FOX 2.0 shocks? Budget Upgrade?
Discussion in 'Suspension' started by StuckinOhio, Nov 14, 2013.
Which kit would be a happy medium of cost vs. performance?
Poll closed Dec 14, 2013.
  1. Fox 2.0
    18 vote(s)
    46.2%
  2. Bilstein 5100
    8 vote(s)
    20.5%
  3. Adjustable 5100
    2 vote(s)
    5.1%
  4. Assembled 5100
    0 vote(s)
    0.0%
  5. Man up, waste your savings, drop 2k on your truck. YOLO
    11 vote(s)
    28.2%
  1. Nov 14, 2013 at 3:52 PM
    StuckinOhio
    StuckinOhio [OP] Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    So I am considering upgrading my coilovers and rear shocks to the fox 2.0 performance series. My truck is a street queen DD. I don't pre-run or huck it because well lets face it im in ohio. I recently upgraded the wheels and tires from the steel dunflops and now it rides pretty rough. I dont plan on lifting it, just leveling it .5-1 in. I am a buy once cry once kind of guy. But cant really justify extended travel 2.5 and adjustable compression rears for my application. What do you guys think?
    I have free 6 month alignment so i didn't factor that cost in.
    Fox 2.0 series
    Fronts: $690
    Rear:$220
    total: $910
    Pros: bolt on kit. drop LCA and you're done, front and rear done for under 1k, can sell complete set of stock coilovers to regain some pennies
    cons: higher price, Significantly higher then bilstein 5100
    bilstein 5100:
    total: $310 + dealing with switching coils over.
    Pros: cheap alternative, highly recommended
    Cons: pay someone to switch coils or con a friend to bum a ride to town. Deal with coil compressor, or buy coil compressor Not as good as fox?
    bilstein 5100 adjustable:
    front:$620
    rear: ????
    Lets be honest, this kit is ridiculously overpriced for the same shocks
    not an viable solution.
    Assembled 5100 with springs:
    fronts: $600
    pros: assembled
    cons: fox price range....
  2. Nov 15, 2013 at 10:15 AM
    Jeffsdeere
    Jeffsdeere Well-Known Member
    Jeff
    07 Tacoma DC4wd
    BAMF Sliders All Pro Rear Bumper 5100's @.85
    I've been very indecisive on new shocks for a long time. I have looked at these more than a couple times but have never seen a review from anyone about them. With the icon sale coming up over Black Friday, I think I'm just going to pull the trigger on a stage 1 kit. It is a couple hundred more but I think it is probably the best. Unless of course, someone puts something else on sale. Then it's back to square one again
  3. Nov 16, 2013 at 4:48 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I have been following the icon sale as well. I think progressive will suit me needs better though. I have considered their rear shocks that can be used for 0-2.5" lift. But doubt I will ever lift and would like to stick to one brand front/rear. I'm really surprised there is so little info/reviews on the 2.0 series.
  4. Nov 18, 2013 at 9:57 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I agree my friend, i had the same predicament you had, i ended up getting the fox 2.0 performance coilovers and the matching rear shocks to boot, ended up being around 800$(DSM had a killer deal at the time)
    Im installing the suspension on friday so i'll have a review to add when that comes since literally no one has any real info on them.. thats active on the site anyway.
  5. Nov 18, 2013 at 10:26 AM
    TMACTacoma
    TMACTacoma Member
    California
    07 PreRunner SR5 DC LB
    Smoked FJ rims. Bilstein 5100's set at 2.5"
    I currently have the bilstein 5100 adjustables and am looking to change it to the fox 2.0 coilovers. The 5100's are a little rough for me, although I do not off road that much, I would like a smoother ride. Another thing you have to worry about is if you do plan to level it out then the stock Upper Control Arms may not be what you want. I leveled the front of my truck out and it drives like crap on the freeway due to the alignment always being off because the stock UCA's aren't made to be leveled. So I would recommend that you get upper control arms as well otherwise you will be going back and forth in your lane on the freeway. Hope that helps.
    And yes ChamYota if you could review those shocks then that would be great!
