Fox vs Elka coilover lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by steviek121, Apr 12, 2020.
  1. Apr 12, 2020 at 8:26 AM
    steviek121
    steviek121 [OP] Member
    2020 Black Tacoma TRD Off Road
    Ok so I'm looking for some advice and or recommendations on these two lifts. I have a 2020 trd off road that I'm looking to put a 3 inch lift on. I feel like I have it narrowed down to these two complete kits from headstrong off road. First is the fox stage 3 which includes 2.5 fronts with resi, 2.0 rears with resi, hs add a leaf, and spc uca for $2,781. Second is the elka stage 2 kit with 2.5 front and rear non resi, hs add a leaf, and camberg uca for $2,839. Both kits are close in price so cost isn't much of a factor in the decision. My usage for the truck at the moment is about 90% street 10% off road, which might change but will remain my daily so road manners are key. With my limited and light off roading do I really need the reservoirs? And as far as the rear which is better a 2.5 non resi or the 2.0 resi? Also I'm from the East coast so rust can be an issue. I'm just trying to buy once cry once so any help is greatly appreciated. Thanks!
  2. Apr 12, 2020 at 8:28 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    @jberry813 you are familiar with Elka Products.
  3. Apr 12, 2020 at 8:46 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That's a lot of coin to drop on a suspension when you don't even know what you need, add to the fact you are 90% on road which tells me the few times you are offroad are general forest service roads or dirt roads. For that price I wouldn't recommend either.
    "With my limited and light off roading do I really need the reservoirs?" Thats a question you have to answer; do you experience shock fade, are your shocks overheating? I'll guess No.
    "And as far as the rear which is better a 2.5 non resi or the 2.0 resi?" Same as above, do you need a 2.5 body shock for the extra oil? Another guess, probably not.
    You may be better with a Bilstein kit, but your money.
    I highly recommend not buying online either. IF you buy online you pay the full price or MSRP, you can typically call a vendor and get 10-15% off what is advertised online.
  4. Apr 12, 2020 at 8:59 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Drive offroad with the suspension you have first. If you like it, get Bilstein 5100s with OME springs. For the type of offroading you describe it'll be good. the 5100s have similar damping properties as the stock shocks so ride will be similar, but you'll get the lift.
    If you find the ride deteriorates and overheat then get 2.0s. Reserviors and/or 2.5 are probably going to be overkill for what you described.
    71tattooguy and JoeCOVA like this.
  5. Apr 12, 2020 at 12:21 PM
    HeritageTRD
    HeritageTRD Well-Known Member
    Washington
    98 4runner 3.4 V6 5spd MT Anthracite Metallic
    265/75/R16 BFG KO2's on Akuza 359 wheels - Sport Hood Conversion - Trail Gear 60" Rock Sliders - Rola Roof Rack - Custom Front Recovery Points - Hella 500 fogs - Flowmaster 50 series - Smoked Tails - Clear Corner & Turn Lenses - 5% Tint - GT Exact Seat Covers - Kenwood DVD & Alpine Speakers.
    Appearantly they (Elka) have introduced a new lower level recently....hmmmm...$700 bucks less expensive sounds tempting for a lite duty offroader. I have been planning on the Elka if 2.5's when I get my truck in a few months. One thing I noticed over the 2.0's is the 2.5's are extended travel. If you're wanting to push closer toward 3" of lift like I am, the extended travel should leave you with more down travel left in your shock at ride height I believe. I also believe the ride quality around town and wash boarded fire roads will be better on the Elka vs. Fox because of the valving. At least thats what I've concluded based on what I've read...
    steviek121[OP] likes this.
  6. Apr 12, 2020 at 12:35 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    If you have the spare money, go for it. I had the cheap 2” lift Bilstein and OME setup for about a year. I just upgraded to a Fox 2.5 shock setup and the ride comfort is night and day. I had no idea how bad the old suspension actually was until I got the new one.
    If you can afford to get the best suspension and you want a soft and plush ride on the highway and offroad, go with a 2.5 coilover and shock system. There is no cheap suspension that can compare. There’s a very big difference.
    Just my personal opinion.
    Check out the suspension thread. You’ll get much more info in there.
    https://www.tacomaworld.com/forums/suspension.18/
    Welcome to TW!!!
