Foam coming out of my a/c vents
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dlm0369, Jul 27, 2018.
  1. Jul 27, 2018 at 3:42 AM
    Dlm0369
    Dlm0369 [OP] Member
    Danny
    Florida
    2002 PreRunner
    Help I have foam coming out of my a/c vents
    Anyone know why or how to fix
  2. Jul 27, 2018 at 4:16 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Normal. Both my Tacomas have done this. The foam is disintegrating because they are in fact 20 years old at this point. You can redo the seals with foam tape from Home Depot.
    DustStorm4x4 likes this.
  3. Jul 27, 2018 at 4:19 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Rabid mice nesting in the vents.
  4. Jul 27, 2018 at 4:30 AM
    Dlm0369
    Dlm0369 [OP] Member
    Danny
    Florida
    2002 PreRunner
    How easy/hard is this to fix
    I can’t seem to find any videos on this
  5. Jul 27, 2018 at 4:32 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    There’s several points in the ducting system that has foam sealing some type of duct. To get it all you’d have to remove the entire dash assembly which would take about an hour, it’s not that bad.
  6. Jul 27, 2018 at 4:32 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Honestly, is there even a reason to have it “fixed?” I had little pieces of black foam come out but I haven’t done anything about it for years.
    koditten likes this.
  7. Jul 27, 2018 at 4:34 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah I just let it happen. I get a piece maybe once every couple months. It doesn’t make a huge difference if you fix it anyway.
    This is a 20 year old truck with 20 year old problems.
    DustStorm4x4[QUOTED] likes this.
  8. Jul 27, 2018 at 5:12 AM
    Dlm0369
    Dlm0369 [OP] Member
    Danny
    Florida
    2002 PreRunner
    I get most of the air coming out of the side vents whenever I select the defrost setting so it is getting to be a problem
    No it is not a servo motor those are not making any noises
    Is there a good video or how to instructions for removing the dash ?
    Thanks Danny
  9. Jul 27, 2018 at 5:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s normal. Air does come out of the side vents when you have defrost on to also defrost the side windows, when I turn on defrost the breeze is relatively strong on those sides.
    DustStorm4x4 and truchador like this.
  10. Jul 27, 2018 at 6:31 AM
    tony2018
    tony2018 Well-Known Member
    Truthfully, it would be best to replace them. If you want proper airflow coming out of your vents instead of leaks behind the dash. I mean you want to cool the entire cab and if you have an extended or double you gotta think about your rear passengers getting cooled off too.
  11. Jul 27, 2018 at 6:46 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  12. Jul 27, 2018 at 8:51 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    That’s how it should be. It should explain this in the owners manual.
