue Unicorn19
    Blue Unicorn19 Member
    Georgia
    2019 Voodoo Blue Tacoma TRD Pro A/T
    Diamondback SE Tonneau Cover Westcott Designs Fox TRD Pro Lift Kit 17x9 -12 offset Fuel Ripper Wheels 285x70r17 Nitto Trail Grappler M/Ts CBI Covert Front Bumper w/Bull Bar Smittybilt X20 10K Winch Runnin4Taco LCA skids CBI Rear Skid Plate CBI Gas Tank Skid RCI Differential Skid White Knuckle Rock Sliders Rigd Ultraswing Tire Carrier Prinsu Roof Rack UpTop Overland Diamondback Truss Mount Bed Rack Tuffstuff Overland Alpha RTT Roam 4' Awning CaliRaised 30" light bar CaliRaised 42" light bar CaliRaised Low Profile Ditch Lights Deaver U402 Stage II Leaf Pack
    So you are able to fit an ICECO fridge under the Diamondback SE? I'm looking at the ICECO VL60D.
    imjustabill1970 likes this.
  11. Nov 14, 2021 at 1:24 AM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    When I had
  12. Nov 14, 2021 at 2:45 AM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    I'm running a vl45 from iceco. Battery is a single optima yellow top 55ah, I've left it as long as 38 hrs without a crank and no issues. Temp was set at 36. Now I have a cascadia 4x4 solar panel on the hood and everything is cherry. I never worry about it dying now. I use my fridge every day of the week for lunch at work, snacks, etc etc. I also use it for weekend trips. It stays on 24/7
    Zacoma77 likes this.
  13. Nov 18, 2021 at 7:35 AM
    imjustabill1970
    imjustabill1970 Twitter: imjustabill1970
    bill
    clarksville, tn
    2017 TRD Off Road DCSB
    SUSPENSION: Icon Stage 4 with tubular UCAs WHEELS: Black ProComp 69 TIRES: BFG KO2s at 265/75/16 Partially debadged Diaz Fabrication Model T up front
    I'm curious about this too. Very interested in a Pull Kitchen, but also need a fridge (also on a slide out). Figured the Diamondback SE would be a good way to keep them both protected.
    Will eventually have a mid-height bed-rack so a full on shell isn't an option.
  14. Nov 18, 2021 at 12:32 PM
    _Shay_
    _Shay_ Well-Known Member
    2020 Cement Tacoma
    Are you using a dual battery setup?
  15. Nov 18, 2021 at 12:42 PM
    #35
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    No sir
  16. Nov 19, 2021 at 6:58 AM
    #36
    imjustabill1970
    bill
    clarksville, tn
    I was able to find out that the Dometic 75 Dual Zone fits under the Diamondback SE...not sure about the ICECO.
  17. Nov 19, 2021 at 9:18 AM
    #37
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Maybe without the slide? My Iceco VL35/45 (the expandable one that they no longer make, ha) fits on the slide just fine. But that's in the VL35 configuration.
  18. Nov 21, 2021 at 5:24 PM
    #38
    _Shay_
    2020 Cement Tacoma
    I'm relatively new to the scene, but how do you run solar without a dual battery? I'd like to do the same thing.
  19. Nov 21, 2021 at 6:51 PM
    #39
    codyjphoto
    Cody
    2015 gx460
    A bunch of junk
    The cascadia solar, or any other solar runs to the charge controller and that to the battery. Basically it is doing its thing 24/7, especially when I'm not driving around.
    During the day of my truck sitting at work, it's indicating 13.4 v and that's thanks to the solar panel.
    Zacoma77, imjustabill1970 and JDSmith like this.
