fluid film on rust??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nvtaco, Nov 11, 2013.
  1. Nov 11, 2013 at 5:35 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    07 dcab rust on underside and frame. Will the rust continue if i keep fluidfilm on it year round? Already tried por15 with no luck.
  2. Nov 11, 2013 at 5:50 PM
    Whitster
    Whitster Well-Known Member
    Whit
    Golden, CO
    '09 AC w/SR5 & TRD, 6' bed
    Never tried it for rust, I know it lubes like crazy.
    Have a friend that builds specialty bodies and he swears by it for rust prevention, goes through about a case a month.
  3. Nov 11, 2013 at 6:07 PM
    nvtaco
    Vancouver, BC
    I guess i should have titled this post "fluid film sprayed overtop of existing rust", just want to see if it will stop any further rusting?
  4. Nov 11, 2013 at 6:18 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  5. Nov 11, 2013 at 6:26 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I'll let you know after this winter, I just sprayed it two weeks ago on my frame.
  6. Nov 11, 2013 at 6:34 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    I've read it will stop rust from progressing.
  7. Nov 11, 2013 at 6:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If POR-15 (with proper prep) didn't stop it, then coating it with fluid film is not going to do any good.
  8. Nov 11, 2013 at 6:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I might spray some on my sentra, I'll let you know if it helped in april.
  9. Nov 11, 2013 at 6:35 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I have a 1950 dodge with no rust on the frame. My grandpa used to wipe it down with used motor oil once a year. It's free, and it works.
  10. Nov 11, 2013 at 6:39 PM
    nvtaco
    Vancouver, BC
    I followed their instructions to a "t" and one winter later the rust showed through, almost like it washed off or something!
  11. Nov 11, 2013 at 6:49 PM
    nvtaco
    Vancouver, BC
    Thanks after reading their quote i wonder if its more of a rust prep for removing rust?
    Quoted directly from fluid film
    "Will FLUID FILM remove rust?
    FLUID FILM is not formulated to remove rust. However, if applied over existing rust, it will stop it immediately from spreading further. FLUID FILM will penetrate rust and rust scale to the base metal, loosening and easing in the removal process."
  12. Nov 11, 2013 at 6:52 PM
    nvtaco
    Vancouver, BC
    That was quite popular, gasstations sprayed used oil directly to the underside. It worked, but think of the environmental downside.
  13. Nov 11, 2013 at 7:06 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I like this method.
  14. Nov 11, 2013 at 7:35 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I guess both removal and to stop it. That's what I get from it. I would think you don't have to remove it unless you want to since it stops its progression.
    I've read a few members on here have used it and are happy with it. I'd give it a shot.
  15. Nov 11, 2013 at 7:42 PM
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    Wire brush the entire frame, apply a good rust converter with a brush and then spray paint with a rustoleum or similar. I use old motor oil over top of that. Then spray inside of frame with Eastwood internal frame coating. Takes days but really worth it. Although the fluid film will at least protect your frame through winter
  16. Nov 11, 2013 at 8:44 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Oil gets returned to the earth whence it came? We don't mine this shit on mars. Have you ever worked construction and paved anything? It's always funny to me how green weenies cry about a single drop of oil on the street, but don't think about what the street is made out of. :rolleyes:
  17. Nov 11, 2013 at 9:18 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    LOL!
    Had a group making a big deal out of our spare and scrap traffic signal poles.
    Galvanized poles... "Oh, they have to be covered, the zinc will contaminate the river"
    What about the signal poles and street light poles that are not in the yard?
  18. Nov 11, 2013 at 9:47 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Most of tbe bunch lack common sense and logic.
  19. Nov 11, 2013 at 10:09 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Deniers
  20. Nov 11, 2013 at 10:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    We're not talking about your post count...
