Floor Jack for 3" lifted Tacomas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, May 3, 2016.
  1. May 3, 2016 at 8:43 AM
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    With the addition of my new lift I'm now having to do (what I deem to be) unsafe things to get the truck into the air. Basically, my current jack needs some wooden blocks stacked to get the truck off the ground and it makes me pretty nervous when I have to do it.
    I have the Icon Extended Travel set and the Dakar leaf pack out back. My frame sits about 17" off the ground and I need to raise it quite a bit to get the front tires in the air. The rear can be raised by jacking up from the diff so that's not really an issue as it gets the truck in the air just fine. For the front though, it requires a good bit more lift from the jack.
    What are other lifted Tacoma owners using?
  2. May 3, 2016 at 9:49 AM
    conifers4
    conifers4 Tired and Broke
    Brian
    Long Island, NY
    2010 DCLB 4X4
    Short section of 4X4 post between jack and frame... Done:fingerscrossed:
  3. May 3, 2016 at 9:56 AM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
  4. May 3, 2016 at 10:32 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Looks a little sketchy but I'll take your word for it that it works.
    Kinda hoping to find something with around 24" of maximum lift. Anything like that? I like the wood block idea but it still worries me.
  5. May 3, 2016 at 10:38 AM
    Arailt
    Dallas, TX
    2019 GX460
    I have some 3 ton high lift stands that I use to hold the weight in the air. The jack holds well, but I wouldn't trust it to carry the weight for extended periods of time, especially if I'm underneath.
    EDDO likes this.
  6. May 3, 2016 at 10:45 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Perhaps not the info you're looking for, but I use sliders and a hi-lift. Once we lift our trucks, any factory stuff becomes obsolete. If anything you could use the factory jack under the LCA (front) or the rear axle (rear) in a pinch, but using the frame is no longer feasible. I have a 3 ton floor jack from harbor freight in my garage as it was the highest lifting jack I could find in my budget and it still struggles to life the tires off the ground without using wood to supplement.
  7. May 3, 2016 at 10:46 AM
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
  8. May 3, 2016 at 10:51 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  9. May 3, 2016 at 10:54 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I use the same but make sure to place supporting jacks as a safety precaution.
    conifers4[QUOTED] likes this.
  10. May 3, 2016 at 10:55 AM
    K.Ray
    East TN
    None
    Yep. 100lbs of amazing.
  11. May 3, 2016 at 10:55 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
  12. May 3, 2016 at 10:55 AM
    GA-3RZFE
    GA-3RZFE Well-Known Member
    2000 Taco 2.7L 3RZFE SR5 manual
    Complete rebuild at 197k miles
    Harbor Freight has a low profile jack with 23 3/4" of clearance (I have this model) and it works great.
    bmorewineguy and Crom like this.
  13. May 3, 2016 at 10:56 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    The front A arm and the rear axle are still relatively at the same height which is where the factory jack is designed to lift from. Not the frame.
    EDDO likes this.
  14. May 3, 2016 at 10:57 AM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    The harbor freight one works for me. 3 ton with a 24 inch lift height. (could be 21 3/4 inch but I cant remember)
  15. May 3, 2016 at 10:58 AM
    cj13058
    Oregon
    This one is the one.
  16. May 3, 2016 at 10:58 AM
    K.Ray
    East TN
    None
  17. May 3, 2016 at 11:01 AM
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    I don't remember if I have the exact same one but it is an Arcan 3 1/2 ton low profile racing jack I got from costco for $99 several years back. I love that jack and would highly recommend it.
    bmorewineguy and EDDO like this.
  18. May 3, 2016 at 11:08 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I have same issue. I'll be buying the HF low profile-long reach one.
  19. May 3, 2016 at 11:12 AM
    Detective_Dan
    Colorado Springs
    I know they used to sell them at Costco so it's probably the same one. Best jack I've ever owned hands down
    rob1208[QUOTED] likes this.
  20. May 3, 2016 at 11:20 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Kinda looking at this one since it's a bit lighter. Would be nice if it had just a wee bit more lift.
