Fluctuating idle and bucking when driving
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jon901, Oct 3, 2024.
  1. Oct 3, 2024 at 2:02 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    Hey guys so I’ve made this post before but I have an 01 SR5 and it was running good then all the sudden it started with the idle fluctuating between 600-800 rpm and shifting into 1-3rd gear it bucks (occasionally). I’ve hooked it up to a scanner and everything looks great so I’m at a loss
  2. Oct 4, 2024 at 9:35 AM
    bobastruck
    bobastruck Active Member
    Skye
    ID
    2004 Toyota Tacoma DBL Cab 3.4l
    I would check these three things. MAf Sensor, Trans Fluid (When's the last time you did a flush and drain?), and your throttle body. Check the throttle adjuster. I would remove your intake, get some throttle body cleaner, some plastic brushes and rags. Clean the carbon up. This is the cheapest and quickest way to do it.
    Jon901[OP] likes this.
  3. Oct 4, 2024 at 9:54 AM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    I will try that today, I replaced the MAF but I didn’t mess with anything else
  4. Oct 4, 2024 at 11:38 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I had a friend who's '98 Tacoma SR5 (V6) had similar symptoms. His were resolved with a new TPS, and new fuel injectors. We did both at the same time and so we can't be sure which of the two solved it.
  5. Oct 4, 2024 at 11:43 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How old are the spark plugs?
  6. Oct 4, 2024 at 12:01 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    I haven’t changed them but they looked good when I pulled them
    Steves104x4[QUOTED] likes this.
  7. Oct 4, 2024 at 12:02 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    I just ordered my TPS as a shot in the dark so hopefully that will fix it
  8. Oct 4, 2024 at 12:32 PM
    Red_03Taco
    Jerad
    OEM Toyota hopefully? You can easily check yours with a multi-meter. The FSM has a testing procedure outline in it.
  9. Oct 4, 2024 at 1:40 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    Yes I ordered OEM and put it on( I also cleaned the throttle body while I was there) and it seems to be idling somewhat better but it is still bucking
  10. Oct 4, 2024 at 2:22 PM
    Red_03Taco
    Jerad
    Could be your injectors then causing the bucking. Have you been able to identify an RPM range the bucking occurs in? My buddy's only bucked between 2000-3000 RPM, above and below that range it ran perfect.
    Also have you scanned for any codes?
  11. Oct 4, 2024 at 5:07 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    Yes that’s the same range mine is bucking, and yes I’ve scanned it a few times and I haven’t gotten a code
  12. Oct 4, 2024 at 5:12 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If it's a 4 cyl and the valves haven't been adjusted then that's a problem waiting to kill the engine.
  13. Oct 4, 2024 at 5:21 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    Any ideas for where to look if it’s a 6cyl?
  14. Oct 4, 2024 at 5:28 PM
    Red_03Taco
    Jerad
    Leaning towards your injectors since it's mirrors my buddy's previous issues. But any history of touching your IAC?
  15. Oct 4, 2024 at 5:36 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    I haven’t messed with the IAC I had just thought it would be throwing codes if it was that
  16. Oct 4, 2024 at 5:37 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I had a ‘97 4Runner with that same 3.4L engine. It acted exactly as yours did. I finally replaced the coolant sensor on the middle front of the intake manifold for like $20. That thing was giving whacked information to the computer which wad screwing with idling and stalling. It’s easy to replace with little to no additional parts needed removed. I would try that.
    se7enine, Jon901[OP] and Steves104x4 like this.
  17. Oct 4, 2024 at 5:38 PM
    Red_03Taco
    Jerad
    If the idle is still not perfect and you have no vacuum leaks, then I'd start with carefully trying to clean the IAC. If idle is good I'd focus on cleaning or getting new OEM injectors
  18. Oct 4, 2024 at 6:07 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    Thanks I’ll try that!
  19. Oct 4, 2024 at 6:07 PM
    Jon901
    Jon901 [OP] Member
    2001 Silver SR5
    I will try to clean it tomorrow, thanks!