  7. Apr 12, 2020 at 12:36 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    Where did you see this at? Gotta link? I just looked at the Elka website & find no hint of a cheaper product.
  8. Apr 12, 2020 at 12:43 PM
    HeritageTRD
    Washington
  9. Apr 12, 2020 at 12:50 PM
    1taco2motos
    Colorado
  10. Apr 12, 2020 at 12:51 PM
    HeritageTRD
    Washington
    Haha....one can dream
    1taco2motos[QUOTED] likes this.
  11. Apr 12, 2020 at 1:28 PM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Apr 13, 2020 at 8:18 AM
    Sandman TRD
    Sandman TRD Well-Known Member
    Indy
    2018 Black DCSB TRD Off Road 4x4
    I was pretty much set on the 6112/5160 combo but now the Elka 2.0 has my attention. Any real world reviews or experience out there yet on a Tacoma?
  13. Apr 13, 2020 at 8:40 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    I am by no means hardcore offroading anything.
    That being said I've gone with guys who have nearly 4k in suspension mods. Yeah it is cool. I'm sure they can and will push the limits on that set up eventually.
    I can say however, I still have yet to not keep up on places I go with people. The guys I go with are casual offroad nothing crazy so far. The stock suspension is I guarentee more capable than most people are.
    Get something practical and quality. Bikstein has been mentioned multiple times, and for good reason. Some 5100's is an upgrade from stock, rides great, and if you're into that kinda thing, looks good too. Runs a 32" tire and is plenty capable.
    JoeCOVA and 71tattooguy like this.
  14. Apr 13, 2020 at 9:02 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Come on man, you've been here long enough to know triple bypass kings are best for going on gravel roads
  15. Apr 13, 2020 at 2:25 PM
    steviek121
    I find it funny how people react to the cost of the kits I asked about. We're talking about 40k+ trucks, I don't think either of those kits are crazy. They are both mid range kits, not the cheapest but not nearly the most expensive. I said as of now I'm mostly on road, but things change and I'd rather not but another kit later down the road plus they can make my on rode ride better. Out of all the responses I got only a couple actually hit on the topic I asked about while the rest complained about the price and how I use the truck. So for the few who actually tried to help thanks for the butt hurt people oh well.
    Dontkillzenkis and ffemt2987 like this.
  16. Apr 13, 2020 at 2:26 PM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    https://accutuneoffroad.com/product/05-tacoma-mid-travel-suspension-kit-stage-5a-fox/
    If you're gonna get 1 foot in might as well commit
    JoeCOVA likes this.
  17. Apr 13, 2020 at 3:46 PM
    JoeCOVA
    Joe
    Colorado Springs
    Oh we know, I'm one of the few running over $5k in their suspension. It's because we are all here to help and we've all been where you are at some point; all looking out for your best interest. Trust us, we see lots of regerts on this forum. Everyone who replied has a different suspension setup with a unique perspective.
    At the end fo the day you can buy whatever you want, only you can determine whether the ROI was worth it.
    eurowner and Dirk Diggler like this.
  18. Apr 13, 2020 at 3:59 PM
    TacoTime850
    2019 DCSB 4x4
    Its just opinions. I think they’re just trying to be helpful in their own way. They’re just trying to save you some money, even though you weren’t asking for it.
    Next time just make sure to say something about money not being a factor. Then you do have an argument about people trying to persuade you to a cheaper alternative
  19. Feb 13, 2021 at 5:26 AM
    QcToy19
    QcToy19 The french guy
    Québec, Canada
    19 Sport DCLB
    I'm in the same bot and I really like both but I don't now which one are the best overall.
    Any advice?
    Edit: elka are like 3 hours from my home that's why I'm still hesitate
    TacoPandaTRD likes this.
  20. Mar 28, 2021 at 9:03 PM
    TacoPandaTRD
    TacoPandaTRD Well-Known Member
    TacoPandaTRD
    Chilliwack, British Columbia, Canada
    2020 Toyota Tacoma TRD Off-Road
    Always looking to modify! Check out my Instagram @TacoPandaTRD
    If you haven’t pulled the trigger yet go Elka. Especially if they’re that close. You could drive there for a rebuild! I’ll be getting Elka because of the aluminum body and how they’ll last with all the salt on my roadways.
    boston23 likes this.
