(FIXED: Wheel Bearings)Hum sound while driving as if I have off road tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grunt66, Dec 28, 2017.
  1. Dec 28, 2017 at 8:29 PM
    grunt66
    grunt66 [OP] Well-Known Member
    Vista, CA
    08 Tacoma DBL cab 4X4 off road
    I am already thinking my problem might be a wheel bearing but I like to see what other forum members think.
    Vehicle: 2008 Tacoma double cab off-road 4x4
    Mileage: 69,000
    Tires: Michelin Ltx Defenders 2,000 miles since installed.
    Recent maintenance: Oct of 2017, drained and filled rear, front, and transfer case with Royal Purple gear oil. Rear diff is a locker.
    Problem: Over the past month while driving there is a hum that sounds like I have off road / larger tires while driving. The sound is not that loud but is audible enough that my wife noticed it while driving the Tacoma. There are no secondary sounds or issues. The sound increases with speed just like the sound of over sized off road tires of lifted trucks I have ridden in. My Michelin LTX defender tires were replaced under warranty back in July of 2017 due to cracks in the sidewalks. The old tires where quiet and the new ones where quiet when installed and the old ones had 35k miles when replaced.
    The truck has only been driven approx. 2,000 miles since July. Researching this issue has me thinking it is a wheel bearing. Over the next several days I will check the tire pressure, lift the truck and check for play by grabbing the front wheels. I have read the wheel bearings can still be bad if no play is evident. My Tacoma is only driven on surface streets and is not driven off-road. From my understanding the front wheel bearings are a weak link and can go bad around the 60k mileage area.
    I appreciate any all comments.
    ***Update 1/23/18:
    I installed two new front wheel bearings and it has fixed my problem. Interesting enough both front wheels had no play.
  2. Dec 28, 2017 at 8:30 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Does it do it in 4 wheel drive
    JoefromPTC likes this.
  3. Dec 28, 2017 at 8:33 PM
    grunt66
    Vista, CA
    I have not checked it in four wheel drive, only in 2wd.
  4. Dec 28, 2017 at 8:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    It was my wheel bearings doing that. Quiet as a mouse since installing @BamaToy1997 wheel bearings some time ago
    BamaToy1997 and WSW3 like this.
  5. Dec 28, 2017 at 8:36 PM
    Bishop84
    Bishop84 Well-Known Member
    Wheel bearings are very common, I'd get it repaired sooner than later. Need a press for any of the 4 bearings.
    WSW3 likes this.
  6. Dec 28, 2017 at 8:36 PM
    grunt66
    Vista, CA
    How many miles were on your Tacoma when you changed them out?
  7. Dec 28, 2017 at 8:37 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    80kish. Edit: turning 140,000k, shortly and silent
  8. Dec 28, 2017 at 8:56 PM
    grunt66
    Vista, CA
    I am looking at buying the whole assembly from the forum member.
    BamaToy1997 likes this.
  9. Dec 28, 2017 at 9:12 PM
    2007tacoman
    2007tacoman Member
    2007 White Tacoma TRD Off Road
    Just replaced both my front bearrings and what you're explaining sounds exactly what I was experiencing? When you let off the gas does your truck coast or is there a noticeable decline in speed? Mine were so bad that whenever I let off the gas, it wouldn't roll as expected, felt like the brakes were being applied.
  10. Dec 28, 2017 at 9:12 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    You need to check this, could very well be your needle bearing...
  11. Dec 28, 2017 at 9:25 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Check to see if your tires are cupped. Had this happen on my Honda Accord after about 3-4k miles of buying new tires. Drove me nuts till I figured it out. I was told that my alignment was outta wack and it cause my tires to cup. I got an alignment done, and convinced Costco to swap out the rears that were cupped under roadhazzard warranty (they rock), and all was well after that. Two months later, traded it in for my Taco! :)
  12. Dec 28, 2017 at 9:30 PM
    grunt66
    Vista, CA
    What symptoms would manifest outside of the current hum when I engage the 4wd system?
  13. Dec 28, 2017 at 9:40 PM
    Jaggerbub
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    If the hum goes away, it's your bearings.
  14. Dec 29, 2017 at 1:21 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    If your talking about the wheel bearings, then that's not correct.
    If the hum goes away when you put it in 4wd, it's likely your front driver's side differential bearing.
    That can be fixed with this: https://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    A good test for the wheel bearings is to find a road that has some good sweeping bends/turns, and if it's a bearing, it will usually quiet down when the load is taken off of it. A right turn will load up the left side, and vise versa.
    The front differential bearing issue will usually appear when you lift it, so I'm thinking that's probably not your issue, but some guys have had the issue with no lift. I'm betting it's a wheel bearing.
    su.b.rat and BamaToy1997 like this.
  15. Dec 29, 2017 at 4:22 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    69000 seems pretty early for wheel bearings, but not impossible. They are really easy to verify, drive about 35mph and swerve right and left if the noise comes and goes bingo, wheel bearings.
    You should also consider U joints, they will growl pretty loudly.
    svocobra and mabepossibly like this.
  16. Dec 29, 2017 at 5:12 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Why don't you just grab the tire by the top and shake it back and forth like you have a pair. If you hear clunking, you now what the problem is. Bad bearingshape don't always have slop but 90% of the time they do.
  17. Dec 29, 2017 at 5:36 AM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    That's what my wheel bearing sounded like when it was worn out. Replaced at around 165k. Bearings had no slop, just worn out.
  18. Dec 29, 2017 at 6:53 AM
    Jaggerbub
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    I was leaning towards the OP possibly needing to do a ecgs fix.
  19. Dec 29, 2017 at 7:29 AM
    grunt66
    Vista, CA
    I will be doing this today or tomorrow. We have several other vehicles to drive and the wife has me gainfully employed with things to do today so I might not get to it today. My only concern is that other members have stated on posts I have researched that there was no play when looking for play while moving the tire / wheel assembly and the wheel bearing was still found to be bad.
  20. Dec 29, 2017 at 10:44 AM
    BamaToy1997
    Bill
    Navarre, FL
    If the bearing is at the beginning time of wear failure, then it may not show any movement when lifted and wiggling it. I do typically suggest that when inspecting the bearings, spin the wheels by hand and feel for as well as listen for anything that is unusual or abnormal. You shouldn't hear any noise, and the movement should be smooth spinning.
