Footwell Lights That Don’t Suck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kmorgan3, Sep 2, 2021.
What colors would you be interested in?
  1. White (5500K)
  2. Blue
  3. Red
Multiple votes are allowed.
Results are only viewable after voting.
  1. Sep 2, 2021 at 6:15 AM
    kmorgan3
    kmorgan3 [OP] Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    Intro
    I’m happy to be sharing the next brain child of @caribe makaira, @Puppypunter, @daveeasa, and myself. This thread is intended to share our ongoing development of a fully plug-and-play footwell lighting kit for the 3rd Gen!
    Function
    This kit includes a wire harness and a PWM that will allow you to have 2 different modes of lighting. The first mode is courtesy mode and will trigger whenever you unlock or open a door. The lights will remain on until you close the door and the factory light timer reaches ~30 seconds, or you simply start the truck or lock the doors. New for version 2: The lights are controlled with the overhead dome light switch; so courtesy mode will now work in sync with your dome lights! The second is night mode which will engage whenever you turn on your parking lights or low beams. This setting is fully adjustable using the PWM. The user can make their ambient lighting as bright or dim as they like — although I must say that I run mine at the lowest and I can’t imagine someone wanting to go much brighter than that. Total install time is around 20 minutes for 2 lights. Longer for rear installs (details coming soon).
    Lights
    The entire kit is built around the newly redesigned VLEDs footwell lighting strips. They are BRIGHT. The standard options will be 5500K white, deep red, blue, or an aqua blue. The user can select whichever they prefer, and swapping them in and out is a breeze. For other color options (i.e. other shades of white) VLEDS will be offering lights separately and you can get them without buying the entire kit with all of the harnesses if you want to change.
    Ordering
    Standard kits will cost $140 for 2 lights with the PWM, an OE-style wire harness to make everything plug-and-play, extensions, wire anchors, adhesives, etc. An additional 2 lights will be $50 sold as a separate kit.
    You can place your order at one of these authorized retailers!
    Photos
    A comparison of the 2 modes in action:
    New in version 2!
    Here are the standard color options! Please note that these are NOT RGB! You will be ordering a single color. If you want to change them it is very simple (less than a few minutes).
    5500K White
    Aqua Blue
    Red
    Blue
    Install Instructions
    Front kit install -- Updated for Version 2
    Rear kit install
    https://www.youtube.com/watch?v=GZl8Xg9N8AY
    If you are installing the rear kit and attempting to mount the lights in your own unique way (e.g. the front of the rear seats), here are some extensions you can purchase separately to ensure you have enough wire.
    Version 2 upgrade:
    If you purchased version 1 (a-pillar harness) and want to upgrade to the overhead switch version, you can purchase the harness separately from the kit.
    3rd Gen Tacoma Footwell Switched Breakout Harness
    Other Trucks
    Kits for the 5th Gen 4Runner and 2nd Gen Tacoma are now available for pre-order!
    5th Generation 4Runner
    2nd Generation Tacoma
    Jbjamn, TacoJoe480, Scrat and 37 others like this.
  2. Sep 2, 2021 at 6:16 AM
    Tacospike
    Two Trucks
    Nice!
    You going to have front and back kits like the VLED tundra kit offers?
    corgimas and GuildOutfitters like this.
  3. Sep 2, 2021 at 6:21 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :drool::drool::drool:
    I'd probably be in for a set for some red. How hard is it to pull that bottom panel once the lights are in? I'm always fuckin around behind there haha.
  4. Sep 2, 2021 at 6:23 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Sep 2, 2021 at 6:24 AM
    kmorgan3
    Kyle
    PNW
    The great thing is that the VLEDs are modular, so you can expand our kit to run 4 lights without modification. Just so long as you don’t exceed 2A. Each light is 0.25A, so with 4 lights you would be within budget!
    Very easy. You just disconnect the lights from the harness and cut any zip ties you might have up there. I think I used 2 zip ties on each panel to tuck the wires. It would only take a couple of minutes to replace.
  6. Sep 2, 2021 at 6:37 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Sweet!
    Tacospike likes this.
  7. Sep 2, 2021 at 6:51 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    I'm interested!
  8. Sep 2, 2021 at 8:21 AM
    TacoinMD
    TacoinMD Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    Put me in for a set for my 2017.
  9. Sep 2, 2021 at 8:24 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Count me in. My wife hates the truck at night because of how dark it is and has been asking me to add some sort of ambient light source.
    JJ Diablo likes this.
  10. Sep 2, 2021 at 8:29 AM
    Kofe513
    Kofe513 Member
    Kolby
    2018 Inferno TRD OR DCLB
    These look awesome, keeping an eye on this thread for sure.
  11. Sep 2, 2021 at 8:30 AM
    su.b.rat
    su.b.rat broken truck
    same!
  12. Sep 2, 2021 at 9:06 AM
    Dustin.K96
    Dustin.K96 Well-Known Member
    Dustin
    2019 White Tacoma TRD OR
    Any pics of the blue LEDs? I would like to have the kind of "ice blue" color that the rest of the controls are when the headlights are on. But if it's a darker/deeper blue, I'll probably just end up going with white since it wouldn't match.
  13. Sep 2, 2021 at 9:08 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    You and me both. I’m curious to see how close we can get it.
    corgimas likes this.
  14. Sep 2, 2021 at 9:09 AM
    kmorgan3
    Kyle
    PNW
    You can look at the options here. I believe it’s a darker blue. We will be directing people to go through @memario1214 for the lights themselves. @Puppypunter is working on some strange disco project in his truck that might support RGBW.
  15. Sep 2, 2021 at 9:16 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Disco? Oh, ya!
    su.b.rat likes this.
  16. Sep 2, 2021 at 9:26 AM
    TacoMV
    TacoMV Well-Known Member
    Michael
    2021 TRD Off Road DCLB Voodoo Blue
    I'd be interested in a blue set for sure
  17. Sep 2, 2021 at 9:26 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Sorry, catching up here, but this might help?
    lighter blue:
    Regular blue
    I have parts arriving today, and I might be able to make this more tunable. The above pictures are the simplest forms of blue I can do, so kind of a “worst case” in a way.
    And I think I glanced @daveeasa wanting Purple?
  18. Sep 2, 2021 at 9:27 AM
    Dustin.K96
    Dustin
    LIT!.. literally.
    Barsoom and Skydvrr like this.
  19. Sep 2, 2021 at 9:30 AM
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    This is greatly interesting me.
  20. Sep 2, 2021 at 9:35 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I didn't have the answer either so I asked this morning. Here's what I got - Original question I asked is if they had photos:
