Flag pole mount to bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacokm, Aug 1, 2013.
  1. Aug 1, 2013 at 8:31 PM
    07tacokm
    07tacokm [OP] Member
    Kyle
    NJ
    07 SR5 V6
    gta radio car kit flag pole mount in bed pirate flag
    i couldn't find a thread on this topic has anyone mount a flagpole to their bed in one of the corners closest to the cab either the passenger or driver side any help would be appreciated thanks!
  2. Aug 1, 2013 at 9:33 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  3. Aug 1, 2013 at 9:34 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If the intent is to fly the flag while driving, I wouldn't do it.
    There is a LOT of drag from a flag. Even at low speed (30mph) I bent a steel bracket that I made for my bike riding Patriot Guard escorts.
    The composite bed is durable, but I wouldn't trust putting that much stress on the mounts.
  4. Aug 1, 2013 at 9:58 PM
    ziggynagy
    Stoughton, MA
    ^ Not if you're flying the stars n stripes. Physics ain't gonna drag down 'Murica!!
    oretaco, TacoJake95, Shayne and 2 others like this.
  5. Aug 1, 2013 at 10:19 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Science. Fact.
  6. Aug 1, 2013 at 10:31 PM
    minuteman
    minuteman Member
    n
    Merica!
  7. Aug 17, 2013 at 3:26 PM
    meckleystephen
    meckleystephen My Taco is Bi-Winning!!!!!!!!
    Stephen
    York, PA
    2013 Toyota Tacoma Off Road
    3 Inch Toytec lift,Blacked out badges
    I did this today. I got my hands on some extra bed cleats from my buddies totaled taco :(.
    I figured I could use them to make a flagpole. Its a 2 x 6 in the bed with each end cut to a 10 degree angle. I purchased the flagpole holder for 11 bucks at home depot. The only thing that was necessary in order to make the pole fit in the holder was to grind the nub on the bed cleat hope this helps. I also am going to drill holes on both the passenger side and drivers side in order to fly two flags.
    catattacksdog likes this.
  8. Nov 5, 2015 at 10:10 PM
    polov1
    polov1 Well-Known Member
    vrver
    vrevre
    Doing this for the 10th and following these instructions here. How'd the flag hold up above 50 mph?
  9. Nov 5, 2015 at 11:05 PM
    JcDillon
    JcDillon Well-Known Member
    Somerville, Tn
    2012 access cab taco
    Bed Lights, Camper Shell w/ led light strip, HUWMS, K&n 63 series CAI, mbrp s5326al exhaust, ride rite dual control airbags.
    Outstanding flag.
  10. Nov 6, 2015 at 7:39 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    ill take pics of my set up when the weather clears...
    Setup i use for tailgating and driving down the road are the same except the tailgating one has a 15' flag pole :D
    So i got the 2" pole, conduit strap and some of the channel nuts...drilled hole through the conduit strap, ran bolts into nuts and TADA! I also used a sheet metal screw through the middle of the strap into the pole to keep it from going up..that sucker wont go anywhere! and for extra stability you could use another strap at base of the pole with screws tapped into the bedside
