Fog Light Wiring Harness Info Needed
Discussion in 'Lighting' started by r_ben65, Feb 5, 2022.
  1. Feb 5, 2022 at 3:03 PM
    r_ben65
    r_ben65 [OP] Well-Known Member
    Robert
    2023 TRD Off-Road Lunar Rock
    Exhaust reroute, cargo mat, WeatherTech side window deflectors, glove box and center console organizer. RCI steel skid plates (engine, transmission, transfer-case, catalytic guards, fuel tank and differential), Total Chaos Bed Stiffeners, RCI rocksliders, Power Tray and Switch Pro, Taco Vinyl Pro Grill, Diode Dynamics SS3 amber fog lights. Front Runner load bars, Powerbrake D-Line Disc & Pad kit, Fox 2 inch lift kit with 2.5 coil-over, Taruca Rogue XC awning, Four Wheel Campers Project M.
    Hey everyone. I'm hoping for some help here. I've looked through the forums and not seen what I'm looking for or, more likely, not recognizing what I was looking at and missed it completely.
    I just got my 2022 Tacoma SR and want to add some fog lights. I've got the new fog light bezels on order and I'm looking at getting the Diode Dynamics SS3 LED Fog Light Kit and would like to wire it into an unused spot in a a switch panel.
    It does not appear that I got lucky and already have the wiring harness for the fog lights pre-installed.
    What I am looking for is a quality wiring harness for the fog lights. When I go online there is just too much info and I have no idea what it all means and would really like not to to buy the wrong product and only find out when I bring the truck in to get the stuff installed.
    Also, not sure if this will matter but I do intend to get a front bumper added in the future that will allow for the use of a 20 inch LED light bar and possibly a winch.
  2. Feb 5, 2022 at 8:31 PM
    caribe makaira
    Caribbean, Puerto Rico
    FastEddy59 and Key-Rei like this.
  3. Feb 6, 2022 at 12:55 PM
    r_ben65
    Robert
    Thanks for the info.
  4. Feb 10, 2022 at 7:40 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you're not pre-wired for fog lights then your best bet is to just purchase a standard wiring harness and have the wherewithal to turn them on/off when appropriate. We have all of the necessary bits for you to get set up on hand!
  5. Feb 10, 2022 at 12:38 PM
    r_ben65
    Robert
    I checked the other day. I think I'm pre-wired. Going to get a a signal stalk that has the fog light switch with it.
  6. Feb 10, 2022 at 12:50 PM
    caribe makaira
    Second photo is incorrect. Look at the radiator, bumper level for this:
    Black connector with green & white wire.
    FastEddy59 likes this.
  7. Feb 10, 2022 at 1:00 PM
    r_ben65
    Robert
    Yes, I have that. Thanks.
  8. Feb 10, 2022 at 1:02 PM
    caribe makaira
  9. Feb 10, 2022 at 1:06 PM
    memario1214
    Colton
    Missoula, MT
  10. Feb 10, 2022 at 1:07 PM
    caribe makaira
    Check for the fuse also:
  11. Feb 10, 2022 at 1:11 PM
    caribe makaira
  12. Feb 10, 2022 at 1:32 PM
    r_ben65
    Robert
    Seems Toyota was nice enough to provide me with a relay and fuse. Of course, it would have been nicer if I had checked beforehand...already bought the relay. Just purchased the harness and lights. Now to find the signal stalk and figure out how to remove a steering wheel.
  13. Feb 10, 2022 at 1:35 PM
    caribe makaira
    It's in the link I posted. Read it:D:rofl:
  14. Feb 10, 2022 at 1:39 PM
    caribe makaira
    OP, does your SR XP have remote alarm?
  15. Feb 10, 2022 at 1:48 PM
    r_ben65
    Robert
    Just what's on the Key Fob.
  16. Feb 10, 2022 at 1:57 PM
    caribe makaira
    There's a relay spot that might be available/useful above the fog relay.
    upload_2022-2-10_17-54-48.jpg I haven't tested it on an SR XP. It's meant to activate an extra horn (disk type) in case the main horn and /or buzzer wire are cut. The connector to the buzzer is next to the skid-control actuator (next to engine intake at the passenger fender)
  17. Feb 10, 2022 at 2:17 PM
    r_ben65
    Robert
    So, what you're saying is that Toyota decided to use that slot for something else but we don't know what?. Could they have just put a relay there but not used it? Sorry if I sound ignorant on this stuff but my car knowledge maxed out about 2 decades ago.
  18. Feb 10, 2022 at 2:24 PM
    caribe makaira
    I know what it's for, I don't know IF your SR XP has the wires to the system. Do you have a relay in that spot already?
  19. Feb 10, 2022 at 2:29 PM
    r_ben65
    Robert
    Yes, there is a relay in that spot already. I double checked with the diagram on the cover.
  20. Feb 10, 2022 at 2:44 PM
    caribe makaira
    Great!
    Is there a metal disk horn by the skid-control actuator?
