Flat towing truck with an RV.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Parker123, Mar 28, 2020.
  1. Mar 28, 2020 at 5:44 PM
    Parker123
    Parker123 [OP] Member
    Stewart
    Yucca valley
    2004 SR5 TRD 4x4
    Does anyone have any experience and/or info flat towing their Tacoma’s? I’m in the market for an RV for work. Looking into both class C’s and Class A’s with either diesel or the triton V10 drivetrains. Any info on them would be much appreciated as well.
    Article below says not to flat tow many Toyota trucks ( not specifically Tacoma’s ) and was wondering why and if I’d be ok as my truck is a manual.
    https://www.edmunds.com/car-buying/what-cars-can-be-flat-towed-behind-an-rv.html
    thanks!
  2. Mar 28, 2020 at 5:56 PM
    ccraider
    ccraider Well-Known Member
    Carson City
    You need a driveshaft disconnect even with a manual trans. The bearings need lube even in the neutral position. Do a search and there’s more info on it. I’m going through this now, adding a disconnect to the driveline.
    Also make sure the RV you buy can tow at least 5000 lbs, some only tow 3500 lbs max.
  3. Mar 28, 2020 at 6:01 PM
    Parker123
    Stewart
    Yucca valley
    2004 SR5 TRD 4x4
  4. Mar 29, 2020 at 4:04 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    that is actually wrong. the front does not require a "pump" as it's an enclosed differential. The front driveshaft from the transfer case does NOT spin unless put into 4wd (at least on my '04 ADD/push-button). the front wheels continuously turn regardless of 2wd or 4wd
    also this:
    https://www.toyotanation.com/threads/towing-a-tacoma-4x4.165169/post-2079975
  5. Mar 29, 2020 at 4:32 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    ok, so the diff being locked to the front right CV operates a pump to lube?
    my other point still holds true tho. OP also has an '04 just manual trans. even with J-shift, the actuator has to tell the front DS to engage otherwise it spins free, so no worries
  6. Mar 29, 2020 at 5:16 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I flat tow my truck all the time. I have made a 600 mile trip every year for the last 12 years. Plus miscellaneous other trips, for a total of probably close to 10,000 miles, all flat towed. Never had a problem. I put the transmission in neutral, the transfer case in 2 hi and turn the key to unlock the steering wheel.
  7. Mar 29, 2020 at 7:16 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Nice, a Skoolie. You got a built thread on that?
    You even kept the strobe on the roof haha
  8. Mar 29, 2020 at 8:32 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Yeah you need to to some work on it first putting it in neutral in an auto/manual is no bueno
  9. Mar 29, 2020 at 9:46 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Transfer case in 2wd and disconnect the rear drive shaft is all you have to do.
    Bivouac and chrispchicken9 like this.
  10. Mar 30, 2020 at 6:50 AM
    Gyrkin
    Wyoming
    If you have a manual transmission you don't have to disconnect the drive shaft.
  11. Mar 30, 2020 at 8:26 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    Driveline disconnect is the way to go. Mine has been towed 25000 miles.
  12. Mar 30, 2020 at 10:15 AM
    Gyrkin
    Wyoming
    Manual or automatic transmission? I have flat towed mine close to 10,000 miles without a driveline disconnect. Just put it in neutral and unlock the steering wheel.
  13. Mar 30, 2020 at 10:28 AM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Many newer class-C's come with a 7500 pound hitch - although you'll want to independently verify you're under all the weight limits. Class A's have 15 more HP but tend to weight significantly more so you'll be going slower if that matters.
    Although flat towing isn't recommended there's no technical reason a 1st gen manual transmission taco can't be flat towed and scores of people have logged significant miles with no issues. Often times the market is small enough that car makers don't want to do the testing to officially allow it.
    Gyrkin likes this.
  14. Mar 30, 2020 at 12:21 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
  15. Mar 30, 2020 at 1:09 PM
    Gyrkin
    Wyoming
  16. Mar 30, 2020 at 1:28 PM
    Parker123
    Stewart
    Yucca valley
    2004 SR5 TRD 4x4
    Thanks for all your info and help guys. I’ll plan on doing a driveshaft disconnect then. Looks like superior driveshafts makes one specifically for my truck.
    thanks again!
  17. Mar 30, 2020 at 2:42 PM
    aroma
    Snottsdale AZ
    Auto
  18. Mar 30, 2020 at 2:44 PM
    Parker123
    Stewart
    Yucca valley
    2004 SR5 TRD 4x4
    Mine is a manual trans. Does that mean I don’t need the disconnect? The owners manual says I do/not to flat tow..
  19. Mar 30, 2020 at 2:48 PM
    aroma
    Snottsdale AZ
    Be ready for spending some coin. The set up on my truck was 5k. disconnect, diodes/lighting/baseplate/tow bar/brake buddy. luckily the PO spent the money. My truck weighs 3600 and I tow it with my old 28' class a chevy 454. I tow it as empty as possible. If you want more opinions on what to buy, PM me. Start with a budget.
    ~V~ likes this.
  20. Mar 30, 2020 at 3:26 PM
    Gyrkin
    Wyoming
    All I can say is I don't have one and I have flat towed it for a total of close to 10,000 miles over the course of 12 years, and never had a problem. I'd think if it was going to cause some sort of problem it would have by now.