  6. Nov 18, 2013 at 10:28 AM
    ChamYota
    Cam
    I will try and take them wheeling a little bit as theres a good trail near where we are gonna install them. No worries brother! :)
  7. Nov 18, 2013 at 10:31 AM
    zacksblacktaco
    zacksblacktaco Well-Known Member
    west virginia
    06 trd sport access
    AEM CAI Throttle body spacer Borla cat back exhaust Doug Thorley long tubes RCD 4.5 anzo halo projectors with 4300k hids 12000k hid fogs T-rex stainless mesh mesh grille kit in pro car wear LED taillights & 3rd brake LED reverse lights LED license plate lights LED dome & map lights all Kicker speakers with 15 inch L7 subwoofer Jensen 7inch flipout headunit Trd sport seatcovers Re-badged red Tacoma
    I just bought the fox ifp 2.0 for my 2004 and they are awesome 100x better than the bilsteins on my RCD lifted 2006
    my vote goes to the fox series
  8. Nov 18, 2013 at 11:05 AM
    FatTony415
    FatTony415 Well-Known Member
    Tony
    San Francisco, CA
    '20 DCSB 4x4 TRD Off Road
    Stock for now
    I was all ready to order an OME lift, but now I am seriously considering the Fox 2.0 shocks. The cost of the Fox setup is comparable to the OME, the coilover is adjustable, and well, it's Fox. I've been using Fox forks on my MTBs since 2005 and I currently own two F29s - they're the best, hands down. I know that doesn't necessarily translate into trucks, but Fox definitely knows suspension.
  9. Nov 18, 2013 at 11:10 AM
    ChamYota
    Cam
    I did exactly that, i was gonna get OME, but decided to go fox, i could adjust as need be, the ride will be better, it's rebuildable to adjust to your particular preferences, i liked the customizable aspect of it.
    Fox forks on MTB are sweet as well.
  10. Nov 18, 2013 at 3:49 PM
    FatTony415
    Tony
    San Francisco, CA
    Stock for now
    How much lift did you get on the front with the Fox 2.0? Did you have to adjust the preload to level the truck, or was it good out of the box? Did the rears provide any lift on their own?
  11. Nov 18, 2013 at 3:55 PM
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    If you don't off road don't waste the money. Buy the billies. If you were off roading the truck then King. Icon. Fox.
  12. Nov 18, 2013 at 4:11 PM
    ChamYota
    Cam
    Ahh sorry i must have made the impression that i already installed them, im installing them friday
    my current measurements are
    20.5 Front
    22.5 Rear.
  13. Nov 18, 2013 at 5:23 PM
    FatTony415
    Tony
    San Francisco, CA
    Stock for now
    OK, post some pics if you can. I'm probably gonna say fuck it and order the Foxes tomorrow from DSMS.
  14. Nov 18, 2013 at 6:02 PM
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    OP start a group buy on the fox's i'm down..haha
  15. Nov 18, 2013 at 8:52 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    I actually just emailed DSM to see if i can find out what the deals for Black Friday will be. Im buying rear shocks ASAP. I just installed methods and toyos and i get bad bump chatter. OH/PA/NY are the the worst states for potholes/road patches. I agree i'm sort of biased to fox's I've ridden some nice mtb's with them and have been impressed with them on my friends quad.
  16. Nov 18, 2013 at 8:56 PM
    TMACTacoma
    TMACTacoma Member
    California
    Awesome! Can't wait to hear how they are!
  17. Nov 19, 2013 at 2:50 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    And FWIW, I have ridden & worked on FOX MX stuff since the 70's, ridden & worked MTB stuff since the mid 90's, while I looked at getting them for the truck, I was always haunted by all the issues of dealing with FOX.
    I narrowed it down to Kings or ICON. While FOX products get good support from their vendors, ICON has been easy to deal with both from the vendor I purchased from and also when I have spoken to ICON direct.
    So the truck rides on ICONs and the Ventana tandem MTB rides on a Fox 40 and DHX 5 air.
    Best of luck with the small bore 2.0 Foxes.
    PK
  18. Nov 26, 2013 at 1:11 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    I haven't read through your whole thread yet but... Why in the hell would 5100 adjustables cost you I've $600 just upfront?!!! Ive got em on my Xmas list from Amazon for $200 including shipping?!!
  19. Nov 27, 2013 at 1:59 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    5100's are $180 from DSMS (down south motorsports) with free shipping
    plus coils ~$160 for OME coils
    Plus the $100 assemble charge from wheelers, and that's $440 without shipping, taxes, and whatever else he adds to the cart :notsure:
  20. Nov 27, 2013 at 4:57 AM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
