Floor Jack and Jack Stand Recommendations?***NOT A HI-LIFT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by My Truck, Oct 3, 2017.
  1. Oct 3, 2017 at 4:48 PM
    My Truck
    My Truck [OP] Well-Known Member
    Bay Area, CA
    2016 SR DCSB 4x4 Super White`
    Yes, I used the search function first, but could not find a definitive answer to my question.
    Looking for recommendations on a floor jack and jack stands.
    Also, what is the proper weight rating to buy for the weight of our trucks?
    I currently have a 4-ton bottle jack, but would like something a little easier to use for projects.
    Also would appreciate correct protocol for where to jack and place jack stands.
    First project I have to tackle once purchase is changing out body mount bushings.
    Appreciate any input.
    Thanks
    EDIT***Hi-Lift is not an option. Please dont make this thread a hi-lift debate, just looking for honest and good minded recommendations.
    remgu2000 and DustStorm4x4 like this.
  2. Oct 3, 2017 at 4:59 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    your owners manual would be great help for where to lift from.
    I have a few different things I use.
    https://www.amazon.ca/Powerbuilt-64...qid=1507074939&sr=8-8&keywords=jack+and+stand
    Which is pretty good. If I'm doing single location type work I just use this. You can lock it in as a stand so its safe to work on. Can be used under teh rear axle from either side or from the front using the owners manual suggested places
    I also have all the safejack attachments like the extension, axle attachment and flat base that I use with both a 6ton bottle jack and have an adaptor to use it with the factory toyota jack. So i keep it in the truck if needed.
    I have two 3ton aluminum stands i got from princess auto (basically canadian harbour freight)
    and just got a 3 ton floor jack from costco they had for $119, has an extension part that nets you 28inches of lift (reduced to 2.5tons)
    3ton is really better to use, but the 2.5 is enough if you're doing corners of the truck. Under the rear diff I use the 3ton option of the floor jack.
    BigRus75 and DustStorm4x4 like this.
  3. Oct 3, 2017 at 5:04 PM
    Joe23
    except it won't if he doesn't have sliders or an aftermarket bumper.
  4. Oct 3, 2017 at 5:04 PM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Great advice if you have sliders and aftermarket bumpers. If not there are no jack points on a stock Tacoma.
    EDIT: Sorry, I was beaten to it!
    blackrifle76 and Joe23 like this.
  5. Oct 3, 2017 at 5:19 PM
    Clearwater Bill
    Billy
    Largo Florida
    Well I can safely say not to get a low profile race jack.
    Last car had to go on 3"ramps to get that jack under it. On my lowly little 5 lugger it will barely get the tire off the ground.
    Joe23 likes this.
  6. Oct 3, 2017 at 5:24 PM
    My Truck
    Bay Area, CA
    Great advice...thank you!! Will look into all those options.
  7. Oct 3, 2017 at 5:26 PM
    My Truck
    Bay Area, CA
    Blktre[QUOTED] likes this.
  8. Oct 3, 2017 at 5:26 PM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    I use this low profile jack from harbor freight. It fit under my wife's old Mini, and would easily get my 2nd gen with 255s with a 2.5" lift off the ground. I'll probably get another this year during Black Friday sales.
  9. Oct 3, 2017 at 5:31 PM
    Joe23
    he won't have any from factory...
    and I'm under the impression he wants to change tires and what not so lifting off the tire isn't a great option. Besides hi lifts are so unstable and dangerous. I try to use one as little as possible. Although yes they do come in handy.
  10. Oct 3, 2017 at 5:34 PM
    My Truck
    Bay Area, CA
    ^This
    Lures & Liberty likes this.
  11. Oct 3, 2017 at 5:34 PM
    My Truck
    Bay Area, CA
    Thanks
  12. Oct 3, 2017 at 5:39 PM
    backcountryj
    Jonathan
    GA
    Maybe this is a dumb question, but what's wrong with the stock body mount bushings?
  13. Oct 3, 2017 at 5:40 PM
    My Truck
    Bay Area, CA
  14. Oct 3, 2017 at 5:55 PM
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Anything made by Hein-Werner will last you a lifetime. The cylinders are rebuildable too so it should be the last jack you ever buy. When my HF low pro jack wears out, that's what I'm getting
  15. Oct 3, 2017 at 5:56 PM
    backcountryj
    Jonathan
    GA
  16. Oct 3, 2017 at 6:04 PM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Something OTC or hein-warner. Though tractor supply has some decent low priced stuff also.
    mach1man001 and DustStorm4x4 like this.
  17. Oct 3, 2017 at 6:30 PM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    Back ordered
    I have that same HF low-profile jack. Good jack. Little poor maneuvering on my rough driveway.
  18. Oct 3, 2017 at 7:31 PM
    My Truck
    Bay Area, CA
    Haha nice! Ya need to get that fix done asap. Mine sound horrible.
  19. Oct 3, 2017 at 8:09 PM
    AA79
    AA79 Well-Known Member
  20. Oct 3, 2017 at 10:41 PM
    Nguyen916
    Nguyen916 Member
    Fishers, IN
    2016 Super White Tacoma TRD OR
