Flat towing a 1980 cj7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tyler7544, Oct 3, 2020.
  1. Oct 3, 2020 at 11:01 PM
    Tyler7544
    Tyler7544 [OP] Well-Known Member
    L
    The most unique and special Tacoma
    Hey guys, i am looking to flat tow my jeep 3 or 4 hours from storage to my place. Bit of background on my truck, I have a 2006 auto v6 4x4 with the tow package.
    I don't have much experience towing, but have pulled a couple ~15' trailers with my truck in the past. My jeep has a tow bar that bolts onto the bumper and is already set up, I just need to wire up the taillights.
    I know the basics of towing that much, like pull the driveshafts, and leaving my truck in 4th and under 55mph and expecting my braking distance to be substantially increased. What I'm curious is to whether you'll have any tips or advise before I go up there, to help keep me from learning things the hard way.
  2. Oct 4, 2020 at 5:21 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    If the Jeep is a standard, no need to drop the driveshaft. Just keep it in neutral. Definitely keep it in 4th. Keeping it under 55, while saving some gas, isn't a requirement when towing.
    Is the Jeep registered? It would have to be in massatooshits if it's wheels were on the road being towed.
  3. Oct 4, 2020 at 6:10 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Speaking of CJ7s, Wheeler Dealers just did one on their show this past week. The Jeep's mechanical bits were in pretty good shape, but it needed some rust restoration.
    TACOMA2NDGEN likes this.
  4. Oct 4, 2020 at 6:21 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That looks just like my old '85
    Transfer case in neutral, tranny in neutral, should be good to go, yes?
  5. Oct 4, 2020 at 6:22 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    PS get pictures, we all love to see our Tacomas pull Jeeps around:D:thumbsup::rofl:
    igno1tus and Tyler7544[OP] like this.
  6. Oct 4, 2020 at 7:31 AM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I'm lazy. I would burn the $60 to rent a car trailer from uhaul. Yeah, it is heavy, but it has surge brakes on it and you won't have to worry about flat towing. You would likely need additional straps or chains if the ones that come with the trailer are not large enough. Just don't tell uhaul what you are putting on there in case they decide to crunch some numbers.
    https://www.uhaul.com/Trailers/Auto-Transport-Rental/AT/
    Muddinfun likes this.
  7. Oct 4, 2020 at 7:44 AM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, Uhaul will ask you what you’re hauling. Tell them it’s a red ‘89 Nissan Sentra 4 door. They won’t rent to you if you tell them it’s a yellow ‘04 Mazda RX8.
    ABNFDC likes this.
  8. Oct 4, 2020 at 9:29 AM
    Tyler7544
    L
    I'm starting to think renting a trailer is a overall better idea too. Not only because of the additional brakes and less headache, but I'm bringing it home to start overhauling the drivetrain, and as such its not going to run for months. If I just rent a trailer that's far cheaper than insuring and registering it.
    Kind of obvious now that i saw it, but i guess I've had the flat towing idea in my mind for a couple years now
    ABNFDC and Muddinfun like this.
  9. Oct 4, 2020 at 10:47 AM
    ABNFDC
    Granite State
    Looks like the curb weight of a CJ7 is <3K, so that+ the 2K pound car trailer is easily manageable by the Tacoma. Depending on how large your tires are, you still may have to provide some additional tie downs. If you went the trailer route, I would swing by a local u haul place to check out what they come with.
    Piece of advice with the rental-they tend to rob you blind on one way rentals. You may want to rent from your start point, go pick up your jeep, and then return at the same place. Play with the numbers to see what works for you.
  10. Oct 4, 2020 at 11:00 AM
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    This. Super good advice. It will almost definitely be cheaper to pick up and return to same place. Make sure you tell them you're just using it around town too they might try to up charge if they know you're planning on logging some miles with it.
    Also, if you're not use to towing often this gives you the added benefit of being able to get some practice driving with the trailer while it's unloaded before you have strap the jeep to it.
    ABNFDC[QUOTED] likes this.
  11. Oct 4, 2020 at 11:00 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I towed a CJ5 1200 miles with nothing but a tow bar and transfer case in neutral and a set of brake lights on a 2x4 strapped to the rear end of the jeep.
  12. Dec 2, 2020 at 7:14 PM
    Coach.SS
    Coach.SS New Member
    Shawn
    Spitdog, what year is your CJ and what TC? I’m in Oklahoma and going to California to buy a 1980 CJ7 this next week. Hear lots of opinions.
