Fox 2.0 Performance Series Coil-over IFP
Discussion in 'Suspension' started by Dr. Jekyll, Oct 18, 2015.
  1. Oct 18, 2015 at 3:31 PM
    Dr. Jekyll
    Dr. Jekyll [OP] Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
  2. Oct 19, 2015 at 10:27 PM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Anyone?
  3. Oct 20, 2015 at 8:43 AM
    summitsurf
    summitsurf Well-Known Member
    Utah
    2004 Ext Cab TRD Fox 2.0 all 4 corners
    Do it! Light desert runs and forest service roads are a dream now! Granted I was coming from factory suspension with 190k on it. Comes set at 2" of lift and has settled to about 1.8" now after about 3 or 4 thousand miles.
    allrsdup and Dr. Jekyll[OP] like this.
  4. Oct 20, 2015 at 9:51 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Thanks for the reply and feedback! Do you have any pics of the truck?
  5. Oct 23, 2015 at 1:06 PM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Anyone else?
  6. Jun 27, 2016 at 5:17 PM
    Trev7
    Trev7 Well-Known Member
    Trevor
    Lehi, UT
    2001 2.7l prerunner Orange Xtra cab
    Icon 2.5 ext travel street valve, Icon 2.0 resi, rebuilt leaf springs, built right UCA's, single stage ppg Orange paint.
    I just picked a set up for $865 all said and done with wrench from ORW. I'll install them (hopefully tonight) currently have stock suspension with a spacer that gives 2" lift and am so stoked to feel the difference. I have a 2001 xtra cab 2.7l
  7. Jun 27, 2016 at 11:20 PM
    Trev7
    Trevor
    Lehi, UT
    Installed them with my little bro in 50 mins! I took them for a spin and my smile got bigger and bigger because those old bumps on the road weren't bumps anymore. Little stuff is smoothed out, speed bumps are fun cause it just takes it. I cranked them a full revolution and that gave 24" inches from center hub to fender and in the rear is 22.5" hub to fender so super happy!
  8. Jun 28, 2016 at 12:09 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Yo are those the Vans that are made from hemp?
    I had those exact same Vans.
    summitsurf[QUOTED] likes this.
  9. Jun 28, 2016 at 3:14 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    I have them on my truck and love them. The only negative is you have to remove the shocks to adjust the height. I have put about 17000 miles on them so far.
  10. Jun 28, 2016 at 12:10 PM
    koda925
    koda925 Well-Known Member
    Dakota
    Ogden, UT
    2015 DCSB TRD Offroad Auto
    Bilstien 5100's all around, SPC uppers, headlights, tailights
    20160627_113140.jpg I want these so bad for my 08 trd offroad. I currently have a supreme suspension leveling kit with 2.5 in the front, 1 in the back, diff drop, and sway bar relocation. So you are all saying they go up to 2" in height.. I dont want to lose clearance from my original 2.5" spacer that i already have. Does anyone have experience running these at zero with a spacer installed? Or close to zero? Would like to get the truck to 3" in the front and 1.25 in the back (since the factory rake is 1.75). Or would this defeat the purpose in getting these in the first place? Looking for that height AND a better ride quality.
  11. Jun 28, 2016 at 12:12 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    Access cab 2nd gen/DCSB 3rd gen
    Me and @ChamYota are running them. I adjusted up to 2.5in but I'm going up to 3in soon. I know he adjusted up too. I've got bumpers and skids so it rode better at a higher setting because I kept smacking my bump stops too easy. I really need heavier coils for my application but it won't change ride tremendously to adjust them up
  12. Jun 28, 2016 at 12:15 PM
    koda925
    Dakota
    Ogden, UT
    Oh... And UCA's... it doesnt look like it from the pictures, but i was under the impression with these kind of coilovers you had to run aftermarket UCA's? Are people running these coilovers all alone? Or are there other components that have to be installed with these coilovers?
  13. Jun 28, 2016 at 12:16 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I was running without UCAs and still having issues getting a good alignment. You could probably get away with it if you don't adjust them
    koda925[QUOTED] likes this.
  14. Jun 28, 2016 at 12:19 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    2.0 IFPs, Uniball uppers, superbumps and 285/75r16s
    doubleBibbs likes this.
  15. Jun 28, 2016 at 12:24 PM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Yes, a huge pain in the ass and a real pisser since they give you the impression they are "adjustable"
  16. Jun 28, 2016 at 12:28 PM
    koda925
    Dakota
    Ogden, UT
    Sick bro. Love your set up. Im all about lifting but i just want to make sure its not going to destroy ride quality or have alignment issues. Seems like to run any higher you need the uca's to keep alignment. Im already right on the border with my 2.5 pucks in the front and trying to get aligned correctly. Looking to run 285/70/17 once im up a little higher. And definitely sounds smart to get the bump stops too. Hows your ride quality/ alignment?
  17. Jun 28, 2016 at 12:29 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Negative ghost rider. I did mine on the truck.
  18. Jun 28, 2016 at 12:30 PM
    koda925
    Dakota
    Ogden, UT
    Sorry if im misunderstanding, but you're saying you're running the spacers with the coilovers?
  19. Jun 28, 2016 at 12:31 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Everything is great I can't complain. My only issue is I'm running digressive valved shocks in the rear making my truck buck while I'm off road but otherwise I'm happy. I've got 50k or so on them
  20. Jun 28, 2016 at 12:32 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Hell no. Spacers and coilovers just isn't smart IMO. Coilovers cranked up to 2.5in
    drawcab and koda925[QUOTED] like this.
