*FIXED*Is it usable? (nail between tread)
Discussion in 'Wheels & Tires' started by crackils, Sep 6, 2022.
  1. Sep 6, 2022 at 2:46 PM
    crackils
    crackils [OP] Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    11-14 update
    Got it patch plugged and it's good to go now
    Woke up and found a nail in my tire. I removed the nail and plugged it, but wondering if it's safe to drive on? Or what I can do?
    My concern is it's between the tread. This is my first nail in an AT tire so idk
    20220906_173408.jpg 20220906_173423.jpg 20220906_173430.jpg 20220906_173513.jpg
  2. Sep 6, 2022 at 2:51 PM
    saint277
    saint277 Vigilo Confido
    Should be ok to drive on, but you should get a tire shop to put a patch in it asap. Between the tread doesn't matter, its sidewall damage that can't really be fixed.
    AxisCab, Key-Rei, Tacoma Mike and 3 others like this.
  3. Sep 6, 2022 at 2:52 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Looks to me like you're screwed.
  4. Sep 6, 2022 at 2:57 PM
    Swb_05
    Swb_05 Member
    Casey
    2005 Speedway Blue TRD OR
    X2, never had any problems to speak of. Sometimes a slow leak but that's all.
  5. Sep 6, 2022 at 3:01 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    Most tire shops would probably pass on that patch as it is “too close to the sidewall” I call BS. I had a nail in the same spot on a fairly new tire, got the spiel from tire shop, decided I wasn’t about to throw away a $150 tire and plugged it myself. I got about 45k miles out of it before buying new ones.
  6. Sep 6, 2022 at 3:02 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    They’re not supposed to patch holes in the outer tread ring or sidewall , only the inner tread rings. But you can ask. Might have to just plug it and keep an eye on it unless you can dismount the tire yourself.
  7. Sep 6, 2022 at 3:07 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I will say having it patched should be no problem. You may want to seek out a real tire shop not just a tire install shop (most national tire chain stores). Look toward shops that service commercial vehicles. Does not have to be Semis but just larger than your passenger vehicles.
    bagleboy likes this.
  8. Sep 6, 2022 at 3:11 PM
    Finanz
    Finanz Well-Known Member
    Sierra
    2021 Pro MGM
    Les Schwab Tires will repair it for free. No Problem.
    crackils[OP] likes this.
  9. Sep 6, 2022 at 3:17 PM
    01 dhrracer
    Still Shopping
    I don't believe they have moved into Florida yet.
    soundman98 and crackils[OP] like this.
  10. Sep 6, 2022 at 5:18 PM
    crackils
    Shane
    FL
    Thanks all for your input. I'll see about getting a patch! Fortunately i have an identical spare that I rotate in and I'll use it for now.
  11. Sep 6, 2022 at 5:23 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Just plug it...
    TnShooter and whatstcp like this.
  12. Sep 6, 2022 at 5:59 PM
    JTfromWV
    JTfromWV Active Member
    WV/VA border
    2022 AG TRDOR 6mt
    I would trust that plug till the tread wears out.
    Stuck in VT, whatstcp and wilcam47 like this.
  13. Sep 6, 2022 at 6:12 PM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    Costco Tire also plugs tires. Very helpful, with no squawks about the aftermarket TPMS sensors preprogrammed and purchased from an eBay store when they did a winter tire swap, 8 wheels/4 tires from steel to Gen3 offroad alloy wheels (factory takeoffs, and a fifth was mounted later).
  14. Sep 6, 2022 at 6:17 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Technically it can be repaired, but most tire shops are not equipped to do it. It's known as a section repair as opposed to the more common puncture repair. Raw rubber is applied to the cleaned out void and cured under heat and pressure in a retread chamber; along with a reinforced patch on the inside.
    asuchemist likes this.
  15. Sep 6, 2022 at 6:31 PM
    Bishop84
    Bishop84 Well-Known Member
    I'd patch that without blinking.
    AxisCab and TnShooter like this.
  16. Sep 6, 2022 at 6:33 PM
    saint277
    How long does it take you to do a patch? you got eye drops on stand by while your working on it?
  17. Sep 6, 2022 at 6:38 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Perpetual safety squint.
    soundman98 likes this.
  18. Sep 6, 2022 at 6:38 PM
    Bishop84
    I work fast, what I do is put a bigger nail in with caulking.
    soundman98, splitbolt and landphil like this.
  19. Sep 6, 2022 at 6:52 PM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    Your options are:
    1: leave the plug
    2: find a local family owned shop and have them patch it, bigger chain owned shops won't do it for insurance reasons
    3: buy a patch kit, have a tire shop remove the tire, patch it yourself and have them install it back
    If I was you I'd go with option 1. I had that exact tire on my 08 tacoma and i lived near a scrap yard so within a year i had like 2 plugs on the passenger front tire. The tire held fine until the end of it's life. It took the abuse of off roading with 0 leaks
  20. Sep 6, 2022 at 7:00 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    rotate the cooper to the spare. I would not trust it.
    I had similar screw in my coopers and discount replaced no hassle.
    Charlie Bravo and crackils[OP] like this.
