Fox shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sr_Suerte, Mar 4, 2018.
  1. Mar 4, 2018 at 6:15 PM
    Sr_Suerte
    Sr_Suerte [OP] Well-Known Member
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    thinking of going with fox over bilstein anybody running this set up? If so what’re your thoughts on it
    HerNameIsRuby and TXpro4X4 like this.
  2. Mar 4, 2018 at 6:18 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    If you got the money, go for it. Ride quality is amazing on kings and fox (friends have em on their truck). I will be getting TRD Pro 2nd gen kit which are essentially Bilstein 6112/5160 which is pretty good and most people who only have rode on factory shocks before would think you have a hi-end suspension, but if I had a bigger budget, would have definitely gotten Fox or Kings.
  3. Mar 4, 2018 at 6:21 PM
    Sr_Suerte
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    Im thinking of going this route over the 6112/5160 set up, i want a nice on road ride while still having decent performance off road
  4. Mar 4, 2018 at 6:25 PM
    ZekeR7
    For "decent", I think fox is a little overkill. The 6112/5160 is firmer and more forgiving compared to stocks on and offroad. Especially going from a TRD sport to 6112/5160, it is a world of difference.
    Fox of course will surpass that. If you are not planning to go MOAB, baja, or etc, I don't think you would need Fox.
    TXpro4X4 likes this.
  5. Mar 4, 2018 at 6:29 PM
    Sr_Suerte
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    You'll have to forgive my ignorance, ive done alot of research but still feel like i know nothing...
    are fox shocks adjustable like the 6112's? my main concern with the 6112 is that if i try to get two inches up front with too high of a clip setting my on road performance will suffer and be too stiff.
    mikestaco17 likes this.
  6. Mar 4, 2018 at 6:34 PM
    ZekeR7
    Yes they are adjustable, however you would have to take it apart to adjust them. On top of that, they are not rebuild able (from what others have said), but a 6112 is. The 6112 is known for going 1"-3" so you would be fine however the Fox lvl 2 is maxed out at 2" so it would be stiffer on the road.
    Sr_Suerte[QUOTED][OP] likes this.
  7. Mar 4, 2018 at 6:41 PM
    ZekeR7
    Oh, forgot to mention, if you are doing suspension that will do any kind of lift to the taco, I recommend replacing the needle bearing in the front diff. You can search up ECGS bushing and everyone will recommend it since the needle bearing are guaranteed to fail, just depends on when. Some reported the very next day others a few years down the road. The ECGS bushing is only $60, if you plan to do it yourself, you would have to buy the special tools for it which is $$$
    RedRed and Sr_Suerte[OP] like this.
  8. Mar 4, 2018 at 6:42 PM
    Sr_Suerte
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    I was thinking of doing 5100's all around with 887 coils instead of the 6112's so the shock had all of its travel in hopes to combat a stiff on road ride
  9. Mar 4, 2018 at 6:43 PM
    Sr_Suerte
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    was planning on it, need the link for it tho....
  10. Mar 4, 2018 at 6:48 PM
    ZekeR7
  11. Mar 4, 2018 at 6:50 PM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Do not do this. It will ride awful, i had 5100's w/ OME 885 coils on my tacoma and it was brutal. Go with fox, icon, king, radflo, etc and be done with if it's in your budget. You'll also need UCA's to get your alignment right. Don't buy the suspension if you can't afford UCA's. I now have radflo's and it was the best money spent on my truck.
    Mully likes this.
  12. Mar 4, 2018 at 6:52 PM
    MGMTaco17
    MGMTaco17 Well-Known Member
    Orange County, CA
    2017 Tacoma DCSB TRD Sport
    2017 DCSB TRD Sport. TRD Pro Grille. Morimoto Elite 35W HID Headlights. Morimoto XB LED Fog Lights. Clazzio All Black Leather Seat Covers. 32" LED Light Bar Bumper Stealth Mount. BHLM. Raptor Light Kit. Leer 100R. Bilstein 6112/5100 set at 3rd notch. LT275/70-17 C-Load Hercules Terra Trac AT2. Bora .750" Wheel Spacers.
    Can you explain this? I'm going from a TRD Sport to the 6112/5100. Will it be a firmer stiffer ride? Or softer?
  13. Mar 4, 2018 at 6:53 PM
    Italia234
    Italia234 Well-Known Member
    Nick
    Tucson
    TRD offroad
    I’m running that exact set up on my 2015 I like it a lot! For sure stiffened up the ride all around over stock. The factory suspension was awful off road. I am running total chaos upper control arms up front and in the rear I have the allpro u bolt flip kit wheelers super bumps and allpro expo leaf pack.
    As a side not I’m not much of a rock crawler or a desert racer I like to camp and mostly find myself driving fire roads that lead to less traveled fire roads pretty bumpy and lots of washboard roads here in Az.
  14. Mar 4, 2018 at 6:55 PM
    ZekeR7
    He won't need UCA's if he is only lifting for less than 2"
  15. Mar 4, 2018 at 6:57 PM
    ZekeR7
    On road will be firmer on handling, but when it goes over things it'll be softer compared to stocks. Basically if you corner hard or brake hard your nose won't dive like the TRD OR stocks do, but when you are offroad and hit a hole or go thru ribs/multiple small bumps, it'll be softer.
    Jukeboxx13 and MGMTaco17[QUOTED] like this.
  16. Mar 4, 2018 at 6:59 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    Firmer,More resistance to bottoming offroad
    No, he'll need them to make the truck drive right. It may be "in spec" but it'll drive funky and not as well as it could/should. Also those fox coilovers are preset at 2", not maxed out at 2" of lift.
    1truckdriver and Sr_Suerte[OP] like this.
  17. Mar 4, 2018 at 7:04 PM
    ZekeR7
    Did you have the 3rd gen? Cause I am pretty sure the 3rd gen is already 1" higher which is why it's maxed out at 2" OF ADDITIONAL LIFT. Sorry I didn't clarify. I could be wrong though.
  18. Mar 4, 2018 at 7:06 PM
    Sr_Suerte
    Chance
    Carlsbad
    2017 TRD Sport DCLB
    I was planning on getting camburg UCA's with whatever set up i get
  19. Mar 4, 2018 at 7:06 PM
    Italia234
    Nick
    Tucson
    TRD offroad
    [QUOTE="Also those fox coilovers are preset at 2", not maxed out at 2" of lift.[/QUOTE]
    I never knew that. I have never adjusted mine up cause I could never found out what they were set too. Always thought a lot of threads were showing so I left it be didn’t want to preload it too much. Now maybe I’ll turn mine up a little
  20. Mar 4, 2018 at 7:07 PM
    steezinstangl
    Elk Grove, Ca
    2008 FJ Cruiser
    good choice:thumbsup:
    1truckdriver likes this.
