Flathood swap, underhood bracing glue broken. Fixes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brendon_ak, Jun 14, 2020.
  1. Jun 14, 2020 at 6:30 PM
    brendon_ak
    brendon_ak [OP] Member
    Brendon
    2017 AC 6MT, 1979 Volvo 245T
    debadged
    Hey everyone,
    First post here, great community. Just finished swapping hoods with someone so my TRD Sport can have the clean flathood look versus the scoop. On the drive home I noticed the hood vibrating or billowing slightly. I detailed the truck today and noticed the underhood bracing that's glued to the hood itself is broken. Possibly from slamming the hood? Either way, can I fix this myself or is this body shop territory? If I'm able to squeeze glue in there I could use the hood to pressure the brace while the glue cures, if that makes sense?
    Ideas?
    Seneca likes this.
  2. Jun 14, 2020 at 6:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Superglue.
  3. Jun 14, 2020 at 6:36 PM
    Flowie
    Flowie Well-Known Member
    2017 TRD OR
    None yet
    Epoxy
  4. Jun 14, 2020 at 6:39 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Bodyshops use 3M panel bonding adhesive
  5. Jun 14, 2020 at 6:40 PM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    Welcome. A couple tips... First off, I would at a minimum talk to the person you swapped with and ask if they had the same issues you are mentioning (I would imagine they did). I would then ask why they didn't bring it up during the swapping process.
    Next, get used to searching because many times you will wait longer for people to respond or get irrelevant information when there are probably multiple threads you can check out. Here is just one that I quickly found by typing in "hood glue" into the search thing. Look through the other threads if this one doesn't get you the answer you need.
    https://www.tacomaworld.com/threads/hood-glue-fix.626552/
    Bleep100 likes this.
  6. Jun 14, 2020 at 6:42 PM
    Flowie
    2017 TRD OR
    None yet
    boston23 likes this.
  7. Jun 14, 2020 at 6:58 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    @brendon_ak
    Bet that guy you swapped with doesn't know a thing about the separation, that's OK we know people who know people.
    Whitetail Assassin likes this.
  8. Jun 14, 2020 at 7:04 PM
    brendon_ak
    Brendon
    debadged
    Thanks for the replies. I'm not new to forums by any stretch. The search function here is different than some of the others I'm used to. In addition to that I wasn't sure what the correct terms were with regard to the bracing, glue, etc. Also if this is a systemic issue then I'll just deal with it I suppose, sounds like that's not the case.
  9. Jun 14, 2020 at 7:35 PM
    QuicksandYoda
    QuicksandYoda Well-Known Member
    Shane
    '19 quicksand 4x4 OR
    I had the same thing happen with my 2019 OR hood. As it was under warranty, I took it to the dealer. The dealer said they had about a half dozen cases of the same issue, all under warranty. They fixed it, no further issues, and no indents from whatever they used pulling the hood inward towards the stiffner. In any case if I were you, I'd call your local dealer, explain your situation, I'm sure they've dealt with it, and ask what they use. Before you say well what if they just use the same shit that didn't work before. I was told they used something different that Toyota had sent them spefically to deal with the issue.
  10. Jun 14, 2020 at 9:08 PM
    brendon_ak
    Brendon
    debadged
    Thanks for that info. I'm not trying to start some kind of argument but if this is a relatively "known issue" (I hate that term) I can only hope a company like Toyota with their six sigma philosophy would have a proper fix. Hood is from a 2018 so fingers crossed they'll fix it!
    QuicksandYoda[QUOTED] likes this.
  11. Jun 14, 2020 at 9:10 PM
    Flowie
    2017 TRD OR
    None yet
    Dont be a chikkin. Just glue it w some epoxy and be done with it. You got this.
  12. Jun 14, 2020 at 9:11 PM
    brendon_ak
    Brendon
    debadged
    I was sold the wrong oil filters so I've got a reason to head to the dealer anyways. If I don't have to pay for the fix I'm not going to. Not afraid of fixing it myself, I'd rather exhaust all no cost options first.
    Big tall dave likes this.
  13. Jun 14, 2020 at 9:14 PM
    Flowie
    2017 TRD OR
    None yet
    I jave so much gluenits rediculous. Gorilla glue, wood glue, elastomerics, 100% silicone, rtv silicone, hot glue, super glue, paste, microscope glue, epoxy... Thats what having kids will do to you. Glue collecting.
  14. Jun 14, 2020 at 9:50 PM
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    This was their first fix luckily though they realized they used the wrong glue (After I said something about the EPU crap they used) so after removing what you see here they replaced it with something that looks like bubble gum and is glued about 50% of what the factory glue job should be.
  15. Jun 15, 2020 at 12:36 AM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    Seam Seal in caulking tube from auto paint store, sticks good dries hard, get some touch up spray paint too.....
  16. Jun 15, 2020 at 1:49 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Known issue, dealer will fix if you’re under warranty. If not, be nice and maybe they’ll throw you a bone
  17. Jun 15, 2020 at 5:45 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I thought the proper product was 3M NVH; a urethane product, not epoxy.
    Skydvrr likes this.
  18. Jun 15, 2020 at 5:52 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Big tall dave and splitbolt like this.
  19. Jun 15, 2020 at 6:12 AM
    Shellshock
    Iowa
    It’s an issue with the earlier trucks, there’s some threads on it and how to fix it. I had mine fixed by the dealer, they just put more goop in there
  20. Jun 15, 2020 at 6:32 AM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    This is a systemic problem with many gen 3 hoods that do not have a scoop. That's the main reason I bought a Sport with a hood scoop rather than an Off Road without one. The person who traded hoods with you was most likely well aware of the problem and knew that he would be getting a more structurally sound hood. Here your go...the 1098 post thread on hood vibrating. https://www.tacomaworld.com/threads/hood-vibrating.402060/ The only good fix is to use the special two part 3M adhesive and then it doesn't work all of the time.
    This is the best fix. Mazda admitted that they had a problem long before Toyota did.
    https://mazda.oemdtc.com/272/hood-vibrates-when-driving-at-highway-speeds-2013-2014-mazda-cx-5
