Fog light aftermarket switch/ adding fog lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cb.eng, Nov 20, 2019.
  1. Nov 20, 2019 at 5:14 AM
    cb.eng
    cb.eng [OP] Member
    Connor
    Lafayette, Louisiana
    2010 DCSB Prerunner
    4" Spindle, 5100's/B110, AAL
    Hey so I ended up just ordering a new harness and fog light assembly for the truck, installing said harness led to me discovering that the truck was prewired for the fogs. Only problem is a OEM switch is like 42$ and although that isn't a whole lot of money the idea of spending it when I have a perfectly good one kinda irks me. I pulled the male connections out from behind the little button cover on the dash and none of them fit the switch I have. Any way to splice something up to make it fit?
    Also, I have those two old fog light housings and conveniently a unused wiring harness. Could I wire that up where all 4 fog lights would come on using the same switch? I figured you guys would know, thanks
  2. Nov 20, 2019 at 5:18 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
  3. Nov 20, 2019 at 5:42 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I like to use the factory connections when possible, by the time you splice in and solder and heat shrink correctly. The time you spent and materials you could have just plugged in the factory switch. Pretty much break even imo and there are plenty of companies not that make the harness with the factory connection on the fog harness so you can use the factory connection that’s there already.
  4. Nov 20, 2019 at 5:51 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Boy, I'd pop for the OEM switch and consider myself lucky.
    The combination of wiring quality of the factory loom and the time required to bypass it makes the cost of the switch look like a bargain.
    Muddinfun and gotoman1969 like this.
  5. Nov 20, 2019 at 5:55 AM
    cb.eng
    cb.eng [OP] Member
    Connor
    2010 DCSB Prerunner
    Thanks for the advice
  6. Nov 20, 2019 at 9:15 AM
    caribe makaira
    Caribbean, Puerto Rico
    You could get connector 90980-11100 (male) and place the male terminals then mate to OEM connector (F16) then the wires from the male connector to your switch. Or get the 3M T-taps and go that route...
  7. Nov 20, 2019 at 9:40 AM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    Just go for the factory switch and not worry about cutting/splicing/soldering. You can find used ones on ebay, or new on ebay or Amazon
    Added bonus, the light color will match all your other switches/dash lights
    Peace of mind has a price and in this case, it's not that high.
  8. Nov 20, 2019 at 9:42 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Off topic: @caribe makaira what program are you using to pull those wire diagrams?
    -J
  9. Nov 20, 2019 at 9:45 AM
    caribe makaira
    Pull?...Adobe Acrobat Reader and MSPaint.
    JustAddMud[QUOTED] likes this.
  10. Nov 20, 2019 at 9:56 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Dang, I thought you had some program because your wiring diagrams are on point.
    -J
  11. Nov 20, 2019 at 10:08 AM
    Muddinfun
    Muddinfun Well-Known Member
    Aftermarket switches are internally connected differently than OEM fog switches. Here's a thread that goes into detail about the problems with trying to use an aftermarket switch with OEM wiring. Buy an OEM switch and plug it in. If you want to get something cool for your money, buy a FJ cruiser switch and a 6 terminal connector body. Depin the Tacoma connector, plug the 4 wires into the FJ connector, add 2 more wires, and you will end up with a fog switch with an indicator light that tells you when the fogs are on.
    https://www.tacomaworld.com/threads...o-existing-foglight-wires-2013-tacoma.630567/
  12. Nov 20, 2019 at 10:22 AM
    caribe makaira
    They are not...
  13. Nov 20, 2019 at 11:21 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    koditten likes this.
  14. Nov 20, 2019 at 12:03 PM
    caribe makaira
