FJ steel rims with 2020 compatibility
Discussion in 'Wheels & Tires' started by hella_tacoma, May 26, 2020.
  1. May 26, 2020 at 2:45 PM
    hella_tacoma
    hella_tacoma [OP] Well-Known Member
    San Francisco, CA
    2020 SR AC 2.7L Black
    I'm in process of upgrading my truck and wanted to do FJ cruiser style steelies - https://www.roadreadywheels.com/products/2005-2019-16x7-toyota-tacoma-steel-wheel-rim
    Can anybody confirm if these will fit my 2020 Access Cab 4Cyl 4WD?
    Picture of my stocks (they have 30 stamped on them) but after searching around looks like they are 25mm offset.
    The steelies I'm going with are 30mm and this will potentially push my wheel inside 5mm? Should I use a spacer to push them out or something like that?
    I will be pairing them with 265/75/16 BFGoodrich KO2's.
  2. May 26, 2020 at 3:35 PM
    hella_tacoma
    San Francisco, CA
  3. May 27, 2020 at 8:46 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I run winters on FJ Steelies, Model: 42611-35330
    They are 17x7.5 15mm offset, 4.5 backspace, round holes all around.
    memtaco and hella_tacoma[OP] like this.
  4. May 28, 2020 at 4:38 PM
    hella_tacoma
    San Francisco, CA
    ok so 30mm offset is ~4.5inch backspace and it seem standard for FJ cruiser rims.
    do you know by any chance what are stock rims (photo in first post) measure backspace and offset?
  5. May 28, 2020 at 6:38 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
  6. Sep 2, 2020 at 6:04 AM
    RD8761
    RD8761 Member
    2019 Quicksand Tacoma TRD Off-Road
    vicali,
    What size tires are you running on the FJ Steelers?
  7. Sep 2, 2020 at 8:14 AM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    255/70R17 Blizzaks.
  8. Oct 13, 2020 at 3:34 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Question: What are you running for a spare, and will it fit under the bed?
  9. Oct 13, 2020 at 8:07 AM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Spare is factory 265/65R17
    Winters are 255/70R17,
    Summers are 265/70R17
