FOUND Rivet Nut Size FOUND
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unchained 5150, Oct 10, 2021.
  1. Oct 10, 2021 at 10:47 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I want to remove all the plastic cheap screw inserts in the tailgate cover and put rivet nuts in them instead. Does anyone know what size I need, Mobtown used to sell a kit for this but we all know what happened to them. Thanks for any help you can provide.
  2. Oct 10, 2021 at 11:07 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Remove one of the bolts, take it to your local hardware store or big box and match it up.
  3. Oct 10, 2021 at 11:08 AM
    Unchained 5150
    Rick
    Auburn Ma
    Once you remove the plastic those OEM screws are no longer used so that won't help.
  4. Oct 10, 2021 at 11:09 AM
    Unchained 5150
    Rick
    Auburn Ma
    1/4-20 steel rivet nut is the size
  5. Jun 24, 2022 at 9:42 PM
    TacoTuesday1
    FL
    which bolts did you use with the new rivnuts?
    am thinking roundhead/curved head stainless Torx would be best
    (Torx less likely to strip than Allen)
    same thread to fit 1/4-20
    just not sure what length
  6. Jun 24, 2022 at 10:10 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    Stainless pan head would be a good idea. Hit the plastic cover with a countersink and set it flush.
  7. Jun 24, 2022 at 10:33 PM
    TacoTuesday1
    FL
    cover is aluminum relentless fabrication
  8. Jun 25, 2022 at 9:51 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Use the OEM screws with NAPA replacement plastic inserts. The NAPA is much better than the OEM, NAPA part #665-1376 by Balkamp. I replaced all my original plastic square inserts with the NAPA. Don't have a clue how anybody puts round rivitnuts into a square hole.
  9. Jun 25, 2022 at 11:20 PM
    CPS-65
    Alta Loma, CA
    Mostly old man mods
    Even better. Countersink it and get a smooth surface.
