Forgot to change the filter when changing the oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by edteach, Jun 4, 2020.
  1. Jun 4, 2020 at 4:51 PM
    edteach
    edteach [OP] Active Member
    I was in a hurry and had things to get to and needed to change the oil. I forgot to drop and replace the oil filter. I use 0 20 Mobil one. This put a bit of used oil in the mix. I started the truck before I realized this. So its mixed in. Should I just run or just take the hit and change it again.
  2. Jun 4, 2020 at 4:53 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Change the filter then in a week change just the filter again if you want. It’s fine
    wilcam47 and Jimmyh like this.
  3. Jun 4, 2020 at 4:54 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If you haven’t changed the filter, do it and top off the oil. Honestly, not a big deal.
  4. Jun 4, 2020 at 4:56 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Just change the filter and drive it normally until your next oil change. You can't get all of the old oil out anyway. A tiny bit more won't hurt.
    tinker_troy likes this.
  5. Jun 4, 2020 at 5:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is what I would do.
    Jimmyh likes this.
  6. Jun 4, 2020 at 5:01 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Isn't that what a dealership does?
    aficianado, jon_elc and Lester Lugnut like this.
  7. Jun 4, 2020 at 5:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It'll be ok. When you drain the oil, there's still a lot of residual oil all up in there. The tiny bit in your old filter is negligible. Just replace and top off.
    vssman likes this.
  8. Jun 4, 2020 at 5:04 PM
    edteach
    I just changed the oil and filter again. I will just get that nagging in the back of my mind, this way its over and done. God what a dumb ass. I hate it when I f up.
  9. Jun 4, 2020 at 5:04 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's worth the price of changing the oil again if it gives you peace of mind, nothing wrong with that.
  10. Jun 4, 2020 at 5:05 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    What interval? If you aren’t towing or hauling all the time you can miss a filter one time. Just do it the next time and don’t forget next time. Not the end of the world for a broken in engine.
  11. Jun 4, 2020 at 5:06 PM
    GarlicFarts
    Lil Rhody
    how TF did you do a second oil change in less than 10 minutes I’m impressed.
  12. Jun 4, 2020 at 5:07 PM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I would have just drained back into the jug, replaced filter, and dumped oil back in...plus whatever amount needed to top off.
  13. Jun 4, 2020 at 5:08 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Just change the filter (it’ll live) . Edit: Googled “dummy”
  14. Jun 4, 2020 at 5:10 PM
    Taco302
    Greenbow, Alabama
    When I had a 2nd gen (2011) the filter was upside down in the engine bay...so changes were REALLY easy.
    jetfishn likes this.
  15. Jun 4, 2020 at 5:12 PM
    edteach
    I know better than that. I also once poured in the oil and forgot to put in the plug. Another screw up. Happens when I am doing too much and not paying attention. I change it every 5000 so not like I change it every 3
  16. Jun 4, 2020 at 5:14 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    End of the world!!!!! :annoyed:
  17. Jun 4, 2020 at 5:15 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Make sure you didn’t drain the tranny
    Hendrix834 likes this.
  18. Jun 4, 2020 at 6:38 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    There is a little hack you can also do with a shop vac, takes two people tho unless you're a mad contortionist.
    Open oil fill plug, cover with a shop rag, put shop vac hose over fill plug and use more shop rags to seal it on there. Turn it on and remove the filter. The shop vac creates suction (duh) holding the oil in the engine. Maybe a few drops will be lost, but the trick works. Used it many times when I worked at a lube shop.
    whatstcp likes this.
  19. Jun 4, 2020 at 7:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That image is disturbing.
    Make you wonder where else that dummy has been. :eek:
    Steves104x4[QUOTED] likes this.
  20. Jun 4, 2020 at 7:42 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Been there! Luckily caught myself before I poured the whole jug in. We all do dumb stuff. Especially smart people. Smart people do the dumbest things of all.
    Island Cruiser and JimIowa like this.
