Free PDF Fault Code Sheet .... Help Needed!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seligman, Jul 8, 2010.
  1. Jul 8, 2010 at 6:08 PM
    seligman
    seligman [OP] Well-Known Member
    I'm a graphic designer by day, so I decided to create a list of fault codes to keep inside the glove box. If something goes wrong, I'd like to know right away what the fault code is telling me. This is intended for ScanGaugeII users in mind. Sources are Factory Service Manuals, www.obd-codes.com, other websites.
    Help Needed: I need help with the Toyota-specific fault codes, particularly the newer ones. Corrections or suggestions are welcomed too.
    Sample image here. Full PDF printout is attached.
  2. Jul 8, 2010 at 6:09 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
  3. Jul 8, 2010 at 6:14 PM
    seligman
    There's a boatload of Toyota-specific codes missing from that list. Notice it only goes as high as P1780, I have probably fifty more higher in number.
    This is why I need help identifying them.
    Thanks!
