FluidAmpr group buy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, May 28, 2023.
  1. May 28, 2023 at 2:48 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Need 100 people to get the ball rolling for FluidAmpr to R&D one for the 1GR-FE
    post up let’s go
    RockfordTaco2006 likes this.
  2. May 28, 2023 at 7:21 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Can you point to a thread or any empirical data to confirm the OE damper is hindering functionality? Sounds like a solution in search of a problem at least as far as our Tacomas are concerned.
    sparkystaco, b_r_o and Kwikvette like this.
  3. May 28, 2023 at 9:03 PM
    TacoTuesday1
    FL
    there’s plenty of positive feedback on the product all over the internet.
    the quality of the product is why they exist.
    We all know Toyota put cheap shit parts on our Tacoma.
    which continues with the 4th gen where they didn’t even put longer control arms or locker(s).
    The stock damper is a piece of rubber that can fall apart and is not very good. And cheap, before dealer parts depts mark up the fuck out of it.
    FluidAmpr is metal, silicone filled, with an inertia ring. Actual design behind it. The best one on the market, and the only one.
    What would you rather have?
    Toyota doesn’t put things like that because they don’t have the money.
    But owners do. It’s why we have upgraded headlights.
    and at $300-400, that’s a decent price, considering that’s the amount people happily trash on step bars that generally shouldn’t exist.
    So, what does it do? I’ll tell you, from experience knowing about it a long time, and having had it on a previous car.
    It dampens. And dampens well. Better than stock. Yet another bulletproof strong high quality part to put on your truck.
    Torsional vibration is the scientific term. From pulses of combustion. As the video and others state.
    Now why is this relevant?
    I will tell you how with my old car, and where the Tacoma is similar.
    I had a Unicorn. That is what it’s called. Because it’s the best B6 and most rare.
    avant/wagon (for practicality, looks, and better balance), 5V per cylinder 1.8Turbo I4 iron block, sport package with springs shocks bumpers and strut brace, 6-speed manual. Mechanical AWD (quattro) whose bias can be upgraded, and rear diff that can be made helical LSD. Throw on some good sway bars let alone suspension and you’re smoking everybody in a turn.
    The engine is not the most balanced. Being I4. That’s why car companies later on put (unreliable) balance shaft(s).
    V6’s do not escape this. See Mercedes.
    V6 is only one step away from I4.
    More balanced is things like opposing/boxer. Think Subaru flat 4, Porsche flat 6, V10, V8, V12.
    On that Audi, removing the front end is very easy. Needed for room to work.
    not on the Tacoma.
    changed my pulleys by sticking my hands in there.
    So on the Audi while I was in there for other shit like a timing belt, I installed FluidAmpr I got on a group buy.
    difference was night and day.
    Partly because I went away from the failure-prone dual mass flywheel (two piece) that slips and doesn’t give straightforward engagement, to the very popular single mass kit. Less dampening at the back.
    On a crank, you have dampening at the front, and the back. Especially in a manual.
    the back, is the flywheel. Which is part of why URD has a heavy one. A FluidAmpr would still yield benefit with that, or more so stock. Without a lot of labor to put one.
    That car, was not the smoothest at low RPM. Not the most usable. FluidAmpr made it way better.
    My Tacoma feels the same way. And low RPM here is even more important. Because this truck is mapped to provide instant torque.
    Off roading. Starting off. Driving efficiently. I can think of so many times this truck is low RPM.
    usability and control. Consistent RPM. Predictable RPM swings. FluidAmpr helps that too.
    it’s a benefit you would feel all the time.
    Look I can ask their engineering people if they think it would benefit. Hell if I was local and could loan them my truck to R&D, I would.
    If they made it, I’d buy it. And if there’s a benefit, I’d enjoy it. Without caring who else does.
    But unfortunately, for them to justify R&D cost, they’ve told me they’d need 100 people interested. Which really I don’t think is that hard to find.
    I’m sure at some point the stock damper will wear out. Don’t even wanna know what crap price Toyota will want for that hockey puck. I’d rather replace it with an actually good part.
    I’ve worked on cars professionally including V8 twin turbos that, stock, make a lot of power. And here is what I saw after 2 things. 1. Studying their manuals, 2. Working on them
    I saw they too, switched to a FluidAmpr
    What does that tell you about it’s benefit, that even more balanced V8’s (which are definitely more balanced than a V6) have also gone to them
    less vibration means less wear.
    Stock there is generally a feeling of shaking. Not major. Here is when:
    -coasting down to a low RPM, makes you want to pop out into neutral to smoothen
    -“lugging” (when really, you’re just a little low on RPM)
    Etc
    In my experience, FluidAmpr makes that go away.
    I think it would also make a clutch last longer. Because there wouldn’t be any shaking interfering with your feel of shifting.
    Or if I can figure out an adapter I would definitely try to put one on.
    im not gonna spend an hour on their website catalog but I’m sure they already make them for other 6cyl engines (aka a necessity)
    why hasn’t it been made yet for the Tacoma? Here’s why.
    People with other cars pushing them want good stuff. That’s it.
    but on the Tacoma lots of people piss in the gas tank and smile about it.
    But not everyone is like that. Some people actually do want cool shit. Like lockers, crawlbox, etc
    and attaching all that is still hooked up to your V6. Unless you swap it which is rare.
    Might as well make the most of what you have, whether you’re supercharged or not.
    and, supposedly it frees up some power. On the car I had it, I feel like it did. no regrets.
