Focal speaker upgrade question
Discussion in 'Audio & Video' started by CPTDJ2, Jul 11, 2012.
  1. Jul 11, 2012 at 8:58 PM
    CPTDJ2
    CPTDJ2 [OP] Member
    Jon
    NY
    2012 Tacoma SR5
    Is it worth it to upgrade to Focal IS 165 component speakers in the front doors if I don't plan on adding an amp or changing the factory head unit? I can spend about $300 for speakers right now. Just don't want to spend the money if there isn't going to be a noticeable difference in sound quality / overall volume w/o adding or upgrading other components.
  2. Jul 12, 2012 at 5:57 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    General rule is run external amp with components.
  3. Jul 12, 2012 at 6:04 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There should be an improvement,,, but a $300 improvement, not so sure. Personally I'd consider it if the components were a very efficient set.
  4. Jul 12, 2012 at 8:40 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    ^^This!
    If all you are doing is swapping speakers, you'll most likely get worse sound. The stock deck is tuned to make sure the stock speakers live a long life. If you remove the stock speakers, you'll see the small magnets(around 1" diameter). The stock deck is tuned to decrease bass as the volume goes up, so you don't blow the speakers. And with the small amount of power the stock deck puts out, the Focal speakers won't have the power to run properly.
    Not worth it, not $300 worth it for sure. Think about upgrading the deck, and getting an amp if you really want them.
  5. Jul 12, 2012 at 10:49 AM
    CPTDJ2
    CPTDJ2 [OP] Member
    Jon
    NY
    2012 Tacoma SR5
    Do you think I can get away with just adding an amp without a new deck? If so what specs should I be looking for? Does anyone ever just throw a set of 3-way speakers in and just disconnect the tweeter in the stock location as a cheap upgrade? Thanks everyone....
  6. Jul 12, 2012 at 11:33 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Woah woah woah......let's firm up a few facts here.
    First of all....it's not REQUIRED to run an aftermarket amp for components/aftermarket speakers.
    Yes, the stock headunit has limited power. So instead of throwing more power at a situation why not just run a more efficient speaker to get the MOST out of the available power?
    So quick lesson....let's say we had two pairs of speakers. One was 89db efficient and the other was 92db efficient (a 3db difference). The 92db efficient speakers if given 15 watts will be as loud as the other 89db efficient speakers when getting 30watts (twice as much!!!!)
    That being said, most Focal component sets are quite efficient. The ones you're looking at are VERY efficient at 92.6db efficiency. The stock stuff I'd guess is fairly efficient but hard to say how much. Probably around 90db but that's about it.
    I say buy them and you'll be happier with the sound. That much I know.
  7. Jul 12, 2012 at 11:56 AM
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    ^ what ItalynStylion said.
  8. Jul 12, 2012 at 2:36 PM
    Aw9d
    Aw9d That one guy
  9. Jul 12, 2012 at 2:55 PM
    dylan199
    dylan199 Well-Known Member
    I would buy a new hu before upgrading speakers.
  10. Jul 12, 2012 at 2:56 PM
    Aw9d
    Aw9d That one guy
    x2
    A new HU on stock speakers can make a world of difference.
  11. Jul 18, 2012 at 11:13 AM
    HDDetailing
    HDDetailing Member
    a amp with stock head unit and stock speakers would make a world of a difference too.
  12. Jul 18, 2012 at 11:19 AM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    im running the focals with amp, audio control and stock hu...sounds greeeeeat.would definitely sound better once the new hu is added.
  13. Jul 18, 2012 at 11:21 AM
    Aw9d
    Aw9d That one guy
    An amp on the stock speakers is worthless. They can't handle any power. A new HU will push the stock speakers more than enough.
  14. Jul 18, 2012 at 11:23 AM
    SoCalTacos
    socal
    yeah...no point in powering stock speakers...they're setup already for best sound...waste of money imo.
  15. Jul 18, 2012 at 12:14 PM
    HDDetailing
    HDDetailing Member
    I guess you guys are right lol. I did everything backwards. I havent upgraded my head unit but im running Focal polyglass component 165V30 Annivesary and Focal access 6.5 in the rear with alpine 5 channel amp and a Jl 10. I bet getting a head unit soon would change everything. Been eyeing out the Pioneer Avh-p8400bh but havent pulled the trigger
  16. Jul 18, 2012 at 12:17 PM
    SoCalTacos
    socal
    I'm setup the same way...stock hu but i added the audio control which makes tuning a little better. A new hu would make it drastically better.
  17. Jul 18, 2012 at 3:13 PM
    Aw9d
    Aw9d That one guy
    Yeah the stock HU is garbage. Get a nice aftermarket and you will never use a stock HU again. :)
  18. Jul 18, 2012 at 3:17 PM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    What do you consider a nice head unit? Im also in the market for an aftermarket hu and need some suggestions for a single din.
  19. Jul 18, 2012 at 3:18 PM
    SoCalTacos
    socal
    i wanna get the kenwood 6990 but these hu's nowadays are so damn expensive!ill just wait till the new models come out and take advantage of a discount on this one.
  20. Jul 18, 2012 at 3:20 PM
    Aw9d
    Aw9d That one guy
    Expensive now a days? Man you must not been in the audio game long :D When I was in HS a single din Pioneer top of the line HU was over $500.. Now you can get a DVD player that is amazing for $300. you can get decent single din's for $120.. Car audio is soooooooooo cheap these days.
    Depending on what you want I would look into Pioneer and Alpine. Those are the only two brands I will ever use when it comes to touch screen DVD HU's. I also avoid flip outs as the motors can wear out and once they go, the deck is worthless. Each person has the brand that they like and don't like.
