Found metal pieces in the holes of my oil filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Jul 12, 2020.
  1. Jul 13, 2020 at 4:16 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    those oil filters have a metal center hole, looks like a strand of metal came loose from it and poked out the drain hole
  2. Jul 13, 2020 at 4:22 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    There was more metal just sitting on top but I took it off yesterday to see what it was there was like 4 strands of metal on top
  3. Jul 13, 2020 at 4:25 PM
    BillsSR5
    bill
    2014 SR5
  4. Jul 13, 2020 at 4:33 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Either it was there when you put the filter on, or it arrived later. Not sure it really matters now.
    You could take it all apart and try to find any other pieces, or you could flush it out with fresh oil, put a new filter on, and send it.
    My guess is you'll be fine, but there's a minor chance you'll need a new engine in the next few thousand miles. I don't think its worth tearing into unless it starts having issues.
  5. Jul 13, 2020 at 4:35 PM
    Rollie's 95Tacoma
    Rollie's 95Tacoma Member
    Roland
    Ohio
    1995 Tacoma ext cab 4X4
    Toytec BOSS suspension, ARB Air lockers, 529 gears, ARB bumper
    just out of curiosity, did you see if the metal would stick to a magnet? Just kind of a starting point for figuring out where or where not it could have come from.
    0xDEADBEEF likes this.
  6. Jul 13, 2020 at 4:39 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    The filter itself has a metal mesh that holds the paper filter media. That’s what it looks like to me.
    Engine damage looks like metal curly-cues
  7. Jul 13, 2020 at 4:44 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    In other words: "either you're totally fine, or you're totally fucked"
    :boink:
    But yeah, those are two distinct possibilities, lol
    @Tacomaislife as I mentioned earlier, I would drive it around for a bit (sounds like you already have), and then change the oil again. As long as it seems to be running normally with no weird sounds you could probably wait a month. Use a coffee filter to catch any potential metal pieces coming out of the engine pan, and closely inspect the filter. If it appears clean, and there's no shiney bit on the coffee filter, replace the filter and refill.
    If you get metal shavings in the engine pan, then yeah, you're in for :spending:
    Good luck
    0xDEADBEEF[QUOTED] likes this.
  8. Jul 13, 2020 at 4:49 PM
    Sharpish
    Brian
    Finish your oil change, and forget it ever happened. I’ll bet it runs another 100 000 miles.
  9. Jul 13, 2020 at 4:54 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    That's what filters do they stop trash. Now I'm sure you don't realize Fram is the #1 selling filter made they did not get that way building junk filters I don't think there is such a thing as "the best filter" they all do exactly the same thing.
  10. Jul 13, 2020 at 4:59 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Not a drain hole it came from the engine side.
  11. Jul 14, 2020 at 6:01 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    If you are super worried and can't stop thinking about it.. blackstone laboratories sells oil sampling kits. They don't cost too much.
  12. Jul 14, 2020 at 6:21 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Counterfeit car parts is a thing. Auto parts stores or reputable sellers normally have a chain of reliable suppliers but counterfeit crap in a shipment of genuine parts is not unheard of. They don't always know it and if you get a fake, you should let them know and they will investigate/stop using this supplier
    Buying parts on internet is hit or miss sometimes, as fakes are often getting rid of this way by unscupulous sellers.
    Wulf and Xbeaus[QUOTED] like this.
  13. Jul 20, 2020 at 7:31 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Metal shavings from a Helicoil or timesert install maybe?
  14. Jul 20, 2020 at 7:39 PM
    BillsSR5
    bill
    2014 SR5
    cruiserguy likes this.
  15. Jul 20, 2020 at 7:39 PM
    #35
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You forgot to tell him to replace the oil after the first drain :)
  16. Jul 20, 2020 at 7:43 PM
    #36
    EZTacoma
    EZTacoma Well-Known Member
    Ezra
    Grand Rapids, MI
    05 TRD Sport AC 4x4 V6 6spd
    265/70/R17 Wrangler UltraTerrains
    I have no idea what FRAM is, but I know hate it because of popular opinion
  17. Jul 21, 2020 at 8:13 AM
    #37
    jbrandt
    Justin
    I also didn't tell him to remove (or replace) the oil drain plug. My post wasn't a step by step instruction manual.
    Tacomaislife[OP] likes this.
