Frame Rust Fix, What Works Best?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tjsingle26, Mar 22, 2015.
  1. Mar 22, 2015 at 9:37 PM
    Tjsingle26
    Tjsingle26 [OP] Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey All,
    I am sure some of you have seen my previous threads about my truck, and I had a few additional questions, and I figured it would be better to start a new thread.
    So my problem is that I have surface rust on my frame in two main areas. The first being the top of the frame rail on the drivers side, see picture.
    The second is behind the shackles at the end of the frame, which isn't all that bad, just scale and surface rust.
    Overall my trucks frame is in good condition. I have performed the frame test with a hammer about two or so weeks ago and I had no soft spots, or perforations. I have concluded that the majority of my rust is surface with minimal inner frame rust from checking drain holes and other access points to the inside of frame.
    I have also checked common week points in the 1st gens such as the frame rails, and the leaf spring mounts very thoroughly with a hammer, and by checking the inside of the frame.
    From my experience in the engineering field I have not found any weak points in the frame that should cause concern, but i have narrowed down my problem to the surface rust and scale.
    I have seen many different approaches to tackling rust issues before they turn into frame rot, and subsequent failure and I wanted to know the best ones out there.
    My original plan was to,
    1.)Wire wheel loose rust off frame
    2.)Wash frame after the wire wheel to remove dirt, dust, etc
    3.)Apply Rustoleum Rust Reformer on the frame
    4.)Top coat frame with Rustoleum chasis paint.
    5.)After Top Coat has dried, use Eastwood Internal Frame coating to coat the inside of the frame.
    After reading thread after thread of many different products used, I am unsure of what to really use at this point and with the weather getting warmer I would like to take care of this rust soon.
    I am considering using Eastwood rust encapsulator followed by chasis black..
    Feedback and suggestions would be much appreciated!
    Thanks
    The lizard likes this.
  2. Mar 23, 2015 at 3:46 AM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    Sounds like a good plan. Similar to what I did.
    Wire Brush
    Rustoleum Rust Reformer.
    Then took 4 parts Mineral Spits and 1 Part Rustoleum mixed them together
    in a Garden Sprayer. Sprayed everything under vehicle except exhaust. Used brush
    to catch any drips. Also sprayed up over the inside of the fenders and took out the plugs behind the cab and shot into there. The flexible wand was also able to shoot inside the box part of frame. I plan on doing this every spring after a good blast with my Power washer.
  3. Mar 23, 2015 at 8:50 AM
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  4. Mar 23, 2015 at 12:51 PM
    Tjsingle26
    Tom
    PA
    So the proper method or step by step would be to
    1.) Wire brush loose rust off
    2.) Degrease
    3.) Rust Encapsulator/Rust Converter. Not sure which to use?
    4.) Top Coat
    Correct me if im wrong
  5. Mar 23, 2015 at 1:54 PM
    Tjsingle26
    Tom
    PA
    How has it held up?
  6. Mar 23, 2015 at 1:59 PM
    bighouse01
    bighouse01 Well-Known Member
    NY
    04 DC TRD
    Sandblasting is best. There is an attachment from northern tool that hooks up to your gas pressure washer that will siphon sand and blast with no dust. You could easily pull the bed for great access to at least the rear 1/2.
  7. Mar 23, 2015 at 2:23 PM
    Tjsingle26
    Tom
    PA
    That definitely seems like a very effective method. I mean I guess the main thing is that is tripping me up, is what is better to use encapsulator, or converter? Encapsulator would prevent the rust from getting oxygen and moisture. But the converter would simple get rid of the rust, and convert it to a surface I could topcoat.
  8. Mar 23, 2015 at 2:32 PM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Why not blast, POR15, then topcoat?
  9. Mar 23, 2015 at 2:47 PM
    Tjsingle26
    Tom
    PA
    I most likely will. I just need to figure how much I need to do the whole frame. I dont think I have the means to sand blast it though
  10. Mar 23, 2015 at 4:20 PM
    Sin
    Superior, Wisconsin
    I'm happy with it. Its gone through two winters and I've resprayed it twice.
    Will try and get a pic for ya....Ok bad pic, its pretty dirty under there. I'll be power washing it and respraying it again soon.
    When I purchased the truck a couple of years ago the truck had a lot of surface rust all over the frame. Although it did look like it had some kind of black factory coating.
  11. Mar 23, 2015 at 5:24 PM
    Tjsingle26
    Tom
    PA
    Okay guys, So I am posting better pictures of my trucks frame
    More surface rust on the drivers side for whatever reason. The passengers is a lot cleaner. But I did notice that I had some inner rust near the leaf spring mount and had kind of freaked out... I know thats a bad spot to have rust. But I took a screw driver and tried to see if it would give at all. Luckily it is just surface scale.. My truck is structurally sound but these forums with all the horror stories make you worry more haha.
    Basically, after performing the Toyota TSB, by hitting the frame with a hammer all over I was not able to find any soft spots on the frame. Which is good. But I do however have frame rust and scale at several portions of the frame. In some places more serious then others. See pictures...
    Drivers side top of frame rail
    Drivers Side bottom of frame rail
    The other side of the frame looks the same. The inside of this portion of the frame is rust free.
    Rear Drivers side- Leaf Springs
    Rear Drivers Side
    Passenger side rear
    This spot was very concerning for me, but this is where I tested the frame with a screwdriver and a hammer. No structural defects or weakness. Inner rust is scale.