    And speaking of less dampening provided by a single mass flywheel, guess what kind of flywheel the Tacoma uses? Single mass
    So this is a way to get better damping, in a good way. A DMF would not be a good way.
    And, these trucks we depend on to work. Out on a trail somewhere or whatever. Not just back and forth in a city.
    FluidAmpr gained 12whp on a VW. With my stock unmoddable V6 I wouldn’t mind that.
    it depends on who you’re talking man. Walk outside, look at the road, watch some guy bounce on by factory shopping cart shocks step bars never been off road. Is he gonna care about a good damper? He doesn’t know how to spell damper, where to find it, or what it is.
    there is a lot of info out there on it.
    Now, does the torque converter dampen more on an auto taco? I don’t know.
    Mine is manual. I’d say that’s probably a big reason for lack of R&D on making a version for the Taco. Although other models have this engine (FJ, Runners)
    Because if you took ever manual 2nd genner and put them in a room, you’d probably have 3 people.
    Maybe FluidAmpr has enough success to where they don’t need the extra business that’d probably benefit the consumer more than them.
    I don’t have an iron block to be cool with wear.
    Making the engine run like butter isn’t just nicer on the street and traffic, but also towing or getting started moving off road. Having the engine happy to sit at any RPM and keeping it there, feeling it, and controlling it.
    That’s what I can tell you for now trying to come up with a quick response on my phone.
    Steves104x4 and shaeff like this.
  4. May 29, 2023 at 8:24 AM
    wi_taco
    Adam
    SE Wisconsin
    Quite the word salad you’ve spewed out with lots of dubious claims but still not showing me evidence a problem exists with the current OEM damper. Our 2nd gens are already some of the most reliable and long lasting trucks on the planet, this new damper is going to improve on that?
  5. May 29, 2023 at 10:53 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    It may very well be a good vibration damper..... it damps (quells) vibrations but it does not dampen anything.
    Unless it fails and silicone fluid leaks out and dampens (wets) whatever it touches.
    Yeah, that may be nitpicking, but if one is making a lot of claims, let's at least stick with correct terminology.
    As for me, I won't spend 25 minutes watching a video claiming to fix a problem that I'm not at all sure exists.
    sparkystaco and wi_taco like this.
  6. May 29, 2023 at 12:34 PM
    TacoTuesday1
    FL
    I think so.
    There’s vehicles from the same year, same mileage also on the road today
    running better because of the product
    these trucks are still on the road because
    1. People upgrade them
    2. People maintain them (it takes work)
    just like any other old vehicle on the road
    FluidAmpr is metal encased welded shut, I don’t think it would ever fail. Vs a stock damper with rubber that eventually will fail.
    that’s just one recent video on it. There’s many out there.
    I know in my case having had good experience owning a FluidAmpr I don’t need the above video at all to know it’s good.
    Steves104x4 likes this.
  7. May 29, 2023 at 12:54 PM
    wi_taco
    Adam
    SE Wisconsin
    Still no evidence of an existing problem. Got it, thanks.
    MHersh328 and sparkystaco like this.
  8. May 29, 2023 at 1:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ve gotta side with tt1, on this. The 2.7 turbo boys need this but that’ll never come.
  9. May 29, 2023 at 1:04 PM
    TacoTuesday1
    FL
    how am I supposed to measure that?
    slap on a FluidAmpr that doesn’t exist to compare before and after?
    I see they’re already going bad on 5VZ-FE V6
    when that time comes why not replace it with something better
    If I was the Guinea pig and noticed no difference I’d be happy to admit
    1. it’s like $300-400
    compared to $2k to put Sherpa racks on the shell and roof or something, that’s nothing
    or the labor saved DIYing your own front end maintenance already being in that area (water pump pulleys etc)
    if I could wave a magic wand to make one exist, send it to you for testing to compare before/after and hopefully be a noticeable upgrade, I would.
  10. May 29, 2023 at 1:52 PM
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
    Literally not a failing part on the tacomas, the frames are gonna rust to shit before the balancer fails.... Don't see any reason to put it onto a truck, if you're looking for smoothness you're driving the wrong vehicle...
    whatstcp, wi_taco and sparkystaco like this.
  11. May 29, 2023 at 2:15 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm only buying one if it comes with a cool sticker for the back window
  12. May 29, 2023 at 3:14 PM
    TacoTuesday1
    FL
    I believe they do come with stickers
    MSgt O likes this.
  13. May 29, 2023 at 8:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I wanted this a long time ago. I ended up getting the other brand that I cannot remember right now. Lol.
  14. May 29, 2023 at 8:53 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    ati
  15. May 29, 2023 at 11:10 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Rattler
  16. May 30, 2023 at 8:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This one!
    whatstcp and Speedytech7 like this.
  17. May 30, 2023 at 8:21 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Not needed.
  18. May 30, 2023 at 8:30 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    The last 5vz rolled out in the US in early 2004, nearly 20 years ago. ~19 years out of a constantly rotating part is a pretty good run me thinks. I get wanting something like this product, but at the slow stock speed these engines are limited to without top end building it seems like a solution in search of a problem. The harmonics produced at lower RPM by these engines are plenty in control by the cheap (in comparison) OEM harmonic balancer. As evidence many are lasting into the 400,000mi range without any main or rod bearing failure.
    wi_taco likes this.
  19. Jun 6, 2023 at 7:46 PM
    TacoTuesday1
    FL
  20. Jun 6, 2023 at 9:25 PM
    averagejoeaz
    averagejoeaz New Member
    Looks pretty awesome.
