Fox 2.0 and 700lb coils?
Discussion in 'Suspension' started by tacoma16, Oct 28, 2019.
  1. Oct 28, 2019 at 10:01 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Back story: I am getting some fox 2.0’s for free and want to get them rebuilt and have heavier coils put on (they come with 600 I believe). This will give me a fox setup for much less than new obviously.
    But.....is there a 700lb coil for this shock?
    I have been searching around and can’t find a definitive answer.
    my questions:
    1. Is there a 700lb coil for the fox 2.0 shock?
    If not....
    2. is anyone running the fox 2.0 shock with a 700lb coil meant for a 2.5 shock? The eibach seems to be a popular choice (14” 700lb coil)
    I have emailed fox and they said yes, however, this has contradicted some other emails I received back from other offroad shops. So just want some real life experience prior to investing anymore time and more importantly money..
    Thanks in advance
  2. Oct 28, 2019 at 10:45 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    The 2.0 and 2.5 Coilover use different springs.
    You will need to use a 2.5" spring for your Fox 2.0.
    The 2.5 Coilover uses a 3.0" spring.
    I have not seen a 2.5x14x700 spring ( King maxes out at 650 )
    But, it doesn't hurt to call King or Fox and see what they say
    How much weight do you have up front that you need 700lb springs?
    JT
    tacoma16[OP] and MattCowsmasher like this.
  3. Oct 28, 2019 at 11:17 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Currently fully armoured, winch with steel cable. 700lb would be ideal. Currently have the OME with the 886 coils which are over 650lb if I remember correctly.
    I currently looking at the eibach coils which are 14” and 700lbs, but I am not sure if they will fit
  4. Oct 29, 2019 at 8:40 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Okay so @Downsouth Motorsports rock!
    they have informed that the 2.0 shocks require a 2.5” coil. I just thought a 2.0 shock required a 2.0 coil which I wasn’t able to find.
    however the stock fox shocks (2.0) for the Tacoma utilize a 3.0 coil.
    thanks DSM for clarifying this!
  5. Oct 29, 2019 at 10:39 AM
    JT@Bajakits
    JT
    I thought I answered all that for you :notsure:
    Haha! All good though.
    Are you sure the Fox 2.0 uses a 3.0 spring ( mean't for the 2.5 coilover )??
    tacoma16[QUOTED][OP] likes this.
  6. Oct 29, 2019 at 10:57 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    edit: yes you did mention that. Flew over my head but I was looking for a definitive answer on what coil fits the fox 2.0 shock for the second gen taco. Fox said the 3.0 shock fits but then been hearing different hear and there.
  7. Nov 27, 2019 at 6:39 PM
    INT.EGRATED
    INT.EGRATED Well-Known Member
    San Francisco, CA
    2006 Lexus GX470
    @tacoma16 you ever get 700lb springs for them, i.e. king springs? looking to go the same route.
    tacoma16[OP] likes this.
  8. Nov 27, 2019 at 7:03 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Still waiting for my buddy to get his shocks installed so he can give me his used 2.0’s. Then they will get rebuilt and 700lb coils.
    INT.EGRATED[QUOTED] likes this.
  9. Nov 27, 2019 at 7:06 PM
    INT.EGRATED
    San Francisco, CA
    2006 Lexus GX470
    what brand 700# springs will you go with?
  10. Nov 27, 2019 at 7:10 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Either eibach or kings. What ever I can get locally
  11. Sep 16, 2022 at 5:29 AM
    Radioactiv
    Radioactiv Well-Known Member
    Georgia
    2015 DCLB 4X4
    Just to follow up on this some of the information above is incorrect. The 2.0s use a 3" coil just like the 2.5.s I swapped to 3 x 14 x 700lb coils on my 2.0s and it made a world of difference in height gained back and deleted the sway bar while I was at it.
  12. Apr 17, 2024 at 2:49 PM
    SIK99Tacoma
    SIK99Tacoma Well-Known Member
    Taylor
    Big Sur
    2020 OR DCLB
    FOX IFP front 2nd clip 1/2" spacer, FOX 2.0 adjustable resi rear, RXT leaf pack, SSO slimline front w/ baricade 9500lb and amber light bar, ARE Cap, allpro steps, TRD pro style wheels w/ Kenda Klevar skins
    resurrection.......
    couldnt one just use the stock springs from the OR which are 700#?
  13. Apr 18, 2024 at 8:59 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    The shocks I was originally getting were coming off of a third gen who was running his stock coils if that helps. I wasn’t aware at the time that they were 700
  14. Apr 18, 2024 at 9:03 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    FWIW in the resurrection.
    Fox uses Eibach springs.
  15. Apr 18, 2024 at 9:07 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    With the resurrection, I ended up going with 2.5 Elka shocks. Can get them with the heavier coils from factory. Bit more spendy but so far so good
    My old man emus shocks failed pretty bad. With the amount of miles they had though I can complain.
    in this image you can see the shock on the left is much longer as it broke the internal bump so it extended an extra inch or so
    SIK99Tacoma likes this.
