Fox rotating shock cap?
Discussion in 'Suspension' started by Vitalzone, Oct 27, 2019.
  1. Oct 27, 2019 at 6:54 PM
    Vitalzone
    Vitalzone [OP] Well-Known Member
    Arizona
    2016 TRD OR 4x4 DCSB 6 spd manual
    -ADS coil overs with RR, and compression adjusters -ADS triple bypass rear shocks -Mcm UCAs -Deaver U402 stage 1 leaf packs -ADS bumps in the rear with Icon U bolt flip striker plates -Relentless Offroad U bolts -Wheeler superbumps in front -SCS 17" Ray 10s -285/75/17 BFG KM2s -Nitro 5.29 gears -Pelfteybilt armor front to back with HC rear bumper. T- case skid cut to fit Spec U exhaust. -RCI diff skid -Avid bed bars with basket holding spare. Poison Spyder 3-way strap. Hi-lift jack,and shovel mounted to basket. - SDHQ ditch light brackets with BD Squadron Pro spots. -BD Squadron Pro wide cornering in F. bumper. -BD S8 30" bar in F. bumper -Smittybilt 10k X20 winch -Factor 55 fairlead, and prolink -Switch pro 9100, with custom machined aluminum switch bezel. -BAMF grille insert -URD short throw shifter -URD Spec U exhaust cut over axle. Exhaust looks like it was fabricated by a blind child. -Suntek carbon XP 18% tint all around -ARB single compressor, mounted on Slee bracket. Lines to front, and rear bumper. -Rear diff breather mod,ran to bed cubby. -Ovtune 1.05 FOB 91 -Sprint-booster -Clutch accumalator delete mod -Hella Sharptone horns -Crown +4” extended brake lines, with modified factory brackets to fit lines. -Hypertech speedo calibrator -Custom pinstripes, and trail rash done by the beautiful AZ desert.
    I can’t find any info on how to rotate Fox rotating shock caps. Nothing in the Fox tech manual, nothing online. Is it as simple as loosening the two cap screws, and moving it to the desired position? Does the nitrogen need to be released? Does the shock need to fully extended, or compressed? Any risk of losing oil?
  2. Oct 27, 2019 at 6:58 PM
    tcjacado
    tcjacado Well-Known Member
    https://youtu.be/Vc3qTUSBm90
    Vitalzone[QUOTED][OP] likes this.
  3. Oct 27, 2019 at 7:03 PM
    Vitalzone
    Arizona
    Maybe I should have said that I’m talking about a 16” triple bypass piggyback shock. I know how to adjust a coilover, but thanks for the effort.
    tcjacado likes this.
  4. Oct 27, 2019 at 7:05 PM
    tcjacado
    Yup.. you were not very specific. :hattip:
  5. Oct 27, 2019 at 7:08 PM
    Vitalzone
    Arizona
    Haha yeah your right. I should know better.
    tcjacado[QUOTED] likes this.
  6. Oct 29, 2019 at 9:04 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Yes, pretty simple. Loosen those top screws and rotate into the position desired. No nitrogen or oil will come out of that. BUT, you may want to discharge the shock to rotate the cap easier. PM inbound
