FJ OEM Auxiliary Lights Switch W Rigid LED bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yarro, Aug 21, 2014.
  1. Aug 21, 2014 at 4:20 PM
    yarro
    yarro [OP] Well-Known Member
    Tacoma, WA
    11' TRD Off Road DCSB
    TREX Eyelids. RIGID Fogs Toyota Skid Plate. AVID Light Bar. Rigid SR 20"Combo LED bar OEM Toyota Running Boards, LEER Canopy RIGID Roof Rack - COMPLETE. FJ cruiser Switch panel install in center isle. (4 new slots for OEM switches) Glove box & Center counsel Lighting with amber switch.
    UPDATE ON LAST COMMENT
    Hey Guys so here's the Question
    I am planning to use the part #'s below which are from the FJ to wire in to my Tacoma and hook up a Rigid LED bar or off-road lights. WILL THIS WORK?
    1. Outside wiring: PT297-35070-LH Fog Light Harness
    2. Inside wiring: PT297-35070-SH -Switch Harness
    3. Light switch: PT297-35070-AS - Auxiliary Lights Switch
    4. Relay: PT297-89016 Fog Relay
    It appears that it should be work just fine as long as its all done correctly however before is start I need some advice and tips and pics.
    I've seen a some threads here and there but nothing 100% saying it will work or pictures of how to.
    http://zlachevsky.wordpress.com/2013/05/31/piaa-fog-lights-install-on-fj-cruisernon-invasive/
    http://www.fjcruiserforums.com/foru...-roof-top-light-switch-oem-part-number-2.html
    has a nice explanation but its for the FJ not the Tacoma, is it the same under the hood?
    Has Anyone done this mod, and if so can you direct me to a good source or pictures? and or give me some tips
    Much Appreciated my Tacoma family
  2. Aug 22, 2014 at 5:02 PM
    yarro
    Tacoma, WA
  3. Aug 26, 2014 at 12:09 PM
    yarro
    Tacoma, WA
    anyone?
  4. Aug 26, 2014 at 12:29 PM
    MassEffect
    MassEffect Active Member
    Do you already have frog lights on your truck?
  5. Aug 27, 2014 at 1:00 AM
    yarro
    Tacoma, WA
    I do
  6. Aug 27, 2014 at 6:45 AM
    TheTacoAdventurer
    TheTacoAdventurer Well-Known Member
    Boston, MA
    2018 DCSB TRD OR
    Forever modding!
    I'm going to assume with that switch, you are trying to put it here:
    If so, I believe the switch should work as I put a A-TRAC switch in there. I'm pretty certain the A-TRAC switches for the Tacoma and FJ are the same and I had to just shave off some of the plastic on the side of the switch casing.
    For wiring, I did not use those wiring harnesses that you plan to. I have an additional fuse block that I connected to. I did use a fog relay for the lights too. Worked out pretty well. I have 2 led bars runnning off the same relay with no issues at all. The trick part for me was wiring up the relay, but my Toyota part department was very helpful with telling me exactly how to wire it up.
    Hope I helped. Please let me know if you have any questions.
  7. Aug 27, 2014 at 9:23 PM
    yarro
    Tacoma, WA
    I'm planning on trying something entirely new and putting the switch here:D264011d1396010796-fj-taco-oem-switch-bezel-project-image.jpg. It will be somewhat painful getting all the wires from the switch.. but my biggest concern is connecting the wires to the right locations, which I have seen only a diagram on a FJ forum, and the Tacoma guys I haven't seen use the above parts. usually someone uses the relay and harness that comes with the lights.. :confused: I would imagine its being similar to those but not much of a electrician so I want to be confident before I start wiring things...
  8. Aug 28, 2014 at 4:00 AM
    boggle
    boggle Active Member
    VT
    TRD
    Switches would look good there, but I could never put them there as I would end up gumming them up with spilled coffees at some point.:(
  9. Aug 28, 2014 at 4:51 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Very nice switch location. I like that a lot.
  10. Aug 29, 2014 at 10:53 AM
    yarro
    Tacoma, WA
    Thanks guys, def know what you mean by being worried on coffee spills. I don't drink much coffee or when I do I put it in the rubber cups in my spill proof Starbucks cup. If your interested in the other half of the panel to do this mod. I still have it available. see here.http://www.tacomaworld.com/forum/2nd-gen-tacomas/310799-fj-taco-oem-switch-bezel-project.htmlIf anyone else have seen someone use these parts to hook up lights please leave a reply here with a link or pics . anything would help ;)
  11. Sep 8, 2014 at 9:06 PM
    yarro
    Tacoma, WA
    jacoblb likes this.
  12. Sep 11, 2014 at 3:11 PM
    yarro
    Tacoma, WA
    Pics of diagrams ill be using
    jacoblb likes this.
  13. Nov 19, 2014 at 12:04 PM
    yarro
    Tacoma, WA
    UPDATE :I order a Rigid 20" LED bar and it came with all wires needed to wire lights along with a relay and everything else I was going to do . I suggest just ordering their wiring and saving yourself the headache. the only thing I will not be using is their switch, I will still be wiring it to the OEM FJ Switch mentioned above
  14. Nov 19, 2014 at 12:10 PM
    yarro
    Tacoma, WA
    bar installed, and secured. (thanks Chas of MRT for great deal on the RIGID GEAR. all I have left to do is change out the switch to my location in the pic in first posts;) will update with pics soon
  15. Jun 14, 2017 at 5:28 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Thread revive
    So I want to hook up the rigid light bar and harness to an oem switch (fog light). There's a red, black and blue wire for the rigid switch. How do I go about wiring this?
  16. Jun 15, 2017 at 6:48 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    a stock OEM fog light switch has four pins, the top two are the switch and the bottom two are for the light in the switch. with that said hook the red and blue wires to the top two, order does not matter. black wire is not needed as it just provides a ground for the light in the Rigid switch
  17. Jun 15, 2017 at 7:16 PM
    lemon177
    Matthew
    Oahu
    And if I want the switch to light up, just splice tge two bottom green wires it into the neighboring fog switch?
  18. Jun 15, 2017 at 7:54 PM
    muisejt
    YMM
    08 TRD Sport DC LB
    that or use the wires from the connector behind the blank
