Fluid Film or Rust Check
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buster888, Oct 28, 2018.
  1. Oct 28, 2018 at 10:57 AM
    Buster888
    Buster888 [OP] Well-Known Member
    Nova Scotia
    Tacoma TRD Trail Teams Sport
    Bed mat, Extang Cover, Shorty antenna, Pop'n Lock, Interior and Plate LEDs.
    Hi everyone. I have a 2014 Tacoma Sport Full Cab Manual Trans short box with 22000 miles. I live in snowy Canada but fortunately they don't salt the roads in the rural area I live in. Trying to decide between Fluid Film or Rust Check. What do you guys (gals) think is best. TIA
  2. Oct 28, 2018 at 11:18 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If they do the same thing, go with the less expensive. The important thing is just keep up with it. Keep the metal treated so rust can not damage the metal.
  3. Oct 28, 2018 at 11:35 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I use fluid film, never heard of rust check
  4. Oct 28, 2018 at 11:40 AM
    spitdog
    Rust check is a service that sprays your undercarriage for a fee. Where fluid film is a diy, I guess you would say.
    https://www.rustcheck.com
    If I took the $140.00 that one yr of rust check would cost and applied it to buying fluid film. That would buy me 3 gal of FF, that would last me 9 yrs.
  5. Oct 28, 2018 at 11:47 AM
    Buster888
    Nova Scotia
    Fluid Film isn't stinky oil stuff and easy to apply. Jack it up, power wash, dry then spray it on.
  6. Oct 28, 2018 at 11:49 AM
    spitdog
    I’m a fluid film junkie. Been using it for yrs.
  7. Oct 28, 2018 at 11:53 AM
    Buster888
    Nova Scotia
    Gonna stick with Fluid Film. Thanks guys!
  8. Oct 28, 2018 at 1:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    In the sandwiched areas of the frame near the front of the truck, I use chain/cable lube that I buy at Wal-Mart. It's a little lower viscosity than Fluid Film and really creeps into those areas nicely. When the solvents evaporate, you're left with a nice sticky oil in those spots. I think Fluid Film is a little thick for those spots unless you spray it on when it's nice and hot outside. I use Fluid Film too, but I supplement with the chain/cable lube.
    I did this for years on my 98 T-100 and the rockers and cab corners were solid when I sold it this last spring. I also hose up into the weep holes in the pinch seam on the rockers.
    I hate to admit it, but up until last year I didn't know much about Fluid Film. Good stuff, just a little thick for all areas in my opinion.
  9. Oct 28, 2018 at 3:26 PM
    spitdog
    A little trick is to warm it up before you spray it on. I use a undercoating gun, warm it up and it comes out as a fog.
  10. Oct 28, 2018 at 3:28 PM
    Markcal
    Markcal Well-Known Member
    Just curious of everyone's opinion about coating the frame once before winter, as opposed to coating twice a year (before winter and in the spring). I have used FF for about 4 years and have only applied it before winter, but curious if it's worth the twice a year application.
  11. May 3, 2020 at 12:08 PM
    Sliding West
    Sliding West Mad Props!
    Dave
    Vancouver
    20 AG Pro
    SPC UCA Westcott Design Front Icon Progressive Add a Leaf Greenlane Step Slider Retrax Pro Retractable Cover Weatertech Visors EGR Hood Deflector Meso Headlight Trim Plates Meso Red Start Button Meso Vent rings Meso Blackout Start and 4X4 ring Meso Total Tail Stage 1 Meso V5 Turn signals Meso Puddle Pods Meso Overhead Hexrack Meso door handle covers VLED Vanity, License, and Plate reverse lights Tacoma OEM bed step Raptor Lights Meso Ultimate Red/White Interior Lights KTJO Grab Handle KTJO Door Pocket Lights Ice Blue Durabump Front SCS SR8 17x8.5
    So what did you do? FF? I'm in Vancouver and have found a Rust Check in Pemberton. Hoping to pick up new truck soon!
  12. May 3, 2020 at 12:28 PM
    Sliding West
    Dave
    Vancouver
    20 AG Pro
    Actually its a "Corrosion Free".... Internet seems to say good things in general. And who doesn't believe the internet?
  13. May 3, 2020 at 1:25 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    So while we're on this topic, how or what does anyone suggest to apply fluid film? I've usually gone to rust check, but really thinking about diy.
    I've got a cheap 100psi compressor, so what else I need?
  14. May 3, 2020 at 1:58 PM
    spitdog
    I would use the new wool wax ( same as FF but thicker and doesn’t smell) .
    I use 1 undercoating gun with compressor
    2 - qt plastic bottles that attaches to gun
    1 - rattle can FF with 360 degree head for tight spots/ holes in frame
    or you can buy a kit here. https://www.kellsportproducts.com/
    Marc70[QUOTED] likes this.
  15. May 3, 2020 at 3:02 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Sounds like you already knew what to do,so why are you asking ?
  16. May 3, 2020 at 8:37 PM
    Sirnick88
    Sirnick88 Well-Known Member
    Nick
    2011 TX Pro, 6spd MT, boosted
    URD mk3 s/c, Dobinsons snorkel, Ultragauge, Stoptech rotors, TRD ceramic brake pads, softopper, anytime backup camera, anzo black headlights, oh, and vehicle OCD organizers!!!
    @Marc70 I wore rubber gloves, sprayed it on my fingers, and got to wiping. In hindsight I should've sprayed it...but I became intimately familiar with the underside of my truck ;)
    Marc70 likes this.
  17. May 5, 2020 at 9:45 AM
    Bit
    Bit Member
    1996 Silver Tacoma
    Side question regarding Fluid Film. Have any of you had your truck painted after using Fluid Film? My truck got hit and is in the body shop but they won't paint it because of the Fluid Film. They say that it will mess up their painting systems in a major way. I told them that I can get it off, but they said that even a small spec hiding in a nook or cranny would be an issue. Have any of you dealt with this before? I called Fluid Film and they said they hadn't heard of this, but a few auto body shops near me said that yes it is an issue, although they aren't familiar with Fluid Film. Any info would be great. Thanks.
  18. May 5, 2020 at 9:58 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
  19. May 5, 2020 at 10:04 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    If you buy fluid film in the cans it works great for spraying inside of the frame
  20. May 5, 2020 at 10:07 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
