Frame rivets
Discussion in 'Technical Chat' started by ilikedoggos, Aug 10, 2019.
  1. Aug 10, 2019 at 10:05 AM
    ilikedoggos
    ilikedoggos [OP] Member
    Keith
    '06 DCLB Prerunner V6
    i’m in the process of de-rusting my frame and i’m wondering if anyone has cut the rivets to get the rust out from between where toyota laminated another piece inside the frame to “reinforce” it. Think it’d be okay to lop em off and just replace them with grade 8 bolts?
  2. Aug 10, 2019 at 10:07 AM
    ilikedoggos
    Keith
  3. Aug 10, 2019 at 10:10 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    I wouldn’t. Unless you are going to somehow pry the whole frame apart it won’t be worth the effort anyway because you won’t get all the rust. I’d get the flakes at the edge the best you can, using a needle scaler if you have a compressor, then shoot a bunch of something like Eastwood internal frame spray up in there then let cure and fire some fluid film on top of that and call it a day.
    Eastwood Internal frame spray is super thin and will get into most cracks and crevices. The fluid film on top (or similar product) will be a final protectant layer.
    Hypothetically if you do select to do your cut the rivets and use bolts, you need to select something as close if not same as the frame material, otherwise now you’ll deal with galvanic corrosion.
    Bishop84 and GQ7227 like this.
  4. Aug 11, 2019 at 2:20 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If that is your truck in the picture you have your work cut out.
    Just where does that truck live??
    GQ7227 likes this.
  5. Jan 6, 2020 at 9:25 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    where!
  6. Jan 10, 2020 at 5:34 PM
    scs_vuth
    scs_vuth SCS sales rep
    Vuth
    Bay Area, Ca
    2013 Tacoma - 2020 GX460 - 2022 Jeep Gladiator EcoDiesel
    You can grind off the head and punch it out the opposite end.
  7. Jan 14, 2020 at 7:17 PM
    ilikedoggos
    Keith
    It’s been around but has spent most of its life in bc on the coast so the salt in the air didn’t treat it well but i ended up just cutting all the rivets and prying that piece out to get the rust finally
  8. Jan 14, 2020 at 7:21 PM
    Bishop84
    Bishop84 Well-Known Member
    I wouldn't. Jdevtec has some really strong points.
    Also the rivet is a completely different force of fastener to a bolt. The tension will not be enough, nor consistent.
