FJ Transfer Case Swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco1419, Dec 29, 2022.
  1. Dec 29, 2022 at 6:12 PM
    Taco1419
    Taco1419 [OP] Member
    2016 Gray Tacoma TRD Off-Road 4dr
    >6 in Rough Country Vertex Coilovers w/ Reservoirs >285/70r17 Atturo Trail Blade XTs on 17x9, -12mm Pro Comp Series 1 >5.29 Nitro Gears >Aluminum Mishimoto Radiator w/ 12in fan and HPS Coolant Hoses >S&B Cold Air Intake >Speedform Throttle Controller
    I am going to swap my tcase out for a manual tcase. The only issue I am getting to is what do I do about the front ADD that is electronically controlled and how do I swap it out or eliminate it completely. I'm guessing the rear locker, MTS, and Crawl Control would be fine since they only require the tcase to be in 4LO. Any info helps. Thanks in advance.
    I have a 2016 TRD Off-Road as well btw.
  2. Dec 29, 2022 at 6:21 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    To eliminate use fj cruiser awd diff tube.
    I used a momentary rocker switch to control.my frond add on my conversion (2nd gen).
    But thats probably the least of the problems you will run into.
    hiPSI likes this.
  3. Dec 29, 2022 at 6:24 PM
    Taco1419
    I never would've thought of that. But now what do I have to do to clear the PCM/ECU of the front ADD? Take it to a shop or just reprogram?
  4. Dec 29, 2022 at 6:25 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Most people add a switch but theres like three 3rd gens that are swapped, because its not really worth the effort.
    hiPSI likes this.
  5. Dec 29, 2022 at 6:33 PM
    Taco1419
    Thats kinda what I've been seeing but I also have a down tcase and new something to get my 4WD back
  6. Dec 29, 2022 at 6:39 PM
    JoeCOVA
    Joe
    Colorado Springs
  7. Dec 29, 2022 at 6:45 PM
    Taco1419
  8. Dec 30, 2022 at 6:48 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
  9. Dec 30, 2022 at 6:58 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I hate the the ADD in my 2 gen with a passion but there is no way it's worth the aggravation you have to go through to change it. I plow with my truck and push snow I don't try to throw snow into the woods at 30 mph so I use low range the ADD is a hateful device but I just live with it.
  10. Dec 30, 2022 at 7:17 AM
    Taco1419
  11. Dec 30, 2022 at 7:18 AM
    Taco1419
    Yeah I get it, but I work remote and make my own hours so I have the time to kill lol. If I didn't have the time or want to I'd leave it alone
