Forged pistons? 5VZ-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brice, Aug 2, 2015.
  1. Aug 2, 2015 at 2:17 PM
    Brice
    Brice [OP] Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    So does anybody know were to find/buy forged pistons for a 5VZ-FE.
    I kinda wanna supe one of these V6's (and the rest of the truck) so im playing with the ideas of a blower, 7th injector, cams, studs, solid drive shaft, rear locker, headers, rear disc brakes and a total rebuild of the lil V6. All i need to complete my list is forged pistons as i here that they are the weak points. (the crank and rods being good up to 500hp)
    because_wumbo-truck likes this.
  2. Aug 2, 2015 at 5:15 PM
    Brice
    Brice
    Texas
  3. Aug 2, 2015 at 6:07 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    LS Swap it!
    Brice[OP] likes this.
  4. Aug 2, 2015 at 6:20 PM
    Brice
    Brice
    Texas
    Lol now call me crazy but in all seriousness that's alot more expensive (believe it or not XD) I could get the ls for about $500 (I know a guy) then a new tranny ($1800+) new differential ($500-1000) new front suspension (omg I don't even know anywhere from 1400-3000) but I'd love to.
  5. Aug 2, 2015 at 6:26 PM
    Brice
    Brice
    Texas
    I wasn't expecting them to lol. From all that I'd expect at least 300hp, I've seen others make it happen. Really the only bottom end piece that needs updating is the pistons
  6. Aug 2, 2015 at 6:33 PM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
  7. Aug 2, 2015 at 6:40 PM
    Brice
    Brice
    Texas
    Heh thanks I never said I'd be easy XD and it would take awhile but I'd go slow :)
  8. Aug 3, 2015 at 7:19 AM
    Wulf
    rock raisin
  9. Aug 3, 2015 at 9:17 PM
    trx125
    trx125 Well-Known Member
  10. Aug 4, 2015 at 12:29 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    LS it and be done.
    You'll have 5k in a high strung 5vz that won't crack 350 hp, plus a trans that isn't going to hold the power either. Find a 6.0 with an NP263 behind it and have a reliable 360hp with a drivetrain that will hold up to the power too. Chevy made a million 6.0/ 4L80E/ 263 combos so it'll be way less to LS swap than build.
    hessian42 likes this.
  11. Aug 4, 2015 at 12:41 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    Don't crush OP's dreams. I myself am quite interested in seeing someone do more than just slapping on the supercharger and 7th injector. I'm excited for you OP. Good luck! :)
  12. Aug 4, 2015 at 3:06 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  13. Aug 4, 2015 at 4:04 AM
    Brice
    Brice
    Texas
  14. Aug 4, 2015 at 9:19 AM
    Brice
    Brice
    Texas
    Im now thinking of a 4-cylinder swap and build...not being able to get forged pistons is probaly why people dont do as much crazy stuff to there V6's...Still looking tho
  15. Aug 4, 2015 at 9:27 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    it's possible!!! :)
    https://instagram.com/p/ldGIH1LEfl/?taken-by=dirtdesigns
  16. Aug 4, 2015 at 10:50 AM
    Brice
    Brice
    Texas
  17. Aug 9, 2024 at 12:45 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Lazy thread revival cause I'm looking for pistons and rods for my next build, but on my stock 5VZ right now, literally nothing done to the engine internals but a turbo and a standalone computer I'm at 345hp and 422lb of torque at the tires (35s) measured on a mustang dyno... couldn't have LS swapped for the cost I'm into it. At the crank that's nearing 500lbs of torque and likely 380ish hp. There's more left in my stock engine too, I'm only pushing 12.5psi on a pretty conservative tune (low timing, lots of fuel). But I want to have another stronger one built before I find the limits of this one.
    Red_03Taco likes this.
  18. Aug 15, 2024 at 5:07 PM
    COTacomaTRDSC
    COTacomaTRDSC Well-Known Member
    2002 Tacoma TRD SC
    TRD black supercharger
    The difference is the margin of safety between the two. At 345/422 you are a lot closer to the ragged edge on the 3.4 vs. the LS swap. If you're driving it with a little care, it can last a long time, but I'd bet 35s are making it work harder as well. Depends on the revs where you find the power, and the ramp of the turbo boost, but lots of combinations push the envelope more than the owner's think...
