FJ Cruiser Transfer Case Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cjsur57, Jun 7, 2019.
  1. Jun 7, 2019 at 10:30 PM
    Cjsur57
    Cjsur57 [OP] Member
    2005 speedway blue DCSB Tacoma TRD OR
    2005 Tacoma TRD-OR DCSB AUTO
    Hi I’m a new member, I want to share my latest fix. I couldn’t find a lot of info on doing the FJ Cruiser t-case swap on an auto without cutting, welding, or altering the factory shifter.
    After cutting the floor, you need to take a little off the shifter box for your stick to clear in the 4H position.
    There is a little guess work involved, but it was easier than I thought it would be. After quite a bit of research, I finally got the t case and tackled it in just over 9 hrs. By my self, with beer breaks.
    I don’t have pics, but I sealed the floor with with a shifter seal from a Chevy square body 4 spd and bonded it to the floor with automotive seam sealer. It’s been almost two months and it is doing its job. I’m contemplating doing some fiberglass work on the center console and installing a proper boot to blend it all together. I got another project ahead of me, but I will follow up with some pics of the final product!
  2. Jun 7, 2019 at 10:52 PM
    Cjsur57
    Cjsur57 [OP] Member
    Mully likes this.
  3. Jun 7, 2019 at 10:54 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    baller. Shot caller. Nice work.
    Cjsur57[OP] likes this.
  4. Jun 7, 2019 at 11:00 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    There is a huge thread on here about this somewhere on here. Going to be one of my mods. Looks like you did a real nice job. Welcome to TW.
  5. Jun 7, 2019 at 11:42 PM
    Cjsur57
    Cjsur57 [OP] Member
    Hindsight, I would have done the twin sticks in the cup holders, but I needed to get it out of 4wd. Long story short it got stuck in 4H and after racking my brains for awhile, finally brought it to the dealer. They claimed it was the actuator (1200 dollar dealer item only) on the t-case, quoted me 10 hrs of of labor (splitting the case). So I found an actuator on eBay for 700, and installed it in about 15 minutes by separating the motor from the shifter shaft. So I told the dealer to go screw and I went along with the manual case swap!
    Mully likes this.
  6. Jun 8, 2019 at 5:48 AM
    Taco'09
    Taco'09 Well-Known Member
    Please-oh-please do a write-up on this with as many details as possible because the FSM and parts diagrams leads one to conclude that he Tcase has to be split to remove the actuator because of two clips on the actuator's shift rod inside the case. And many have shied away from attempting doing anything from the outside due to problems with getting it "reclocked".
  7. Jun 8, 2019 at 6:06 AM
    Gopher TRD
    Gopher TRD Well-Known Member
    Justin
    New Jersey
    2014 TRD Sport
    Nice work. and I am glad you didn't skip out on a very important step - beer breaks.
    Cjsur57[QUOTED][OP] likes this.
  8. Jun 8, 2019 at 6:51 AM
    Cjsur57
    Cjsur57 [OP] Member
    You do not need to split the case to to change the actuator, you just leave the old shift rod in.
    You have to take the little triangle cover off the actuator, and you will see a round gear. Pull out the gear and you can slide the actuator off of the shift rod.
    SR-71A likes this.
  9. Jun 8, 2019 at 6:55 AM
    Cjsur57
    Cjsur57 [OP] Member
    Here you can see the little triangle plate you to remove. The gear just kinda rides on the triangle plate.
  10. Jun 8, 2019 at 7:00 AM
    Taco'09
    Thanks, but I read all kinds of horror stories about not being able to get that round gear back in the identical spot. I have not attempted one so don't know.
  11. Jun 8, 2019 at 7:07 AM
    Cjsur57
    Cjsur57 [OP] Member
    You’re talking about timing the actuator.
    Just make sure the actuator is in the same position as the transfer case (2H or 4H). Now for that little gear, you really can’t put that wrong, it will only fit in one spot and will only go in one way
  12. Jun 8, 2019 at 7:12 AM
    Cjsur57
    Cjsur57 [OP] Member
    On my pickup the actuator was not the problem. I believe it was either a bad wire or something internal in the case not allowing it to shift.
  13. Jun 8, 2019 at 7:45 AM
    Taco'09
    I'm going to print this and put in my Tcase file.
  14. Jan 7, 2022 at 8:58 AM
    95_Taco123
    95_Taco123 Active Member
    1995 Silver Tacoma
    Well done OP! I'm looking to do this to my 4.0 auto taco. Do you have any more details on how to do it? Does the fj case bolt right up and all you need to do is cut a hole for the J shifter? Any detail is much appreciated. I hate my electronic shifter!!!
  15. Jan 7, 2022 at 11:43 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :cookiemonster:
    Cover hole with doggo dish
    TBH, BEST MOD EVARRRRRRRRR
  16. Apr 21, 2022 at 8:46 AM
    Airdreams
    Airdreams Well-Known Member
    Boise
    2005 access cab
    Softopper, 2022 TRD suspension, 2020 TRD Wheels, Pioneer stereo, K&N
    Now this is even more confusing than trying to figure out Why you would put in A manual transfer case but then still have to put in an actuator.... Obviously there's something I'm missing...
    No matter how you look at it I've never been wrong when I say all of these new vehicles with electronic everything are nothing but garbage! And somehow they want us to change over to all electric vehicles.. This way there's nothing manual about them whatsoever and supposedly nothing can ever go wrong with them. Yeah right, I don't believe it at all.
    TodayWasTHeDaY likes this.
  17. Apr 23, 2022 at 4:11 AM
    llamasmurf
    Wes
    Northern Ontario
    I think you are missing something, because I removed all the 4x4 electronics from my rig with this mod.
    I have no actuator?
    ADD and 4x4 ECU deleted.
    :cookiemonster:
  18. May 20, 2023 at 11:49 AM
    bamafan2k1
    bamafan2k1 Member
    reno
    14 White Taco TRD
    How did you accomplish this? I am doing a sas kit and an fj case with a taco box and want to get rid of all that too. I can seem to find this info. Everyone talks about rst but that dude is non existent anymore
  19. May 20, 2023 at 1:06 PM
    Pittsy
    Pittsy Ex car guy, currently in rehab
    Davis
    Cave Creek, AZ
    07 DCSB 4x4, 20 DCSB PRO 6MT
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Swap
    Just buy an FJ front diff tube with shaft and transfercase. Done. Countless people have completed that on here, myself included.
  20. May 20, 2023 at 1:09 PM
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