    Passenger Side middle of frame
    Like I said before I have no doubt in my mind that the trucks frame is safe and structurally sound. But that does not change the fact I have frame rust, that needs to be addressed. Unfortunately the original owner was a dummy and never took the truck in to be sprayed. So I cant get a new frame ever. But I don't think it would matter regardless because the warranty for me would have been up in three years and my truck is no where as bad as others I have seen.
    I have experience in the engineering field particularly structural engineering and I have seen the affects of rust on steel rebar in structures and how bad it can be. And in my opinion my truck has rust not rot. My truck would pass inspection at Toyota, and I think that with proper rust treatment I can extend the life of my truck for several more years.
    PS: The leaf springs have bright orange surface rust because they were install over the summer, and I didnt think I would have to top coat them...
  12. Mar 23, 2015 at 6:41 PM
    bighouse01
    NY
    04 DC TRD
    OP- your frame looks great. But its time to nip it before the rust really takes off. I've used all the above. Eastwood had hope. The converter turned a pretty purple when applied to am axle housing. but months later the paint peeled exposing rust like the converter was never applied. Por-15 isn't what it used to be either.
    You need to blast. Apply an acid etching primer followed by a primer sealer and finally a topcoat. Automotive refinishing process. I just did mine- insides the tubes and out. I disassembled the whole truck. Blasted the frame in and out and my topcoat was a 2k hot rod black urethane on a rotisserie. That would be a #1, top notch repair. I'm a little nuts.
    The truck in my pic is a friends 2500 GMC. He blasted then used tractor supplies version of rustoleum etching primer and followed with with their satin black. It came out nice and still looks good. A #2 job after what was described above. I would recommend this process for most people.
    If you don't get all the rust off. The iron oxide left behind(darker harder rust) holds moisture and will just fester under your new pretty paint. Do it right and do it once. You'll be happy you did.
    Oh and after your all done. Apply 3m rustfighter inside the frame with a rustproofing wand. Its a wax coating that shoots 360 degrees out of the nozzle. Eastwood has a similar internal coating. Don't skimp.
  13. Mar 23, 2015 at 6:49 PM
    Tjsingle26
    Tom
    PA
    Thank you for the awesome advice. I myself am a little bit nuts as well, stress from school turns into stress over things like my truck... I have some choices to make regarding product specifics, but the common theme is prep is EVERYTHING.
  14. Aug 12, 2015 at 4:07 PM
    Quba
    Quba Member
    1998 Black Tacoma 4x2 Manual
    OP - Do you have an update on the route you chose? I recently got a great deal on my first Taco. The body is super clean (few dents but no rust anywhere) though the frame has some surface rust I'd like to address. Currently trying to figure out my best option.
  15. Aug 12, 2015 at 4:59 PM
    Tjsingle26
    Tom
    PA
    Hey, I used KBS rust seal I had great results.
    https://www.tacomaworld.com/index.php?threads/KBS-Rust-Seal-Review-(Picture-Heavy).374144/
    With the right prep work it'll go on any surface. Let me know if you have any questions regarding the product
  16. Aug 13, 2015 at 7:57 PM
    Kevlar
    Kevlar Well-Known Member
    Kevin
    03 tacoma double cab, v6 4wd
    Fluid film. It may not give you a pretty black paint job but this stuff works awesome!
    unbrokenchain likes this.
  17. Aug 14, 2015 at 10:20 AM
    53rdcard
    53rdcard Well-Known Member
    2004 Black Tacoma SR5 4x4 3.4v6
    Im in the same boat, though mine was a free 2k4 from my brother in law who inherited a 2012 from his father, so he passed on his to me, but he had been living down in tn, truck was here as well and sitting for years due to a limb that hit the roof and broke a window, he was taking care of his father during that time, and still is so he didn't need to drive his truck as the fathers was already his, his old one got repaired and now is mine, but it needed a lot of small stuff, i did all that myself.
    last thing is the frame, im solo on the repairs, and don't have the kind of setup that i would need to do things like lift the bed off the frame even, or more to the point i could get it off, but not back on.
    so mine is going to be a frame on truck job, not the best solution but its what i have to work with, good news is, i tested a small patch of it and got it to bare metal really fast, and have tested with a hammer alll parts of it nothing showed any issues.
    i found these 2 threads benificial in choosing what to do and use
    https://www.tacomaworld.com/threads/frame-restoration-did-it-myself.368199/page-3#post-10565184
    https://www.tacomaworld.com/threads/kbs-rust-seal-review-picture-heavy.374144/
    im just waiting for the temp to go down to get started on it, it is way to hot outside to do this kind of long time frame work when covered head to toe in a plastic suit for hours.
    i went with the kbs system, got 2 kits, they say it will only take one, but i also only wanted to do it once, and dont want to have to stop and redo anything cause i ran out of anything, i got the eastwood interior frame rust encapsulator spray in green so i could easily see when or if rust ever started showing through again, and already had a camera scope from something else that i will use to check the rust inside it, trying to find something i can use to brush out the inside parts of the frame, something like a chimney brush or something like that maybe
  18. Aug 14, 2015 at 10:22 AM
    Tjsingle26
    Tom
    PA
    I used one KBS system. It worked well. I didn't wear a tyvex suit when I did it, I worked outside though so it wasn't bad. I also used KBS cavity coater, it's the same idea as east woods.
  19. Aug 14, 2015 at 10:29 AM
    53rdcard
    good to know, i havent ordered the 2nd kit yet so that saves me some cash, did you have much left over after 2 coats?
  20. Aug 14, 2015 at 10:34 AM
    Tjsingle26
    Tom
    PA
