Fox 2.5 front coilover Top shock hat hardware issue
Discussion in 'Suspension' started by Reapacheap, May 16, 2016.
  1. May 16, 2016 at 7:38 PM
    Reapacheap
    Reapacheap [OP] Well-Known Member
    Kam
    Memphis/Bay Area
    2015 TRD sport double cab
    All-pro Fox 3" lift, FN wheels, 33" general M/Ts
    What's up guys, I'm installing my 2.5 coilovers a but I'm convinced my coilovers didn't come with the right bolts. I'm only concerned with the top shock hat installation at this point. If someone could validate the length, size and quantity of the hardware for this I would appreciate it. I'm not mechanically gifted so try and make it as laymen as possible thanks again. I'll post pictures and descriptions of what came in my shipment when I get back to the garage.
    Thanks in advance guys and gals
    Kam
  2. Oct 13, 2020 at 6:52 PM
    Efrenngalindo
    Efrenngalindo Member
    Efrenn
    Work in progress
    Suspension/snorkel/cbi bumper/painted my rims
    I’m having the same issue
    Did you find out what size bolts??
  3. Oct 14, 2020 at 10:02 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Can't say for sure what they are supposed to be but my 2.5" IFP non-reservoir top hat bolts appear to be 10mm-1.25 5T class JIS. My belief is because a 14mm wrench fits them best and the spec is 24 ft-lb torque. I'd have to take one out to check length.
    Why are you questioning? They should thread in by hand with the shock on the bench and be maybe 1/2" to an inch longer than the top hat is thick. Long enough that with washers and the coil bucket thickness they'd engage all the threads without being proud of the bottom. If that's not true then they are wrong.
